Hello,
I use this method to scale a block reference:
Private Function SetBlockScaleFactor(cur_scl As Double, ByRef cur_block_ref As Autodesk.AutoCAD.DatabaseServices.BlockReference) As Double
cur_block_ref.ScaleFactors = New Autodesk.AutoCAD.Geometry.Scale3d(cur_scl)
End Function
However, I'd like to know if there is a method in VB.Net ObjectARX that scales a block reference by using a base point as an argument.
Thanks,
cannorth
