Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
How to make the tangent?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: How to make the tangent? (Read 3112 times)
2e4lite
Guest
on:
November 01, 2013, 10:27:16 PM »
Who can write a program that can make the tangent by specifying the point in 2d curves,the length and the angle? It will a great help to me.Thanks!
Last Edit: November 01, 2013, 11:18:44 PM by 2e4lite
Logged
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
Re: How to make the tangent ?
Reply #1 on:
November 01, 2013, 10:37:33 PM »
Please clarify your question.
What information do you know.?
Logged
ymg
Guest
Re: How to make the tangent?
Reply #2 on:
November 02, 2013, 04:14:26 AM »
Not sure if it is what you are looking for, but using this little bit of code by AlanJT
you have the angle. You already have the point.
So your tangent is an xline starting at your point with angle as slope.
ymg
Code - Auto/Visual Lisp:
[Select]
;; Return angle along curve, at specified point (on curve) ;
;; e - valid curve (ENAME or VLA-OBJECT) ;
;; p - point on curve ;
;; Alan J. Thompson, 11.04.10 ;
defun
AngleAtPoint
e p
angle
0
0
0
vlax-curve-getFirstDeriv
e
vlax-curve-getParamAtPoint
e p
;; Example call and entmaking an XLINE
setq
a
angleatpoint enameofcurve point
entmakex
list
0
"XLINE"
100
"AcDbEntity"
100
"AcDbXline"
62
1
cons
10
point
list
11
cos
a
sin
a
0.0
Last Edit: November 02, 2013, 04:46:56 AM by ymg
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
