The topic of Pseudo Code just arose and i wanted to share with you some of my "syntax" for Pseudo code.
I wanted to give an example too so im gonna include a small project i was working on. (Well i started it and didnt get a chance to look at it since, but you get my point.) Take a look at the header and you'll get an idea about how i go about starting a code project. (I try to do this for all my projects but im not perfect.)
Pardon the spelling mistakes. (Spelling is not a priority when i do this.)
;;; C H A N G E L A Y E R C O L O R ;
;;; Project: Change layer color of selected item. ;
;;; Date: 03.15.05 ;
;;; Author: John (Se7en) K. ;
;;; Notes: This is for a guy in my office. He "sets up" the ;
;;; drawings in the office. This was a request. ;
;;; Symbol Key: ;
;;; * = Subject. ;
;;; - = Topic. ;
;;; ~ = Note or thing(s) to be aware of. (Conditional) ;
;;; [ = Begin loop ;
;;; ] = End loop ;
;;; } = A reference or an example to help defign my thoughts. ;
;;; Pseudo code: ;
;;; ** User interaction. ** ;
;;; - Get selected item from user. ;
;;; ~ Support for preselected items would be cool. ;
;;; ** Test the environment. ** ;
;;; - Test to see if the item is a block or xref. ;
;;; - Retrieve the layer property from item. ;
;;; ~ If it is a block or xref, get the top level layer prop. ;
;;; - Retrieve the layer property from the Drawing data base. ;
;;; - Test to see if the layer is locked. ;
;;; ~ If the layer is locked, prompt the user and quit. ;
;;; - Retrieve the proposed color for the layer. ;
;;; ** Make proposed changes ** ;
;;; - change the layer color. ;
;;; - update the drawing. (refresh) ;
;;; ** Clean up ** ;
;;; - Done. ;
;;; Begin code development. ;
;;; Selected-p ;
;;; This function will test to see if something is selected on screen ;
;;; Returns: T or nil ;
;;; Author: John Kaul ;
;;; Usage: (if (not (Slected-p)) ;
;;; (vlax-ename->vla-object (car (entsel)))) ;
(defun Slected-p ()
(and (cadr (ssgetfirst))))
;;; Get-Selcted ;
;;; This function will offer a way for the programer to get an ;
;;; entity or entities already slected on the screen before the ;
;;; program took control. This program was intended for use in an ;
;;; ActiveX program. I have chosen not to use the "Pickfirst" method ;
;;; in accomplishing this task because I wanted a way to do this even ;
;;; if the "pickfirst" variable was toggled to zero. If no entity is ;
;;; currently selected on the screen, this function will prompt the ;
;;; end user to select an entity. ;
;;; Returns: Either previously selected entity, a selected entity, or ;
;;; a list of selected entities. ;
;;; Usage: (vlax-ename->vla-object (Get-Selcted)) ;
;;; Version: 1.1 Added the ability to have more then one selected ;
;;; objects on the screen. ;
(defun Get-Selcted (/ x cntr xlength xlist)
(setq x (cadr (ssgetfirst)))
(if x (setq xlength (sslength x)))
((= xlength 1)
(setq x (ssname x 0))
(sssetfirst nil)
(redraw x 3))
((> xlength 1)
(setq cntr xlength)
((>= cntr 2)
(setq cntr (1- xlength))
(while (>= cntr 0)
(setq xlist (cons (ssname x cntr) xlist)
cntr (1- cntr)))
(foreach a xlist (progn (sssetfirst nil) (redraw a 3))))))
((= xlength nil)
(while (not (setq x (entsel "\nselect object: "))))
(setq x (car x))
(sssetfirst nil)
(redraw x 3)))
(if (= nil xlist) x xlist)
;;; ** Test the enviroment. ** ;
;;; block-p ;
;;; test to see of given is a block ;
;;; Returns: Boole ;
;;; Author: John (Se7en) Kaul ;
;;;(defun block-p (x)
;;; (and (caddr (nentselp (cadr x)))))
;;; //-- Status: On hold till validity is verified. --//
;;; Get layer ;
;;; Get the layer of the entity. ;
;;; Returns: String ;
;;; Example: (getlayer (entsel)) ;
;;; > "0" ;
(defun getlayer (x)
(cdr (assoc 8 (entget x))))
;;; Test 1 ;
;;; This is test number one. I am testing to see if I can retrieve ;
;;; an entities layer if it is selected on the screen before my code ;
;;; runs. ;
(defun test1 ()
(getlayer (Get-Selcted)))
