try this:
1 - create a new folder and gives it a name that contains an opening parenthesis.... something like "test(1)"
2 - create a slide with _mslide command. then copy the slide in the folder
3 - call the command _vslide and try to open the slide
an error is generated : "test.slb non found"
also (slide_image) autolisp function don't work !!
autocad recognizes the open parenthesis as to want to specify the name of a library of slides (.slb files)
when you open a slide from a slidelib the syntax is: libraryname(slidename) .
