I don't use the ribbon but does anyone have problems w/ nextfiberworld=1 and the ribbon?
Trying that code snippet with 2013 and 64bit I get the new drawing name for last 2 message boxes
nextfiberworld=1 and it works.Even loading Will's dll works.I thought you only had to set that to debug while using windows forms.I don't use the ribbon but does anyone have problems w/ nextfiberworld=1 and the ribbon?
I'll try test that tonight.I have to press escape sometimes to work in a dwg I have just opened.So perhaps that is part of the fiber thing.Interesting to me is that Will's dll loaded no matter what the fiber setting was after I had initially changed the setting.
Changed Fiberworld = 1, the active drawing is now shown correctly.
Quote from: Jeff_M on October 15, 2013, 05:26:14 PMChanged Fiberworld = 1, the active drawing is now shown correctly.Can you confirm you restarted autocad after making the change?
