Author Topic: Help Finding Block Route  (Read 27304 times)
« on: August 08, 2013, 12:55:21 PM »
So I'm drawing a blank on how to achieve the following result:
I have an existing route that consists of multiple polylines. There are multiple blocks that reside on this "route". The blocks need to traverse this existing route from their insertion point back to a user defined point.
Could someone help out or at least get me started on the thought process?
Attached is a drawing with a simple scenario.
Re: Help Finding Block Route
« Reply #1 on: August 09, 2013, 08:44:08 AM »
I guess it's not that easy to do.
hmspe
« Reply #2 on: August 09, 2013, 09:35:25 AM »
If I understand what you are trying to do, random thought:
1.  Create a single pline that overlays the existing plines and follows the backbone for its entire length.  Reverse the pline if necessary so that it starts at the correct end.
2.  Use vlax-curve-getClosestPointTo on each block to get the apparent intersection with the working pline, then get the distance along the working pline from the pline start point to the apparent intersection.   Store the data in an array so that the block data and the distance along the working pline are kept together.
3.  Determine if each block is to the left of the working pline, on the pline, or to the right of the pline.  Add to the data set for the block in the array.
4.  Sort  the array based on distance of the apparent intersection from the pline start point, closest to start point first.
5.  Iterate through the array.  For points on the left or on the line offset the pline to the left.  Keep a running counter so you can step the offsets by (N * offset distance).  Drop a line from the block to the offset pline.  Trim out the excess offset pline.  Same process on the right, but with a different counter and offsets to the right.
6.  Do whatever is necessary to clean up at the start point.
« Reply #3 on: August 09, 2013, 11:33:53 AM »
Ron,
I did not follow the explanation of what you are trying to do.  :(
« Reply #4 on: August 09, 2013, 11:41:38 AM »
Charles,
Did you download the drawing ? I'm trying to tally wires (grey lines) that are run from each valve to a controller location, but these wire routes have to follow the shortest predetermined path back (white polyline).
hmspe
« Reply #5 on: August 09, 2013, 01:03:27 PM »
Ron,
What I posted earlier does not account for the pipes that are branches, but the general procedure should work.  Maybe check for tees and use each tee as a start point for a recursive run through the function.  If the diagram has branches off of branches it could get interesting.
Two deadlines today so I can't play with this much.
Martin
« Reply #6 on: August 09, 2013, 01:06:05 PM »
Thanks for the reply Martin. Unfortunately these "networks" can be very complicated and could sometimes contain loops within loops :(.
Perhaps I've bit off more than I can chew. :)
« Reply #7 on: August 09, 2013, 04:56:14 PM »
This reeks of Dijkstra's algorithm...
« Last Edit: August 09, 2013, 04:59:19 PM by Lee Mac »
« Reply #8 on: August 09, 2013, 05:37:41 PM »
Yep, looks like the solution.  ::)
« Reply #9 on: August 10, 2013, 08:49:14 AM »
Thanks guys .. will take a look at it on Monday. Have a nice weekend.
« Reply #10 on: August 10, 2013, 12:28:01 PM »
I don't understand, this:
Seems like a perfectly good response to the question:
Amongst the other responses in the thread. It identifies the problem, a way to solve it and antes up pseudo code to boot.
What's the problem?
ymg
« Reply #11 on: August 10, 2013, 07:11:07 PM »
RonJomp,
Not sure If I follow you, but I believe you are after the Traveling Salesman Problem.
Here is a link  http://cadtips.cadalyst.com/linear-objects/tsp-problem to a routine that appeared
10 years ago in Cadalyst.
Still works ! that's the joy of Lisp.
ymg
« Reply #12 on: August 10, 2013, 10:20:23 PM »
 Just saying that the pseudo code Lee suggested looks like the solution to the problem.
« Reply #13 on: August 10, 2013, 10:35:10 PM »
Guess I just don't understand how you guys use rolling eyes anymore, seemed like the antithesis of a "Nice find Lee" sentiment.
« Reply #14 on: August 11, 2013, 04:50:26 PM »
Yea, I paid no attention to the "Rolling Eyes" but it looks up to Lee's post above mine. At least it does on my browser & settings.
Sorry for the confusion.
