Author Topic: .IsDynamicBlock returns false ?  (Read 6933 times)
Bert
« on: September 03, 2013, 08:06:41 AM »
Hello guys,
Been stuck for a couple of hours on the job and was wondering if any of you could help me ?
(I bet you can  :wink: )
What i'm doing:
   - Have a 'master dwg' that has relevant Blocks & Dynamic Blocks
   - Running a routine that populates a new production  drawing's modelspace with BlockReferences, importing from the 'master dwg' if the block is not yet present in the new production drawing.
   - Importing 'regular' & Dynamic blocks alike.
   - Able to set attributes and dynamic properties where and when needed
   - After this initial insertion-method, all blocks are inserted and dimensioned in place, a certain check needs to be made.
     I traverse the ModelSpace and based on the BlockRef.Name a certain action needs to be performed
   - This works for my regular blocks, but the Dynamic ones all have those anonymous names, like "*U24", making them dodge my name-check.
found a solution to get the 'EffectiveName' of a dynamicblock :
Public Shared Function EffectiveName(ByVal blkref As BlockReference) As String
        If blkref.IsDynamicBlock Then
            Return DirectCast(blkref.DynamicBlockTableRecord.GetObject(OpenMode.ForRead), BlockTableRecord).Name
        Else
            Return blkref.Name
        End If
End Function
But problem is : blkref.IsDynamicBlock  allways returns false !
So even when my Dynamic blocks in ModelSpace are inserted well, have attributes and dynamic properties correctly set-up and function well progammatically they are not recognised as being Dynamic Blocks ?
Why would this be ?
n.yuan
Re: .IsDynamicBlock returns false ?
« Reply #1 on: September 03, 2013, 09:42:27 AM »
Not seeing more of your code as for where the Blockreference.IsDynamicBlock is called, I'd be almost certain that the call is made in such way: you obtain a Blockreference object in a transaction, and then pass the BlockReference object around (for getting its "effective name") outside that transaction where the BlockReference is obtained. That is why IsDynamicBlock returns false, even you do know that the block is a dynamic block reference.
Passing object obtained via Transaction is not good and obtaining DBObject's properties outside a transaction scope may not get you what you want, as you just experienced. Instead, you ALWAYS pass ObjectID between transaction, and obtain DBObject's properties within the scope of active transaction.
Bert
« Reply #2 on: September 03, 2013, 10:20:56 AM »
Hey n.yuan, thanks for replying !
This is how i'm doing this (code-wise):
Step 1) Inserting my Dynamic Blocks :
        ' assure the desired doorsketchBlock is present in the blocktable
        acadBlockId = Acad.searchOrImportBlock(Acad.SketchblocksFileName, blockName)
        ' insert the block in modelspace
        acadblockref = Acad.InsertBlock(blockName, insPnt, 1, 1, 1, _acParentBlockref.Rotation)
        'Set Dynamic properties
        AttVals.Clear()
        AttVals.Add("Lookup|" & dimNuttigeBreedte & " x " & dimPaneelBreedte)
        AttVals.Add("Paneeldikte|" & _acParentBlockref.ScaleFactors.Y)
        AttVals.Add("Draairichting|" & conDraairichting)
        Acad.set_DynamicBlockProperties(acadblockref, AttVals)
        'Set Attributes
        AttVals.Clear()
        AttVals.Add("InventTransId|" & genInventTransId)
        AttVals.Add("DIM|" & dimNuttigeBreedte & "|" & dimPaneelBreedte & "|" & dimNuttigeHoogte & "|" & _acParentBlockref.ScaleFactors.Z & "|" & doorPanelConn)
        AttVals.Add("ONDERBOUW|" & IIf(conVerzonkenOpstelling, _
                                       Acad.get_AttValByIdx(_acParentBlockref, 3) & "|" & conVerzonkenOpstelling, _
                                       Acad.get_AttValByIdx(_acParentBlockref, 3)))
        Acad.set_BlockAttributes(acadblockref, AttVals)
4 methods come to play in the above code :
    Acad.searchOrImportBlock (checks if the desired block is allready present in the current drawings blocktable, if not it'll fetch it from the 'master drawing')
    Acad.InsertBlock (knows that the desired block is present in the current drawing's blocktable, it'll insert it in modelspace as and return a BlockReference object)
    Acad.set_DynamicBlockProperties (made to set Dynamic Properties of the given BlockReference)
    Acad.set_BlockAttributes (made to set attribute values of the given BlockReference)
    Shared Function searchOrImportBlock(_sourceFileName As String, _blockName As String) As ObjectId
        ' Get the current document and database
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim acCurDb As Database = acDoc.Database
        ' Lock the document
        Using acLckDoc As DocumentLock = acDoc.LockDocument()
            ' Start a transaction in the database
            Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                ' Get the Block table for the current database
                Dim acBlockTbl As BlockTable = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
                ' If found in local BlockTableRecord
                If acBlockTbl.Has(_blockName) Then
                    Return acBlockTbl(_blockName)
                End If
            End Using ' Dispose of the transaction
        End Using ' Unlock the document
        ' If not found in local BlockTableRecord then Import from _sourceFileName
        Return importBlockFromSourceFile(_sourceFileName, _blockName)
    End Function
    Shared Function importBlockFromSourceFile(_sourceFileName As String, _blockName As String) As ObjectId
        Dim sourceDb As New Database(False, True)
        Dim acObjIdColl As ObjectIdCollection = New ObjectIdCollection()
        ' Read the DWG into a side database
        sourceDb.ReadDwgFile(_sourceFileName, System.IO.FileShare.Read, True, "")
        Using acTrans As Transaction = sourceDb.TransactionManager.StartTransaction()
            ' Open the block table
            Dim bt As BlockTable = DirectCast(acTrans.GetObject(sourceDb.BlockTableId, OpenMode.ForRead, False), BlockTable)
            If bt.Has(_blockName) Then
                acObjIdColl.Add(bt(_blockName))
                'SendCommandMessage(vbCrLf & "Imported block: '" & _blockName & "' from '" & _sourceFileName & "'" & vbCrLf)
            End If
            '' Check each block in the block table
            'For Each btrId As ObjectId In bt
            '    Dim btr As BlockTableRecord = DirectCast(acTrans.GetObject(btrId, OpenMode.ForRead, False), BlockTableRecord)
            '    If btr.Name = _blockName Then
            '        acObjIdColl.Add(btr.ObjectId)
            '        SendCommandMessage(vbCrLf & "Importing block: " & btr.Name)
            '    End If
            '    btr.Dispose()
            'Next
        End Using
        ' Lock the document
            Using acTrans = acDoc.TransactionManager.StartTransaction()
                ' Open the Block table for read
                Dim acBlkTblNewDoc As BlockTable
                acBlkTblNewDoc = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
                ' Open the Block table record Model space for read
                Dim acBlkTblRecNewDoc As BlockTableRecord
                acBlkTblRecNewDoc = acTrans.GetObject(acBlkTblNewDoc(BlockTableRecord.ModelSpace), OpenMode.ForRead)
                ' Clone the objects to the new database
                Dim acIdMap As IdMapping = New IdMapping()
                acCurDb.WblockCloneObjects(acObjIdColl, acBlkTblRecNewDoc.ObjectId, acIdMap, DuplicateRecordCloning.Ignore, False)
                ' Commit the transaction
                acTrans.Commit()
        'Return ObjectId
        Return acObjIdColl(0)
    End Function
Acad.InsertBlock
    Shared Function InsertBlock(ByVal _blockName As String, ByVal insPt As Point3d, ByVal xBlkScale As Double, _
                                ByVal yBlkScale As Double, ByVal zBlkScale As Double, ByVal ang As Double) As BlockReference
        ' Lock the document
                Dim blkTable As BlockTable = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
                If blkTable.Has(_blockName) Then
                    Dim blkObjId As ObjectId = blkTable(_blockName)
                    Dim blkRef As BlockReference = New BlockReference(insPt, blkObjId)
                    blkRef.SetDatabaseDefaults()
                    blkRef.ScaleFactors = New Scale3d(xBlkScale, yBlkScale, zBlkScale)
                    blkRef.Rotation = ang
                    Dim blkTblRec As BlockTableRecord
                    ' Assumes the current space was already changed to.
                    blkTblRec = acTrans.GetObject(acCurDb.CurrentSpaceId, OpenMode.ForWrite)
                    blkTblRec.AppendEntity(blkRef)
                    acTrans.AddNewlyCreatedDBObject(blkRef, True)
                    ' add the attribute definitions.
                    Dim blkTblR As BlockTableRecord = blkObjId.GetObject(OpenMode.ForRead)
                    For Each objId As ObjectId In blkTblR
                        Dim obj As DBObject = objId.GetObject(OpenMode.ForRead)
                        If TypeOf obj Is AttributeDefinition Then
                            Dim ad As AttributeDefinition = objId.GetObject(OpenMode.ForRead)
                            Dim ar As AttributeReference = New AttributeReference()
                            ar.SetAttributeFromBlock(ad, blkRef.BlockTransform)
                            ar.Position = ad.Position.TransformBy(blkRef.BlockTransform)
                            blkRef.AttributeCollection.AppendAttribute(ar)
                            acTrans.AddNewlyCreatedDBObject(ar, True)
                        End If
                    Next
                    acTrans.Commit()
                    Return blkRef
                End If
    End Function
Shared Sub set_DynamicBlockProperties(_blkRef As BlockReference, _attVals As List(Of String))
        ' Get the current document and database, and start a transaction
        ' Lock the new document
            ' Start a transaction in the new database
                'Open _blkRef For writing
                _blkRef = DirectCast(acTrans.GetObject(_blkRef.Id, OpenMode.ForWrite), BlockReference)
                For Each dynamicProperty As DynamicBlockReferenceProperty In _blkRef.DynamicBlockReferencePropertyCollection
                    Dim recievedValue As String = get_AttVal(dynamicProperty.PropertyName, _attVals)
                    If Not String.IsNullOrEmpty(recievedValue) Then
                        If is_DynamicValueAllowed(recievedValue, dynamicProperty) Then
                            If IsNumeric(recievedValue) Then
                                dynamicProperty.Value = CDbl(recievedValue)
                            Else
                                dynamicProperty.Value = recievedValue
                            End If
                        Else
                            MsgBox("Voor DynamicBlock '" & _blkRef.Name & "'" & _
                                   " werd voor property '" & dynamicProperty.PropertyName & "'" & _
                                   " getracht de niet-toegestane waarde '" & recievedValue & "' mee te geven." & _
                                   vbLf & vbLf & _
                                   "Gelieve dit te controleren !", vbOKOnly + MsgBoxStyle.Exclamation)
                        End If
                    End If
                Next
                acTrans.Commit()
    End Sub
    Shared Sub set_BlockAttributes(_blkRef As BlockReference, _attVals As List(Of String))
                Dim attCol As AttributeCollection = _blkRef.AttributeCollection
                For Each attId As ObjectId In attCol
                    Dim attRef As AttributeReference = DirectCast(acTrans.GetObject(attId, OpenMode.ForWrite), AttributeReference)
                    Dim recievedValue As String = get_AttVal(attRef.Tag, _attVals)
                    If Not String.IsNullOrEmpty(recievedValue) Then attRef.TextString = recievedValue
                Next
                acTrans.Commit()
    End Sub
I'm not taking any credit for the above code. None of it is completely compy-pasted, neighter is it completely written by hand.
Step 2) Traverse inserted blocks :
I've made a collection of all BlockReferences in the 'Sketch'-layer and now i want to evaluate them, and take action based on their name
       'Perform individual convertion per block in the SketchBlocksCollection, based on it's type (Name)
        For Each acSketchBlockRef As BlockReference In SketchBlocksCollection
            Select Case acSketchBlockRef.Name
                Case "SketchHoekBlock V"
                    convert_Corner_vertical(acSketchBlockRef, SketchBlocksCollection)
                Case "SketchVloerBlock"
                    Dim MaxUsedFloorPanelLenght = convert_Floor(acSketchBlockRef, SketchBlocksCollection, SketchConversionSettings, sketchOrigins, MaxUsedLength)
                    MaxUsedLength = Math.Max(MaxUsedLength, MaxUsedFloorPanelLenght)
                Case "SketchPlafondBlock"
                    Dim MaxUsedCielingPanelLenght = convert_Cieling(acSketchBlockRef, SketchBlocksCollection, SketchConversionSettings, sketchOrigins, MaxUsedLength)
                    MaxUsedLength = Math.Max(MaxUsedLength, MaxUsedCielingPanelLenght)
                Case "SketchPaneelBlock"
                    convert_Wall(acSketchBlockRef, SketchBlocksCollection, SketchConversionSettings, SketchHorizontalCornerBlocksCollection, SketchDeurBlocksCollection)
                [b]Case "SketchDraaiDeurBlock", "SketchDraaiDeurDubbelBlock", "SketchSchuifDeurBlock"[/b]
                    convert_Door(acSketchBlockRef) 'code never reached
                Case "SketchVBNBlock"
                    convert_VBN(acSketchBlockRef, SketchConversionSettings, sketchOrigins)
                Case Else
            End Select
        Next acSketchBlockRef
Here it goes wrong: the
is never met. As all blocks with these 'names' are Dynamic Blocks.
Thus acSketchBlockRef.Name evaluates to (example) "*U24", not "SketchDraaiDeurBlock".
I tried this :
            Select Case[b] EffectiveName(acSketchBlockRef)[/b]
                Case Else
            End Select
with the method 'EffectiveName' beeing :
        Else
            Return blkref.Name
        End If
End Function
But here, blkref.IsDynamicBlock allways returns false.
pfew  :| that was a mouthfull !
Any Ideas ?
« Last Edit: September 03, 2013, 10:26:06 AM by Bert »
WILL HATCH
« Reply #3 on: September 03, 2013, 03:17:40 PM »
A quick note, in your importBlockFromSourceFile() function you should create the side database in a using variable so you don't need to worry about its disposal (which you didn't do)
Regarding the problem you're having, could you show me what you're doing to create the SketchBlocksCollection you're iterating through?
n.yuan
« Reply #4 on: September 03, 2013, 03:39:22 PM »
Well, only the code you showed in "step 2" is relevant to the issue (the For Each ...Next with Select Case... in it). However, you did not show the whole context where the For Each...Next is in.
The For Each... Next would only works if it is in a Transaction scope and the blockreference in SketchBlockCollection in obtained within the transaction scope, something like this:
''somewhere you may have code like this to build your blockrerefence collection
Public Function GetSketchBlocks() As List of BlockReference
    blocks As List of Blockreference=New ....
    ''You probably used one of the Editor.SelectXXX() methos
    Using tran As Transaction=MyDb.TransactionManager.StartTransaction()
        ''Obtain Blockrefernce objects and add to StechBlockCollection here
        blocks.Add(tran.GetObject(.....)
        tran.Commit()
    End Using
    Return blocks
End Function
''Then you can run the For Each ... here
''At this stage, the Blockreference object is out of the transaction scope where it is obtained
''Therefore some properties are lost (such as IsDynamicBlock)
For Each blk As Blockreference in SketchCollection
    Select Case EffectiveName().ToUpper()
    End Select
Next
For that code structure, you probably thought that you'd better to make the code for gathering BlockReference into a collection in a separate method, so it could be reused somewhere else, like
End Function
This is when the problem arise: you need a transaction to turn selected ObjectId into BlockReference in order to place them into the collection. And at the end of the method, the transaction is completed, and you pass DBObject(s) (BlockReference, in this case) to other methods for further processing. Then you have problem as I pointed out in previous reply: you should pass around ObjectId, instead of DBObject, and only access DBObject's properties in current transaction when needed.
So, you should have a method like this:
Public Function GetSketchBlocks() As ObjectIdCollection
'' Only returns ObjectId or a collection of ObjectId for other process to reuse this code
End Function
And in the place where you need to read BlockReference' properties, you do
''Get selelcted blocks as a collection of ObjectId, instead of DBObject
SktechBlocks=GetSketchBlocks()
''Loop through the ObjectId in a transaction
Using tran As Transaction=....()
  For Each id As ObjectId in SketchBlockCollection
    Dim BlkRef As BlockReference = tran.GetObject(id,...)
    Select Case EffectiveName(blkReg)
    End Select
  Next
  tran.Commit()
End Using
Bert
« Reply #5 on: September 03, 2013, 04:39:10 PM »
That makes hell'of lotsa  sense !
I'm not @work anymore, but home now. I will re-do my code as you stated.
You're right, I do collect my SketchBlocks (Blockrefs) via a function that returns a  'blockref-collection'.
It's called 'collect_SketchBlocks' (or something like it, don't have it on me here)
and it just crawls the ModelSpace for Blockrefs that has 'SKETCH' as their layer, and when found adds them to the collection.
when done, ... it closes the transaction it was using.
Never tought that would be giving me this trouble ..
if I understand correctly i'll have to create the collection,
                                                        traverse trough it and
                                                        perform the needed actions
all under the eye of a 1 single transaction ?
I'm allready knee-deep in AutoCAD .NET api for weeks, and have done alot of nifty stuff.
Yet i still feel i've got lots to learn and sometimes i'm missing out on some key concepts.  :-o  :-(
.Net specific documentation i find to be very superficial.
I'll report back within 10hours with my findings !
Thanks for the pointers !
WILL HATCH
« Reply #6 on: September 03, 2013, 05:26:45 PM »
If you like to maintain per function transaction then you will need to wrap the subroutine call inside a transaction to keep the objects opened or pass ObjectIds around.  If a transaction is absolutely required I like to use the top transaction from within the subroutine:
Function main()
Using Transaction tr = db.TransactionManager.StartTransaction()
Dim DbObjectCollection blocks = get_blocks(db)
sort_blocks(blocks)
End Using
End Function
Function get_Blocks(db As Database) As DbObjectCollection
Dim Transaction tr = db.TransactionManager.TopTransaction
If tr == null Then throw new ArgumentNullException( "Function called outside the scope of transaction" )
...get blocks
End Function
Jeff H
« Reply #7 on: September 03, 2013, 06:55:51 PM »
Looking quickly and too hard to follow, but do not see how your InsertBlock function works.
Looks like you create and add it to transaction then commit the transaction which would close the object then return the blockreference, and do not see that it is in a nested transaction to pass it up to.
mohnston
  • CAD Programmer
« Reply #8 on: September 04, 2013, 12:49:30 AM »
What happens if you pass the blockReference byRef instead of byVal?
CAD Programming Solutions
Bert
« Reply #9 on: September 04, 2013, 02:16:27 AM »
I do, as I never realised this would be a problem.
I'm using a seperate *new* transaction each time I need to dig in. (Insert entities, edit Blocks, move things about)
Virtually every method I wrote in my code holds its 'own' transaction.
I understand very well how closing a transaction could pose a problem further down the line.
Will use this approach.
In my defense, or in that of my code: Everything did work as designed tough !
If it was not for that check (.IsDynamic) that kept failing, i'd never be any wiser.
All other functionality actually worked (insertion, attributes, transformation and erasing 'regular' Blocks)
I'll adress to it now, will report back !
Thank you
Bert
« Reply #10 on: September 04, 2013, 02:24:51 AM »
I assume that following code-example works identically as what WILL HATCH suggests ?
(It involves passing the 'active' transaction trough an argument)
Function main()
Dim DbObjectCollection blocks = get_blocks(db, tr)
sort_blocks(blocks)
End Using
End Function
Function get_Blocks(db As Database, tr as Transaction) As DbObjectCollection
...get blocks
End Function
Then again, adepting every method that uses a transaction to recieve a transaction via argument might not be so desireable.
*EDIT*
I obviously ment :
*/EDIT*
looks more acceptable
« Last Edit: September 04, 2013, 04:08:05 AM by Bert »
Jeff H
« Reply #11 on: September 04, 2013, 03:45:10 AM »
First off
Welcome to the Swamp Bert!
Are you using a vertical because I remember Will was using MEP or maybe something different but he figured out it would create a Transaction for each Custom Command.
Also Any method that requires or you want to use a transaction does not need to pass around a transaction.
If you step back and look there are only so many entry points AutoCAD will execute your code.
-Initialize
-Command
-Events
-Overrule
-etc...
And can change how it needs to be handled.
And if not paying attention using nested or numerous transactions you can only have data partially changed.
Need to get some sleep but when get a better idea of requirements someone can help refactoring code, and how you can wrap methods inside one transaction.
Bert
« Reply #12 on: September 04, 2013, 09:44:11 AM »
Thanks for the welcome Jeff !
What do you mean with me using a 'vertical' ?
As stated my code was realy overdue for some refactoring.
I followed WILL HATCH's advice, keeping all my operations in 1 transaction.
This took some work, but the results are as follows :
Sub Main()
        ' Lock the document
                Call function1()
                dim obj as DbObject = function2()
                If TypeOf (obj) Is BlockReference Then
                      Call function3(obj)
                end if
                ' Save the changes
                acTrans.Commit()
            End Using ' Transaction
        End Using ' Lock
End Sub
Function method1()
        Dim acTrans As Transaction = db.TransactionManager.TopTransaction
        End If
End Function
Function method2() as DBObject
        Dim pPtOpts As PromptEntityOptions = New PromptEntityOptions("")
        ' Prompt for the start point
        pPtOpts.Message = vbLf & _prompt
        pPtOpts.AllowNone = False
        Dim pPtRes As PromptEntityResult = acDoc.Editor.GetEntity(pPtOpts)
        ' Exit if the user presses ESC or cancels the command
        If pPtRes.Status = PromptStatus.Cancel Then Return Nothing
        Return acTrans.GetObject(pPtRes.ObjectId, OpenMode.ForRead)
End Function
sub method3(_blkRef as BlockReference)
        Next
End sub
Currently I'm having troubles with quite the opposite of managing numerous transactions, managing a single transaction :
I'm dodging the following error left & right :
"Operation is not valid due to the current state of the object."
I've got code wanting to open ForRead on an object that apperently allready got opened ForRead/Write earlier in the same Transaction.
Maybe i'm making this way to complex ?
Jeff H
« Reply #13 on: September 04, 2013, 10:25:12 AM »
By vertical I mean
Civil3D, Autocad Arch, AutoCAD MEP, etc.... A product that adds to or extends AutoCAD.
Got to get a job out but will post something later or someone else will post something better.
Bert
« Reply #14 on: September 04, 2013, 10:35:58 AM »
Nope, i'm writing .NET in a 100% pure AutoCAD backdrop.
Replacing 400 pages of VBA-code I wrote over the past 5 years for the company I work for. (don't ask  :-D)
