Author Topic: Sorting "nested" attributes by name  (Read 5431 times)
AcDbZombieEntity
  • Mosquito
« on: July 10, 2013, 08:11:47 AM »
i've got here many blocks with many attributes, a lot of them have the same attributes but sorted crazy unique in each block definition.
- Is there any method to "resort" them all with lisp, alphabetical order by name and not the promt or value?
- Is there an way to get battman working with command?
P.S. with out an lost of allready entered values  :evil:
Tharwat
  • Hypersensitive
Re: Sorting "nested" attributes by name
« Reply #1 on: July 10, 2013, 08:28:30 AM »
e.g .
(setq l '("c" "e" "d" "a" "f" "b"))
(acad_strlsort l)
cadplayer
  • Autocad Civil3d, OpenDCL.Runtime, LISP, .NET (C#)
« Reply #2 on: July 10, 2013, 08:51:34 AM »
Are you meaning tagname from attributdefinition you would like sort. Do you want rebuild a block with attributes.
Another way without lisp is, you take a copy of block, explode them and than use command attredef and you can by clicking on attdef byself choice direction which attdef should be sort.
It΄s a bit difficult to do that with lisp, you need a function which sort all tagnames from attdef and than you have to entmod them. I΄m not sure if it΄s the best way.
irneb
« Reply #3 on: July 10, 2013, 09:24:30 AM »
I don't think the BAttMan options are available to Lisp.
The "simplest" method would be for the lisp to recreate the block definition using the BLOCK command, but select the attdef's in the correct order:
  • Insert a temporary block
  • Explode it
  • Select previous
  • Remove all attdef objects from that selection set and add them to a list
  • Sort the list on the attributes' tag names
  • Add them back in order using ssadd
  • Recreate the block, overwriting the old definition
  • Run attsync to update all the existing block references to the same attribute order
  • Erase the temporary block
Repeat the process for each block definition.
« Reply #4 on: July 10, 2013, 09:38:46 AM »
However, this method would not work for attributed dynamic blocks.
Try the following:
  1. ;; Sort Tags  -  Lee Mac
  2. (defun c:sorttags ( / cmd lst )
  3.         (if
  4.             (and
  5.                 (= :vlax-false (vla-get-isxref blk))
  6.                 (= :vlax-false (vla-get-islayout blk))
  7.             )
  8.             (progn
  9.                 (vlax-for obj blk
  10.                     (if (= "AcDbAttributeDefinition" (vla-get-objectname obj))
  11.                         (setq lst (cons obj lst))
  12.                     )
  13.                 )
  14.                 (foreach att (vl-sort lst '(lambda ( a b ) (< (vla-get-tagstring a) (vla-get-tagstring b))))
  15.                     (vla-copy   att)
  16.                     (vla-delete att)
  17.                 )
  18.                 (setq lst nil)
  19.             )
  20.         )
  21.     )
  22.     (setq cmd (getvar 'cmdecho))
  23.     (setvar 'cmdecho 0)
  24.     (vl-cmdf "_.attsync" "_N" "*")
  25.     (setvar 'cmdecho cmd)
  26.     (princ)
  27. )
AcDbZombieEntity
  • Mosquito
« Reply #5 on: July 10, 2013, 10:09:57 AM »
Awesome Lee, thanks a lot. learned something new with
                   (vla-copy   att)
                   (vla-delete att)
« Reply #6 on: July 10, 2013, 10:16:03 AM »
You're very welcome.
Great username BTW  :-P
« Reply #7 on: July 10, 2013, 01:45:16 PM »
Welcome to the swamp brother zombie!
alanjt
  • Standby for witty remark...
« Reply #8 on: July 11, 2013, 04:44:30 PM »
                   (vla-copy   att)
                   (vla-delete att)
 :kewl:
Dropbox
« Reply #9 on: July 11, 2013, 07:43:00 PM »
                   (vla-copy   att)
                   (vla-delete att)
 :kewl:
