Author Topic: 14MB empty drawing..  (Read 2474 times)
Andrea
« on: September 26, 2013, 11:26:12 AM »
Hi all,..
I've over 14MB empty DWG,..
all purge method ,wblock, reggap, layer filter, xdata removed, empty block, pages setups, scalistedit reset, all proxy removed,..
tried to saveas as diffrent format,..and version...
I also saved this file with DrafSigth, ZWCAD, BricSys, StarIcad, Teigha,..but drawing stay Huge size.
No entity inside the drawing...!?
all was deleted !
also,..I use AutoCAD 2014 and save the drawing in 2000 dwg format...
and it came over 216MB !!
any idea ?
thank you.
any suggestion ?
Keep smile...
Re: 14MB empty drawing..
« Reply #1 on: September 26, 2013, 11:53:44 AM »
Perhaps the Geographic Location is fubared, I've seen this a few times. In Autocad 2014 type in GEOGRAPHICLOCATION, if there is one set you will have the option to Edit, Define a new one, or remove, choose Remove, then save and exit. The last drawing I had like this was ~40mb that reduced down to ~300kb.
Andrea
« Reply #2 on: September 26, 2013, 12:10:04 PM »
thank you...
unfortunatly....it was not the solution....there is no geographiclocation in there...
this drawing was created With AutoCAD 2011.
 :roll:
Keep smile...
« Reply #3 on: September 26, 2013, 12:41:51 PM »
Could I perhaps have a look at the drawing? jeffm AT quuxsoft DOT com
kruuger
« Reply #4 on: September 26, 2013, 12:44:03 PM »
can you post the file ?
is there ACAD_DGN... dictionary ?
kruuger
Andrea
« Reply #5 on: September 26, 2013, 01:27:08 PM »
here..
Keep smile...
Marc'Antonio Alessi
  • Marco
« Reply #6 on: September 26, 2013, 01:40:03 PM »
Try -purge r      (regapps):
Eliminazione di applicazione registrata "AeccUiMgr" in corso.
Eliminazione di applicazione registrata "AeccUiModel" in corso.
Eliminazione di applicazione registrata "AeccLand80" in corso.
Eliminazione di applicazione registrata "ManulPointsAssociative" in corso.
Eliminazione di applicazione registrata "ACAD_SPLINE_DATA" in corso.
Eliminazione di applicazione registrata "ACAD_SPLINE_DATA2" in corso.
Eliminazione di applicazione registrata "DCA_MODELER" in corso.
Eliminazione di applicazione registrata "USG-2000" in corso.
Eliminazione di applicazione registrata "SPACE_MAX_GAPSIZE" in corso.
Eliminazione di applicazione registrata "AeccPlanProd50ViewportType" in corso.
Eliminazione di applicazione registrata "AeccLand70" in corso.
1510 applicazioni registrate eliminati.
> 1510 regapps!
kruuger
« Reply #7 on: September 26, 2013, 01:43:56 PM »
here..
as expected. delete microstation crap and file is 70k.
(dictremove (namedobjdict) "ACAD_DGNLINESTYLECOMP")read more here:
http://www.theswamp.org/index.php?topic=42110.0
kruuger
Andrea
« Reply #8 on: September 26, 2013, 01:51:12 PM »
LIFE SAVER !!!!!!!!!!!!!
Thank you so much. ! :)
you guys rocks !
Keep smile...
gile
  • Marseille, France
« Reply #9 on: September 26, 2013, 04:00:34 PM »
Hi Andrea,
This issue was also raised here in the .NET forum, and Autodesk provides an Hotfix there.
