Author Topic: Layer Isolation Lock/Unlock - Fading problem  (Read 2263 times)
Beekee
  • Mosquito
« on: November 01, 2013, 12:10:30 PM »
Hi, I found the routine for Layer Isolation made by Kent Cooper. This one is very cool but it works just like on/off isolation. I would like to add lock/unlock isolation (fading) functionality as well. Job almost done, but I’m struggling with fading (LAYLOCKFADECTL). The problem is Unisolation.
I run the new routine (LIL) and then I want to unlock layers back again. Run LUO, it does its job, and it looks just fine. But if I do REGEN, fades all unlocked layers again even if they are not locked anymore.
Please help, how to make unfading permanent.
Re: Layer Isolation Lock/Unlock - Fading problem
« Reply #1 on: November 01, 2013, 06:11:46 PM »
Welcome to the Swamp.
Have you asked Kent to modify the routine?
Most likely he would accommodate you.
Beekee
  • Mosquito
« Reply #2 on: November 01, 2013, 06:57:31 PM »
Actually, I have not. I would not bother him or anyone particular. I thought somebody might have experience with this variable, because I cant figure out, how it works :/
