Author Topic: Rotating Attribute and keeping horizontal :Example  (Read 4126 times)
Jeff H
« on: October 08, 2013, 03:50:05 AM »
Seen this question asked and using a dynamic block you can rotate a block and the attribute while keeping it horizontal.
- Set Lock Position to Yes
- Place a Point Parameter
- Set Chain Action to Yes
- With the rotation action just select the point parameter and not the attribute.
The first block allows you to move the attribute while second one just hides in attached drawing below.
There are trade offs where you have to rotate it only with rotation parameter, and loose ability to use alignment parameter, etc......
The one nice thing you can gain without code which can handle all these situations is adding move and rotation to each attribute you will not loose its rotation or placement during a AttSync.
