Author Topic: Upgrading project from ACAD 2010 to 2013... missing CommandMethod  (Read 2269 times)
Matt__W
  • I like my water diluted.
I'll get straight to the point... My application doesn't recognize the 'CommandMethod' portion.
<Autodesk.AutoCAD.Runtime.CommandMethod("RenumberSSM")>
I have the same references loaded as before (but I'm using the 2013 ones instead of 2010).  What gives??  What can I change and where??  I'm admittedly not the most well-versed in .NET.
Autodesk Expert Elite
Matt__W
Re: Upgrading project from ACAD 2010 to 2013... missing CommandMethod
« Reply #2 on: July 26, 2013, 10:02:37 AM »
Thanks!
