Author Topic: Loading problem  (Read 5605 times)
One Shot
Loading problem
« on: August 14, 2013, 01:09:23 PM »
Hello all, it has been a log time since I have been on The Swamp.  How is everyone doing?  My question is the following.  I am running Win7 Pro and ADT 2007.  I know that there is a compatibility problem between the two.  I used the Win7 Pro compatibility tool to make it work.  But I am having a problem keeping my lisp routine loading.  I have them loaded already, but every time I open up ADT 2007.  The will not load and I cannot remember how to make them load all the time.  Can someone help me  figure this out please?
Thank you,
Brad
Rob...
Re: Loading problem
« Reply #1 on: August 14, 2013, 01:26:31 PM »
Add them to the start-up suite using the APPLOAD dialog box.
CAD Tech
One Shot
Re: Loading problem
« Reply #2 on: August 14, 2013, 01:33:34 PM »
I did that and they still will not load each time it is open.
Thank you,
Brad
Rob...
Re: Loading problem
« Reply #3 on: August 15, 2013, 01:04:09 PM »
Are they somehow being removed from the startup suite or are they still in there and being loaded?
CAD Tech
dgorsman
Re: Loading problem
« Reply #4 on: August 15, 2013, 02:41:28 PM »
Does ADT use the old "application fixed SDI mode" setting?  I know this has some impact on ACAD.LSP, ACADDOC.LSP, and the ACADLSPASDOC sytem variable for automatic loading.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
