See Tip|1552 Cadalyst, get the code ,september 1999 For the lisp ZPP
And one other around a arc.
;; This routine allows the user to place parking stalls along an arc.
;; Written by Ron Engberg 12-2000
;; Radians to degrees
(defun rtd (r)
(* (/ r pi) 180)
;; Degrees to Radians
(defun dtr (r)
(/ (* 2 pi) 360)
(defun c:arc-park (/ ent arc-pt1 stall-w stall-l arc-side arc-dir stall-count
arc_list arc-cpt arc-diam s-ang e-ang arc-circ delta arc-length
stall-angle-in stall-angle-out arc-base arc-rot-angle)
;; Screen echo off
(setvar "cmdecho" 0)
;; Set to World UCS
(command "ucs" "w")
;; Parking stall information
(setq ent (entsel "\nSelect ARC: "))
(initget 1)
(setq arc-pt1 (getpoint "\nStarting End of ARC: "))
(initget 7)
(setq stall-w (getreal "\nStall Width: "))
(initget 7)
(setq stall-l (getreal "\nStall Length: "))
(setq arc-side (getstring "\nInside or Outside < I,O >: "))
(setq arc-dir (getstring "\nClockwise or Counter Clockwise < CW,CCW >: "))
(initget 7)
(setq stall-count (getint "\nNumber of Stalls: "))
;; Arc information
(setq arc_list (entget (car ent)))
(setq arc-cpt (cdr (assoc 10 arc_list))) ;center point
(setq arc-diam (* (cdr (assoc 40 arc_list)) 2)) ;arc diameter
(if (or (= arc-side "I") (= arc-side "i"))
(setq arc-diam (- arc-diam (* 2 stall-l)))
(setq s-ang (cdr (assoc 50 arc_list)) ;start angle
e-ang (cdr (assoc 51 arc_list)) ;end angle
arc-circ (* pi arc-diam) ;arc circumference
;arc length
); end arc info
;; Test for delta angle
(if (> s_ang e_ang)
(setq delta (+ (- 6.2831853 s-ang) e-ang))
(setq delta (abs (- s-ang e-ang)))
); end if
(setq arc-length (* (cdr (assoc 40 arc_list)) delta))
;; Angle for starter line
(setq stall-angle-in (angle arc-pt1 arc-cpt) ;stalls inside arc
stall-angle-out (angle arc-cpt arc-pt1) ;stalls outside arc
); end set group
;; Rotation info
(setq arc-base (/ arc-circ 360.0000) ;length per degree
arc-rot-angle (/ stall-w arc-base) ;degrees per stall
); end set group
;; Test for inside or outside
(if (or (= arc-side "I") (= arc-side "i")) ;case sensitive ?
(command "line" arc-pt1 (polar arc-pt1 stall-angle-in stall-l) "") ;if inside
(command "line" arc-pt1 (polar arc-pt1 stall-angle-out stall-l) "") ;else, outside
);end if
;; Test for clockwise or counter clockwise
(if (or (= arc-dir "CCW") (= arc-dir "ccw")) ;case sensitive ?
(repeat stall-count
(command "array" "l" "" "P" arc-cpt "2" arc-rot-angle "Y")
); if ccw
(repeat stall-count
(command "array" "l" "" "P" arc-cpt "2" (- arc-rot-angle (* 2 arc-rot-angle)) "Y")
); else cw
); end if
;; Reset UCS
(command "ucs" "p")
;; Screen echo on
(setvar "cmdecho" 1)
Good work,
François
