Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
CAD Forums
Vertically Challenged
Land Lubber / Geographically Positioned
Topic:
Arc by two points tangent to a line?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Arc by two points tangent to a line? (Read 3151 times)
surveyor_randy
Guest
on:
August 26, 2013, 04:24:11 PM »
Good afternoon all,
I'm trying to clean up some linework that the crews brought in. Typically, they shoot the PC of an arc, a point on the arc and then the end of the arc. But 9 out of 10 times, they don't get the PC quite right and the linework looks crappy and I go in and fix it by hand. I was trying to do this today and noticed that when I use the standard 3 point arc command, it won't let me snap tangent to the tangent line coming into the arc. Is there any lisp of C3D routine that will let me draw an arc through two points and tangent to a line? Thanks in advance for any suggestions. Right now, I'm just snapping nearest on the line and kinda "eyeballing" it in there. I'd like to have proper geometry though! You know how surveyors get about geometry!
Logged
danallen
Guest
Re: Arc by two points tangent to a line?
Reply #1 on:
August 26, 2013, 07:24:25 PM »
Try redrawing the line, then start arc command immediately after, hitting enter for 1st point, it should use the just created line for a tangent.
Dan
Logged
surveyor_randy
Guest
Reply #2 on:
August 27, 2013, 08:07:08 AM »
danallen, thanks for the reply. This was actually an Autocad question and I posted this in the Carlson forum accidently. Mods, could you please move this to "Land Lubber"? Thanks!
Logged
Dent Cermak
Guest
Reply #3 on:
August 29, 2013, 03:42:49 PM »
Same solution for either Carlson or AutoCad: Draw Arc by Start,End,Direction will work for what you want.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
CAD Forums
Topic:
