Author Topic: HATCH AREA TABLE  (Read 5358 times)
Fabricio28
HATCH AREA TABLE
« on: August 09, 2013, 12:12:01 PM »
Hi guys,
I'm trying to create a area table for 2 hatches. I'm using HatchTAble.lsp from Pbe.
But didn't work, I think isn't a hatch.
I've attached the dwg file.
I'd like to know the total area yellow and gray.
(Defun c:HatchTAble ( / AllData ss e edata Area_table crow bn area_ ssNH)
;;; pBe 23Apr2013 ;;;
    (setq AllData nil ssNH (ssadd)
          ss      (ssget '((0 . "Hatch")))
       (repeat (setq i (sslength ss))
         (setq e (vlax-ename->vla-object (ssname ss (Setq i (1- i)))))
         (setq edata
                (list
                  (vlax-get e 'Color)
                  (IF
                    (not
                      (vl-catch-all-error-p
                        (setq area_ (vl-catch-all-apply 'vla-get-area (list E)))
                     area_
                     (progn (ssadd (ssname ss i) ssNH) 0.0)
         (setq AllData
                (if (setq f (assoc (car edata) AllData))
                  (subst (list (car f) (+ (cadr f) (cadr edata))) f Alldata)
                  (cons edata AllData)
       (setq AllData (vl-sort AllData '(lambda (m n) (> (Cadr m) (cadr n)))))
       (setq Area_table
              (vlax-invoke
                (vlax-get (vla-get-ActiveLayout
                          'Block
                'Addtable
                (getpoint "\nPick point for Table:")
                2  2 50 275
       (vla-settext Area_table 0 0 "Area Tabulation")
       (vla-setcelltextheight Area_table 0 0 20.0)
       (mapcar '(lambda (y)
                  (vla-settext Area_table 1 (car y) (cadr y))
                  (vla-setcelltextheight Area_table 1 (car y) 20.0)
               (list '(0 "Area") '(1 "Color"))
       (foreach d AllData
         (vla-insertrows
           Area_table
           (1+ (setq crow (vla-get-rows Area_table)))
           50
           1
         (vla-setCellValue Area_table crow 0 (cadr d))
         (vla-setcelltextheight Area_table crow 0 20.0)
         (vla-setCellAlignment Area_table crow 0 5)
         (vla-setcellformat Area_table crow 0 "%lu2%pr2%th44")
         (if (tblsearch "BLOCK" (setq bn (strcat "Zone " (itoa (Car d)))))
             (vla-setCellType Area_table crow 1 acBlockCell)
             (vla-SetBlockTableRecordId
               Area_table
               crow
               1
               (vla-get-objectID
                 (vla-item
                   (vla-get-blocks
                   bn
               :vlax-true
             (vla-setAutoScale Area_table crow 1 :vlax-false)
             (vla-setBlockScale Area_table crow 1 0.85)
             (vla-setCellAlignment Area_table crow 1 5)
           (princ (Strcat "\nBlock " bn " Not Found"))
       ) (sssetfirst nil ssNH)
Re: HATCH AREA TABLE
« Reply #1 on: August 09, 2013, 12:59:11 PM »
All SOLIDS.
danallen
« Reply #2 on: August 09, 2013, 01:01:50 PM »
All SOLIDS.
convert solids to plines for area calcs
;;; Convert solid to pline, inspired by post:
;;; From: Alex Schamenek (Aschamen@yahoo.com)
;;; Subject: Re: Solid object to Polyline
;;; Newsgroups: autodesk.autocad.customization
;;; Date: 2001-09-18 12:08:28 PST
(defun-q c:Solid2Pline (/ ss i solid pt1 pt2 pt3 pt4 ed dlay)
  (setq ss (ssget '((0 . "SOLID"))))
  (if ss
    (progn (setq i 0)
           (repeat (sslength ss)
             (SETQ Solid  (ssname ss i)
                   pt1 (trans (cdr (assoc 10 (entget solid))) 0 1)
            pt2 (trans (cdr (assoc 11 (entget solid))) 0 1)
            pt3 (trans (cdr (assoc 12 (entget solid))) 0 1)
            pt4 (trans (cdr (assoc 13 (entget solid))) 0 1)
              );SETQ
            (setq ed (entget solid)
                  elay (cdr (assoc 8 ed))
            ) ;_setq
            (setvar "CLAYER" elay)
             (COMMAND "_.PLINE" PT1 PT2 PT4 PT3 "C")
             (command ".erase" solid "")
             (setq i (1+ i))
           ) ;_ repeat
    ) ;_ progn
  ) ;_ if
  (princ (strcat "\n" (itoa i) " Solids converted to LwPolylines"))
) ;_ defun
Fabricio28
« Reply #3 on: August 09, 2013, 01:46:21 PM »
@danallen
Works Perfect!
Many Thanks
I have a question...
All SOLIDS.
SOLIDS isn't a kind of hatch?
danallen
« Reply #4 on: August 09, 2013, 03:28:21 PM »
no, solids are an autocad object just like lines, circles, etc
they can have either 3 or 4 points
jtm2020hyo
« Reply #5 on: March 21, 2019, 05:19:58 PM »
All SOLIDS.
  (if ss
    (progn (setq i 0)
              );SETQ
            ) ;_setq
             (setq i (1+ i))
           ) ;_ repeat
    ) ;_ progn
  ) ;_ if
) ;_ defun
awesome. this work for me.
but what about SOLIDs in NESTED BLOCKS.
