Author Topic: Replace block, also when to be replaced block is nested  (Read 10467 times)
kruuger
Re: Replace block, also when to be replaced block is nested
« Reply #15 on: October 10, 2013, 12:54:45 PM »
I think this should do what you want. The new block definition has to exist in the drawing though.
(defun _updateblocks (old new)
  (if (tblobjname "block" new)
    (vlax-for b   (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
      (vlax-for   bb b
   (if (and (= (vla-get-objectname bb) "AcDbBlockReference")
       (wcmatch (strcase (vla-get-name bb)) (strcase old))
       (print (vla-get-name bb))
     (vl-catch-all-apply 'vla-put-name (list bb new))
(_updateblocks "old" "new")
wow . very interesting way to replace block :)
maybe vla-get-EffectiveName to replace dynamic also
kruuger
« Reply #16 on: October 10, 2013, 12:56:21 PM »
Nice explanation Lee, very helpful.
Cheers Alan 8-)
« Reply #17 on: October 10, 2013, 01:58:11 PM »
kruuger
      (vlax-for bb b
(wcmatch (strcase (vlax-get bb
     (if (vlax-property-available-p bb 'effectivename)
       'effectivename
       'name
  (strcase old)
;; (_updateblocks "old" "new")
;D
roy_043
  • BricsCAD 18
« Reply #18 on: October 10, 2013, 02:15:42 PM »
@ronjonp: No need to check if the effectivename property is available.
I will update my code (thank you kruuger).
« Last Edit: October 10, 2013, 02:27:30 PM by roy_043 »
roy_043
  • BricsCAD 18
« Reply #19 on: October 10, 2013, 02:28:29 PM »
Updated code:
  1. (defun KGA_Conv_Collection_To_List (coll / ret)
  2.     (vlax-for a coll
  3.       (setq ret (cons a ret))
  4.     )
  5.   )
  6. )
  7.
  8. (defun BKG_ReplaceBlock_InputName (message / input)
  9.   (setq input (getstring T message))
  10.   (if (= input "")
  11.     (if
  12.       (and
  13.         (setq input (car (entsel)))
  14.         (setq input (vlax-ename->vla-object input))
  15.         (= (vla-get-objectname input) "AcDbBlockReference")
  16.       )
  17.       (vla-get-effectivename input)
  18.     )
  19.     input
  20.   )
  21. )
  22.
  23. (defun c:BKG_ReplaceBlock ( / actDocObject blockFile blockNameNew blockNameOld count)
  24.   (if (= (logand (getvar 'undoctl) 8) 8)
  25.     (vla-endundomark actDocObject)
  26.   )
  27.   (vla-startundomark actDocObject)
  28.   (if
  29.     (and
  30.       (setq blockNameOld
  31.         (BKG_ReplaceBlock_InputName "\nBlock to replace (Enter to select): ")
  32.       )
  33.       (tblobjname "block" blockNameOld)
  34.       (setq blockNameNew
  35.         (BKG_ReplaceBlock_InputName
  36.           (strcat "\nReplace '" blockNameOld "' block with (Enter to select): ")
  37.         )
  38.       )
  39.       (or
  40.         (tblobjname "block" blockNameNew)
  41.         (and
  42.           (snvalid blockNameNew)
  43.           (setq blockFile (getfiled "Select a drawing" " " "dwg;dxf" 0))
  44.           (setvar 'cmdecho 0)
  45.           (not (command "_.insert" (strcat blockNameNew "=" blockFile) nil))
  46.           (setvar 'cmdecho 1)
  47.           (tblobjname "block" blockNameNew)
  48.         )
  49.       )
  50.     )
  51.     (progn
  52.       (setq blockNameOld (strcase blockNameOld))
  53.       (setq count
  54.         (length
  55.           (vl-remove
  56.             nil
  57.             (apply
  58.               'append
  59.               (mapcar
  60.                 '(lambda (blockDefObject)
  61.                   (mapcar
  62.                     '(lambda (object)
  63.                       (if
  64.                         (and
  65.                           (= (vla-get-objectname object) "AcDbBlockReference")
  66.                           (= (strcase (vla-get-effectivename object)) blockNameOld)
  67.                         )
  68.                         (progn
  69.                           (vla-put-name object blockNameNew)
  70.                           T
  71.                         )
  72.                       )
  73.                     )
  74.                     (KGA_Conv_Collection_To_List blockDefObject)
  75.                   )
  76.                 )
  77.                 (KGA_Conv_Collection_To_List (vla-get-blocks actDocObject))
  78.               )
  79.             )
  80.           )
  81.         )
  82.       )
  83.       (princ (strcat "\n" (itoa count) " block reference(s) updated "))
  84.     )
  85.   )
  86.   (vla-endundomark actDocObject)
  87.   (princ)
  88. )
  89.
  90. (defun c:BRBL ()
  91.   (c:BKG_ReplaceBlock)
  92. )
  93.
  94. (princ "\nUse: BKG_ReplaceBlock or BRBL ")
roy_043
  • BricsCAD 18
« Reply #20 on: October 10, 2013, 02:29:15 PM »
And how about AcDbMInsertBlock...
« Reply #21 on: October 10, 2013, 02:38:12 PM »
What about for older versions of CAD ?
roy_043
  • BricsCAD 18
« Reply #22 on: October 11, 2013, 04:30:45 AM »
That is a good point. When were dynamic blocks introduced?
roy_043
  • BricsCAD 18
« Reply #23 on: October 11, 2013, 06:33:18 AM »
;;; BKG_ReplaceBlock: Change the referenced name of inserts.
;;; Author:       Roy Klein Gebbinck (www.b-k-g.nl)
;;; Made for:     http://www.theswamp.org/index.php?topic=45490.0
;;; Version:      20131011.
;;; History:      20131011: Added xref and recursion check.
;;;               20131011: Added support for AcDbMInsertBlock.
;;;               20131011: Using effective name (thanks kruuger and ronjonp).
;;;               20131010: First version.
« Reply #24 on: October 11, 2013, 08:31:51 AM »
I think it was 2006 .. but don't know for sure.
« Reply #25 on: October 11, 2013, 08:42:48 AM »
I have 2004 & 2006, 2006 has dynamic blocks.
kruuger
« Reply #26 on: October 11, 2013, 12:39:31 PM »
works nicely :) may come in handy someday
puzzle...when we replace attribute block with regular block attributes occurs in all inserts. how to attsync existing/inserted block ?
thanks
kruuger
roy_043
  • BricsCAD 18
« Reply #27 on: October 13, 2013, 06:18:44 AM »
... how to attsync existing/inserted block ?
;;; Version:      20131013.
;;; History:      20131013: If the new block has no editable attributes,
;;;                         existing attribute references are deleted.
;;;                         Else there is an optional call to the Attsync
;;;                         command.
;;;               20131011: Added xref and recursion check.
