Author Topic: vla-plottoFile using previous parts of printersetup  (Read 1940 times)
CADwiesel
  • Wir machen das Mögliche unmöglich
« on: August 13, 2013, 09:33:17 AM »
Hi there,
im trying to plot layouts into an pdf file while using the 'dwg to pdf.pc3' ant the vla-plottoFile methode.
sometimes there is another printer as default printer set. Now i set the 'dwg to pdf.pc3' as default. and i want to plot the same papersize which was set to the old Printerconfig, but the papersize isnt no more available for the 'dwg to pdf.pc3'.
How can i put all the Papersettings, which worked on the previous Printer to the 'dwg to pdf.pc3'.
If i do this manualy while calling the plot dialog, and i change the Plotter to 'dwg to pdf.pc3' there is an <previous paperformat> in the paperformat pulldown, which i can chose.
I want to do the same while using ActiveX
Many Regards
CADwiesel
Gruß
CADwiesel
Besucht uns im CHAT
