Author Topic: DGN Purge for 2012  (Read 27440 times)
BlackBox
Re: DGN Purge for 2012
« Reply #15 on: September 20, 2013, 11:15:08 AM »
Thanks BB, that helps.  Works here as well so far.
Cheers!
You're welcome, Jim; I'm happy to help.
Cheers
rkmcswain
« Reply #16 on: September 30, 2013, 11:02:48 AM »
.....I need to netload it every time I start a new session of autocad. Is there a way to fix this so I only need to load it once?
I'm still old school, so....
;;; LOAD DGN PURGE COMMAND
(if (setq dgnp (findfile "DgnLsPurge.dll"))
  (command "._NETLOAD" dgnp)
 :kewl:
max
« Reply #17 on: February 27, 2015, 05:38:10 AM »
Hi there,
I get a null object ID sometimes in the PurgeLinetypesReferencedNotByAnonBlock Method. The following if clause can fix this:
// If the owner does not belong to an anonymous
// block, then we take it seriously as a reference
// Chek the OwnerId first!
if (ent.OwnerId != ObjectId.Null)
var owner = (BlockTableRecord)tr.GetObject(ent.OwnerId, OpenMode.ForRead);
