my version, draws a box and line, with label
; MKLAYTXT.LSP (c) Dan Allen 1998
; derived from
; SAVLAY.LSP
; Copyright (c) Barry R. Bowen 1992
(defun c:MAKECLAYERTEXT () (MAKELAYERTEXT (getvar "clayer")) (princ))
(defun c:MAKELAYERTEXT ( / lay)
(princ (strcat "\nCreate layer list - text size: " (rtos (getvar "textsize"))))
(setq lay (strcase (getstring "\nEnter layer name pattern <*>: ")))
(if (= lay "") (setq lay "*"))
(MAKELAYERTEXT lay)
(defun MAKELAYERTEXT (laymatch / pt px py ts n tprmpt tr iy ix ix2 pty1 pLx1 pLx2
l_list llist lname laycons elast)
(SETV "cmdecho" 0)
(SETV "clayer" "0") ;set to layer 0
(SETV "cecolor" "bylayer")
(setq pt (getpoint "Select point to start text <0,0>: "))
(if (not pt) (setq pt (list 0.0 0.0 0.0)))
(setq llist (tblnext "layer" T)
px (car pt)
py (cadr pt)
ts (if (ABC_stylefixed) ;get default textsize
(progn (setq tprmpt (list "")) ; trap for text command prompt
(ABC_stylefixed)) ;from style if fixed
(progn (setq tprmpt (list "" "")) ; trap for text command prompt
(getvar "textsize")) ;from variable if not
tr (/ ts 0.09375) ;txtsize ratio to 3/32" (basis for layout)
iy (* ts 1.67) ;vertical text increment
ix (* tr 1.5) ;distance from text to line
ix2 (* tr 3.0) ;line length
ix3 (* iy 3) ;distance from line to color text
ix4 (* iy 1) ;distance from color text to linetype
elast (entlast) ;remember last entity
(SETV "osmode" 0)
(command "undo" "begin")
(while (/= llist nil) ;get layer list
(setq lname (cdr (assoc 2 llist))) ;get layer name
(if (and (not (wcmatch lname "0")) ;skip layer 0 and defpoints
(not (wcmatch (strcase lname) "DEFPOINTS")) ;
(not (wcmatch lname "*|*")) ;check to make sure not an xref layer
(wcmatch lname laymatch)) ;check to see if it matches parameter
(setq l_list (cons lname l_list)) ;add to list
) ;end if
(setq llist (tblnext "layer")) ;forward to next layer
) ;end while
(if l_list ;sort list alphabetically
(setq l_list (ACAD_STRLSORT l_list)) ; built-in acad subroutine
(foreach lname l_list
(setq lcol (itoa (abs (cdr ;get layer color w/color name
(assoc 62 (tblsearch "layer" lname))))) ; from external routine
ltyp (strcat "("
(cdr (assoc 6 (tblsearch "layer" lname))) ;get layer linetype
pty1 (strcat (rtos px 2 8) "," (rtos py 2 8)) ;layer name text location
pLx1 (strcat (rtos (+ px ix) 2 8) ;start point of line
(rtos py 2 8))
pLx2 (strcat (rtos (+ px ix ix2) 2 8) ;end point of line
(rtos py 2 8))
pSx1 (strcat (rtos (+ px ix ix2) 2 8) ;1st point of solid
(rtos (- py (* 0.5 iy)) 2 8))
pSx2 (strcat (rtos (+ px ix ix2) 2 8) ;2nd point of solid
(rtos (+ py (* 0.5 iy)) 2 8))
pSx3 (strcat (rtos (+ px ix ix2 iy) 2 8) ;3rd point of solid
pSx4 (strcat (rtos (+ px ix ix2 iy) 2 8) ;4th point of solid
ptx2 (strcat (rtos (+ px ix ix2 ix3) 2 8) ;start point of color text
(rtos py 2 8))
ptx3 (strcat (rtos (+ px ix ix2 ix3 ix4) 2 8) ;start point of linetype text
(rtos py 2 8))
py (- py iy) ;increment y position
(setvar "clayer" "0")
(setvar "cecolor" "8")
;; (command "text" "ml" pty1) ;add background text in color 8 layer 0
;; (foreach n tprmpt (command n))(command lname) ;trap for fixed style height
(setvar "cecolor" "bylayer")
(command "-layer" "thaw" lname "set" lname "")
;; (setvar "clayer" lname)
(command "text" "ml" pty1) ;add foreground text in layer color
(command "line" pLx1 pLx2 "")
(command "solid" pSx1 pSx2 pSx3 pSx4 "")
(command "text" "mr" ptx2) ;add layer color number
(foreach n tprmpt (command n))(command lcol)
(if (/= "(CONTINUOUS)" ltyp) ;if not continuous
(command "text" "ml" ptx3) ; add layer linetype
(foreach n tprmpt (command n))(command ltyp)
) ;end foreach
;(command "select" (ABC_AFTER elast) "") ;select new entities to be used as previous
(command "undo" "end")
(RSETV "cecolor")
(RSETV "clayer")
(RSETV "osmode")
(RSETV "cmdecho")
; Does current text style have a fixed height?
; - from Looking Glass Microproducts
(Defun ABC_stylefixed (/ tsize)
(If (/=
0.0
(Setq
tsize (CDR
(Assoc
40
(TblSearch "style" (GetVar "textstyle"))
tsize
; SETV function saves setvar settings to be reset at end with RSETV
; (setv "cmdecho" 0) set cmdecho off
; (rsetv "cmdecho") resets cmdecho (see below)
; taken from Essential AutoLISP by Roy Harkow
(defun-q SETV (sysvar newval / cmdnam)
(setq cmdnam (read (strcat sysvar "1"))) ;Create [savevar]1
(set cmdnam (getvar sysvar)) ;Save [savevar]'s value
(setvar sysvar newval) ;Then set [savevar] to new value
(defun-q RSETV (sysvar / )
(if (eval (read (strcat sysvar "1"))) ;Only change if exists
(setvar sysvar (eval cmdnam)) ;Restore [savevar]'s value
(set cmdnam nil)
) ;end progn
) ;end if
