Author Topic: XREFs code  (Read 2693 times)
V-Man
XREFs code
« on: September 13, 2013, 11:08:09 AM »
In need of simple code to check the existence of any XREF's in current drawing and if any found LOCK the layer they are inserted on.
Thanks,
Re: XREFs code
« Reply #1 on: September 13, 2013, 11:47:26 AM »
Try this quick draft:
  1. (defun c:lxr ( / a b e i l s x )
  2.     (while (setq a (tblnext "block" (null a)))
  3.         (if (= 4 (logand 4 (cdr (assoc 70 a))))
  4.             (setq b (vl-list* "," (cdr (assoc 2 a)) b))
  5.         )
  6.     )
  7.     (if (and b (setq s (ssget "_X" (list '(0 . "INSERT") (cons 2 (apply 'strcat (cdr b)))))))
  8.         (repeat (setq i (sslength s))
  9.             (if (not (member (setq x (cdr (assoc 8 (entget (ssname s (setq i (1- i))))))) l))
  10.                 (setq l (cons x l))
  11.             )
  12.         )
  13.     )
  14.     (foreach x l
  15.         (setq e (entget (tblobjname "layer" x))
  16.               a (assoc 70 e)
  17.         )
  18.         (entmod (subst (cons 70 (logior 4 (cdr a))) a e))
  19.     )
  20.     (princ)
  21. )
Tharwat
  • Hypersensitive
Re: XREFs code
« Reply #2 on: September 13, 2013, 12:01:55 PM »
Maybe REGEN would be needed after locking layers.
V-Man
Re: XREFs code
« Reply #3 on: September 13, 2013, 01:20:24 PM »
Thank you sir for your generous support. That procedure worked perfectly.
Re: XREFs code
« Reply #4 on: September 13, 2013, 05:00:27 PM »
You're very welcome V-Man  :-)
tedg
Re: XREFs code
« Reply #5 on: September 16, 2013, 02:17:00 PM »
Thanks,
Instead of locking whatever layer  they are inserted on, why wouldn't you want to put your xrefs on an appropriate layer and then lock it?
Such as G-ANNO-REFR (or what ever your desired standard is)?
Just a thought.
That way if someone put an xref on the wrong layer such as a text layer, you're not locking that one.
Windows 10 Pro 64bit, AutoCAD 2023, REVIT 2023
Re: XREFs code
« Reply #6 on: September 16, 2013, 08:02:59 PM »
I agree Ted. One option is to name the layer to match the xref name ... 'standards' allowing :-)
