Author Topic: [SOLVED] "Startapp" for Explorer: does not open the file  (Read 2964 times)
Peter2
« on: September 15, 2013, 08:35:06 AM »
I tried to use "Startapp" to open "every" file like the explorer does with double-click.
There are some posts here which show this way:
(startapp "explorer" "test.xls") -> starts Excel
(startapp "explorer" "test.ctb") -> starts plotstyle-editor
Seem to be simple; I tried
(startapp "notepad" "c://muster.ini") -> opens file with notepad. Fine.
33
(startapp "explorer" "c://muster.ini") -> opens explorer in AutoCAD-folder, no notepad, no ini
33
Any idea what could be wrong?
(PS: DosLib can not be used ...)
« Last Edit: September 15, 2013, 09:09:42 AM by Peter2 »
Peter
BricsCAD V23
ribarm
  • Marko Ribar, architect
Re: "Startapp" for Explorer: does not open the file
« Reply #1 on: September 15, 2013, 08:41:21 AM »
Have you tried :
"c:\\muster.ini"
instead of :
"c://muster.ini"
M.R. on Youtube
Peter2
« Reply #2 on: September 15, 2013, 08:45:35 AM »
Have you tried :...
Yes. I tried backward and forward, single and double ....
And of course I tried also to double-click to the file inside explorer: It was opened with notepad as expected.
Here was the same problem: http://www.theswamp.org/index.php?topic=44768.0
But the solution was focused to open a browser; I need to open the depending software.
Peter
BricsCAD V23
Peter2
« Reply #3 on: September 15, 2013, 09:09:15 AM »
Solved!
Sh.....  :ugly:
I had a confusion between my keyboard and my keyboard settings, ans so I entered the backslash with "Alt+092". But I made I typo and I wrote "\\" instead of "\\".
Now you want to say: Hmmmh - where is the difference??? It is the same!  :-o
No. Copy it to your editor ...
In the meantime I found another simple way:
(vlax-invoke-method (vlax-create-object "shell.application") 'open "c:\\muster.ini")But I did not test it with typos ...
Have a nice sunday.
Peter
BricsCAD V23
