Good morning,
I am experiencing a weird anomaly. I have 2 separate drawings showing the same window mullion (Drawing A and Drawing B). On drawing A, the lines are visually thicker and drawing B they are thin. Now, in both drawings A & B the mullion is on the same layer with the same line-weight thickness (properties). I want to know why they show up differently.... The LWDISPLAY is turned OFF in both drawings A & B but as you can see in Drawing A the mullion is visually showing the lineweight as it is in the layer properties..... This is where is gets weird... If I go into Drawing A and turn ON the LWDISPLAY and then turn it OFF, then the lines change from being thick to thin but as soon as I pan or zoom, the thick lines show up immediately. Now, if I go into Drawing B and turn ON or OFF multiple times using the LWDISPLAY command nothing happens. I can turn it ON and OFF and nothing happens at all. I did a System Variable Dump from both drawings to compare and there is nothing. Does anyone have any idea why this is occurring? Or am I just having a brain fart.... I am using AutoCAD 2012
