Author Topic: SSV (Save as Same Version)  (Read 3507 times)
Andrea
« on: August 12, 2013, 02:59:56 PM »
Hi all,..
here is a little routine allowing users to prevent saving in another DWG format.
have a good day all.
;;SSV SAVE SAME VERSION v.1 ;;
;;By: Andrea Andreetti 2013-06-01 ;;
;;Allow to save drawing in same version as it was opened. ;;
(defun SSV (_SSVCR / versionlist odn FL NewDefault drawingname) ; Save Same Version
  (if (findfile (setq drawingname (strcat (getvar 'dwgprefix) (getvar 'dwgname))))
      (setq versionlist '(("AC1014" 8) ("AC1015" 12) ("AC1018" 24) ("AC1021" 36) ("AC1024" 48) ("AC1027" 60)))
      (setq odn (open drawingname "r"))
      (setq FL (read-line odn))
      (close odn)
      (if (and
    (setq NewDefault (cadr (assoc (substr FL 1 6) versionlist)))
    (/= _SSVCR (itoa NewDefault))
(setenv "DefaultFormatForSave" (itoa NewDefault))
(defun *SSV_OnSave_Reactor_Start* (call-reactor sci /)
  (if (eq (strcase (car sci)) "QSAVE")
      (SSV (setq SSVCR (getenv "DefaultFormatForSave")))
(defun *SSV_OnSave_Reactor_Ended* (call-reactor sci /)
      (if SSVCR (progn
  (setenv "DefaultFormatForSave" SSVCR)
  (setq SSVCR nil)
;;command WillStart
(if SSV_OnSave_Reactor_Start
    (progn (vlr-remove SSV_OnSave_Reactor_Start)
           (setq SSV_OnSave_Reactor_Start nil)
         (vlr-command-reactor nil
                              '((:vlr-commandWillStart . *SSV_OnSave_Reactor_Start*))
;;command Ended
(if SSV_OnSave_Reactor_Ended
    (progn (vlr-remove SSV_OnSave_Reactor_Ended)
           (setq SSV_OnSave_Reactor_Ended nil)
                              '((:vlr-commandended . *SSV_OnSave_Reactor_Ended*))
;|refrrences
MC0.0 - DWG from Rel. 1.1
AC1.2 - DWG from Rel. 1.2
AC1.4 - DWG from Rel. 1.4
AC1.50 - DWG from Rel. 2.0
AC2.10 - DWG from Rel. 2.10
AC1002 - DWG from Rel. 2.5
AC1003 - DWG from Rel. 2.6
AC1004 - DWG from Rel.9
AC1006 - DWG from Rel.10
AC1009 - DWG from Rel.11/12 (or LT R1/R2)
AC1012 - DWG from Rel.13 (or LT95)
AC1014 8 - DWG from Rel.14, 14.01 (or LT97/LT98)
AC1015 12 - DWG from AutoCAD 2000/2000i/2002 (or LT, Map or relative Desktop version)
AC1018 24 - DWG from AutoCAD 2004/2005/2006 (or other product in the "2004", "2005" or "2006" family)
AC1021 36 - DWG from AutoCAD 2007/2008/2009 (or other product of the "2007", "2008" and "2009" families)
AC1024 48 - DWG from AutoCAD 2010/2011/2012 (or other product of the "2010", "2011" and "2012" families)
AC1027 60 - DWG from AutoCAD 2013/2014 (or other product of the "2013" "2014" family)
(vla-get-SaveAsType
    (vla-get-OpenSave
      (vla-get-preferences
(vlax-get-acad-object)))
« Last Edit: August 14, 2013, 01:14:42 PM by Andrea »
Keep smile...
roy_043
  • BricsCAD 18
Re: SSV (Save as Same Version)
« Reply #1 on: August 13, 2013, 05:06:06 AM »
Maybe there is a copy-paste error here:
    nil
    '((:vlr-commandWillStart . *SSV_OnSave_Reactor_Ended*)) ; <<< error?
It seems wise to also handle :vlr-commandcancelled and :vlr-commandfailed?
« Last Edit: August 13, 2013, 05:13:52 AM by roy_043 »
roy_043
  • BricsCAD 18
« Reply #2 on: August 13, 2013, 05:09:42 AM »
... Although it is unlikely that QSAVE is ever cancelled.
« Reply #3 on: August 13, 2013, 06:38:56 AM »
An original idea Andrea - thank you for sharing  :-)
You are welcome to use ideas from this simple function to account for other drawing formats, such as DXF  :-)
Andrea
« Reply #4 on: August 13, 2013, 09:24:18 AM »
    nil
Hi Roy,..thank you for your feedback..
may you explain what the error is ?
vlr-commandfailed will be added.
thank you.
Keep smile...
Andrea
« Reply #5 on: August 13, 2013, 09:31:56 AM »
thanks for the Link Lee.. :)
I'm using..
(vla-get-SaveAsType
    (vla-get-OpenSave
who work also for DXF. :P
by the way,...you'r website is one of the best reference site.
nice work Lee.
Keep smile...
« Reply #6 on: August 13, 2013, 09:40:58 AM »
I'm using..
Sorry, I meant to determine the current version of the active drawing file, whether it be dwg/dws/dwt/dxf  :wink:
by the way,...your website is one of the best reference site.
nice work Lee.
Many thanks Andrea!
That means a great deal coming from you, I appreciate your kind feedback  :-)
roy_043
  • BricsCAD 18
« Reply #7 on: August 14, 2013, 03:00:25 AM »
... may you explain what the error is ?
    nil
    '((:vlr-commandWillStart . *SSV_OnSave_Reactor_Ended*)) ; <<< Error?: should be :vlr-commandended
Andrea
« Reply #8 on: August 14, 2013, 01:14:11 PM »
    nil
Oops....:)
thank you.
(bad cut&paste)
Keep smile...
