Author Topic: AutoCAD VSLIDE AND SLIDE_IMAGE BUG  (Read 1796 times)
Vandyck
« on: August 05, 2013, 08:59:52 AM »
try this:
1 - create a new folder and gives it a name that contains an opening parenthesis.... something like "test(1)"
2 - create a slide with _mslide command. then copy the slide in the folder
3 - call the command _vslide  and try to open the slide
an error is generated : "test.slb non found"
also (slide_image) autolisp function don't work !!
autocad recognizes the open parenthesis as to want to specify the name of a library of slides (.slb files)
when you open a slide from a slidelib the syntax is: libraryname(slidename) .
Crank
Re: AutoCAD VSLIDE AND SLIDE_IMAGE BUG
« Reply #1 on: August 10, 2013, 02:20:24 AM »
Parenthesis are not possible because the code of slides was already written in the DOS era.
