Hi Marko!
Sorry for dellay. I come a bit forward and would like use your routine more practically. Your routine works fine, but if I run I have to know which tollerance I must type in. In my example it was 7.67 deg, but how can I know this in beginning. Have I to measure every segmentsdiff in angle or is there a esier way. I try to generate all diffence angles some text. I would be nice it comes before I must type in tollerance angle.
A big compliment to your effort.
(defun c:reconst3dpoly (/ 3dpl fuzzang fuzzangr initang pt ptlst pt1lst pt2lst ptlst1 ptlst11 ptlst2 ss tst tt vert)
(prompt "\nPick zig-zag reference 3d polyline")
(while (not ss)
(setq ss (ssget "_+.:E:S:L" (list '(0 . "POLYLINE") '(70 . 8))))
(if (not ss) (prompt "\nMissed, try again"))
(setq 3dpl (ssname ss 0))
(setq vert 3dpl)
(while (and (setq vert (entnext vert)) (eq (cdr (assoc 0 (entget vert))) "VERTEX"))
(setq pt (cdr (assoc 10 (entget vert))))
(setq ptlst (cons pt ptlst))
(setq ptlst (reverse ptlst))
(initget 7)
(setq fuzzang (getreal "\nInput fuzz tolerance angle in decimal degrees for recreating new 3d polyines of reference 3d polyline vertices: "))
(setq fuzzangr (* (/ fuzzang 180.0) pi))
(setq initang (angle (car ptlst) (cadr ptlst)))
(setq pt2lst ptlst)
(foreach pt1 ptlst
(setq pt1lst (cons pt1 pt1lst))
(foreach pt pt1lst (setq pt2lst (vl-remove pt pt2lst)))
(if (and ptlst1 (equal pt1 (car ptlst1) 1e-6)) (setq tt nil))
(foreach pt2 pt2lst
(if (and (not tt)
(equal (setq diffan (angle pt1 pt2)) initang fuzzangr))
(setq diffan (/ (* 180 (- diffan initang)) pi))
(setq initang (angle pt1 pt2))
(setq ptlst1 (cons pt1 ptlst1)
ptlst1 (cons pt2 ptlst1)
tt t
(entmake (list '(0 . "TEXT")
'(100 . "AcDbEntity")
'(100 . "AcDbText")
(cons 10 (trans pt1 1 0))
(cons 8 (getvar "CLAYER"))
(cons 7 "SIMPLEX8"); Textstyle
(cons 62 3) ; TextColor
(cons 40 (getvar "TEXTSIZE")); Textsize
(cons 41 0.8) ; TextWidth
(cons 50 0) ; TextAngle
(cons 1 (rtos diffan 2 (getvar "AUPREC"))) ; Textmessage
(setq ptlst1 (reverse ptlst1))
(setq ptlst1 (acet-list-remove-duplicates ptlst1 1e-6))
(setq initang (angle (car ptlst1) (cadr ptlst1)))
(setq tst (mapcar '(lambda (a b) (if (equal (angle a b) initang fuzzangr) (progn (setq initang (angle a b)) T) nil)) ptlst1 (cdr ptlst1)))
(while (eq (car tst) T)
(setq ptlst11 (cons (car ptlst1) ptlst11))
(setq ptlst1 (cdr ptlst1) tst (cdr tst))
(setq ptlst1 ptlst11)
(setq ptlst2 ptlst)
(foreach pt ptlst1
(setq ptlst2 (vl-remove pt ptlst2))
(entmake
(list
'(0 . "POLYLINE")
'(100 . "AcDb3dPolyline")
'(66 . 1)
'(62 . 1)
'(10 0.0 0.0 0.0)
'(70 . 8)
'(210 0.0 0.0 1.0)
(foreach pt ptlst1
(entmake
(list
'(0 . "VERTEX")
'(100 . "AcDbVertex")
'(100 . "AcDb3dPolylineVertex")
(cons 10 pt)
'(70 . 32)
(entmake
(list
'(0 . "SEQEND")
(entmake
(list
'(0 . "POLYLINE")
'(66 . 1)
'(62 . 1)
'(10 0.0 0.0 0.0)
'(70 . 8)
'(210 0.0 0.0 1.0)
(foreach pt ptlst2
(entmake
(list
'(0 . "VERTEX")
(cons 10 pt)
'(70 . 32)
(entmake
(list
'(0 . "SEQEND")
