Author Topic: Hatching islands between two polylines  (Read 7810 times)
motee-z
Re: Hatching islands between two polylines
« Reply #30 on: March 13, 2016, 11:56:00 AM »
thank you ymg for modification but i am sorry to inform you it is not working on my autocad version 2015
and i got these messges
Select Reference Polyline:
Select objects:
Select Proposed Polyline:
Select objects:
2D point or option keyword required.
Error: bad argument type: lentityp nil
Specify internal point or [Properties/Select objects/draW boundary/remove Boundaries/Advanced/DRaw order/Origin/ANnotative/hatch COlor/LAyer/Transparency]:
any reason for that
ymg
« Reply #31 on: March 13, 2016, 12:04:54 PM »
moteez,
I don't have 2015 so I cannot check.
But the most likely reason would be that either the hatch command
or the boundary command have changed the requested input since 2012.
Notes that I do get the message for 2d point but the command completes
normally.
Try changing the hatch line to this:
(vl-cmdf "._-HATCH" "_CO" hcol "_P" "SOLID" "_S" bnd "" "")
ymg
« Last Edit: March 13, 2016, 12:18:29 PM by ymg »
motee-z
« Reply #32 on: March 13, 2016, 12:37:40 PM »
perfect gob
Thank you ymg for your efforts
Sudipta2020
  • Mosquito
« Reply #33 on: July 30, 2020, 02:53:10 AM »
you done great work. when this lisp file use in autocad 2018 or higher it create problem of True color.
