Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
Topic:
ReadOnly Drawing
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: ReadOnly Drawing (Read 2147 times)
TJK44
Guest
ReadOnly Drawing
on:
August 16, 2013, 11:21:53 AM »
Is it possible to make a drawing ReadOnly except for the creator of the drawing?
Logged
dgorsman
Water Moccasin
Re: ReadOnly Drawing
Reply #1 on:
August 16, 2013, 12:30:58 PM »
Everywhere? Password protection is the only thing that springs to mind outside of CADLock (?) which does things to the contents.
In your own system you could roll something together. But how would you identify who the "creator" is? Computer name? User name? What happens if the user name changes, or they get a new computer? Eventually you end up back at some minor variation on the built-in password protection but with a lot more work.
You could also manipulate access rights on the folder location.
Logged
try {GreatPower;}
catch (notResponsible)
{NextTime(PlanAhead);}
finally
{MasterBasics;}
TJK44
Guest
Reply #2 on:
August 16, 2013, 01:23:25 PM »
Thanks dgorsman,
I wasn't sure if AutoCAD had any built-in feature for something like this. It does seem like more of a hassle than what it is worth.
Logged
Gasty
Newt
Reply #3 on:
August 16, 2013, 02:29:31 PM »
The short answer is NO with plain AutoCAD, but you can add a digital signature to a drawing, that permit to know the owner, and any unauthorized change will invalidate the digital signature.
Gaston Nunez
Logged
elliottpd
Guest
Reply #4 on:
August 16, 2013, 04:59:54 PM »
Let them open the drawing Read-Write, then flip it to Read-Only if they are not authorized for editing (whatever your criteria) with .NET code that you run via a DocumentIdle event handler. Something like doc.DowngradeDocOpen(False)
Logged
Jeff H
Needs a day job
Reply #5 on:
August 16, 2013, 05:50:37 PM »
I have not tried it and could get around it easy enough with code but could lock all the layers and add a ObjectOverrule on layers and override close method and check if it is open for write and if so make sure it is still locked.
Logged
--> Donate to TheSwamp <--
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
.NET
Topic:
ReadOnly Drawing
