Author Topic: Commercial Tools for. NET  (Read 11200 times)
exmachina
« on: July 01, 2013, 03:03:18 PM »
I do not like to "advertise" commercial tools, but I think this information may be useful to some users
« Last Edit: July 01, 2013, 04:09:00 PM by whoknows »
exmachina
Xamarin
« Reply #1 on: July 01, 2013, 03:08:11 PM »
"Easily" create apps in C# for iOS, Android and Mac
Home:
http://xamarin.com/
Note:
For Mac development (in windows) we need a virtual machine running Mac OS + Xcode
exmachina
Postsharp
« Reply #2 on: July 01, 2013, 03:09:38 PM »
Design Pattern Automation for .NET
Home:
http://www.postsharp.net/
exmachina
LINQPad (freeware/ commercial)
« Reply #3 on: July 01, 2013, 03:14:58 PM »
LINQPad lets you interactively query databases in LINQ
Note:
autocompletion is only included in the commercial version
Home:
http://www.linqpad.net/
exmachina
Devart LINQ Insight
« Reply #4 on: July 01, 2013, 03:17:48 PM »
LINQ Insight is a Visual Studio add-in that provides a complete set of tools that make LINQ/ORM development faster and easier, and helps you to produce more efficient data access code. It allows executing LINQ queries at design-time directly from Visual Studio without starting a debug session, allowing you to test queries instantly after you write them. LINQ Insight also provides a powerful ORM profiler tool for profiling the data access layer of your projects and tracking all the ORM calls and database queries from the ORM.
Home:
http://www.devart.com/linqinsight/
exmachina
Devart dotConnect Universal
« Reply #5 on: July 01, 2013, 03:21:44 PM »
dotConnect Universal offers universal access to data of different databases for the Microsoft .NET Framework. It supports most of major database servers, including Microsoft SQL Server, Microsoft Access, Oracle, DB2, MySQL, PostgreSQL, SQLite, InterBase, and Firebird. Other servers can be accessed through their ADO.NET, OLE DB and ODBC providers.
dotConnect Universal is based on ADO.NET technology and can be used in the same way as the SQL Server .NET Data Provider. The main feature of dotConnect Universal is an access to multiple database servers at the same code. With dotConnect Universal it is possible to avoid writing conditional code for different providers or using ADO.NET interfaces directly. dotConnect Universal implements full support of design-time development and integration with IDE, which allows to reduce development time greatly.
Home:
http://www.devart.com/dotconnect/universal/
Note:
I've tried it and it works fine
exmachina
Devart Entity Developer
« Reply #6 on: July 01, 2013, 03:26:42 PM »
Entity Developer is a powerful ORM modeling and code generation tool for NHibernate, ADO.NET Entity Framework, LinqConnect, and LINQ to SQL. You can use Model-First and Database-First approaches to design your model and generate C# or Visual Basic .NET code for it. It introduces new approaches for designing ORM models, boosts productivity, and facilitates the development of database applications.
Home:
http://www.devart.com/entitydeveloper/
Note:
Works very well with EF, I have not tried others
exmachina
LLBLGen Pro)
« Reply #7 on: July 01, 2013, 03:34:20 PM »
LLBLGen Pro is a data-access solution.
You use the LLBLGen Pro Designer to create the entity/domain model, define the mappings and generate source-code for one of the four supported O/R mapping frameworks: Entity Framework, NHibernate, Linq to SQL or the LLBLGen Pro Runtime Framework.
You use the generated code combined with the O/R mapping framework of your choice to access your database and consume the data in that database.
Home:
http://www.llblgen.com/
Note
Some developers say that the LLBLGen Pro Runtime Framework is the best ORM, and surely they are right, but to create EF models I think it's better Devart Entity developer
exmachina
Code on Time
« Reply #8 on: July 01, 2013, 03:42:52 PM »
Code On Time web application generator will create advanced web apps straight from your database. These web applications are rich with features, such as adaptive filtering, search bars, reporting, charts, and data sheet view. All you need is a database, and you can impress your customers and peers in a few short minutes.
Your enterprise-class web app will be ready for immediate deployment to your own server, shared, or dedicated hosting provider. You can even deploy directly to the cloud.
Home:
http://codeontime.com/
exmachina
Codesmith
« Reply #9 on: July 01, 2013, 03:54:11 PM »
Template-based code generator that can generate code for any ASCII-based language
Home:
http://www.codesmithtools.com/
I do not know how to use this tool, but developers says it is an exceptional tool
Tomorrow more...
exmachina
Re: Commercial Tools for. NET
« Reply #10 on: August 31, 2013, 12:46:54 AM »
SmartInspect
- Advanced High-Performance Logging and Tracing for .NET, Java and Delphi
- Identify and fix software bugs faster
- Monitor and analyze applications in real-time
- Find solutions to user-reported issues
- Debug production systems while they run[/li][/list]
Very good logging software for .NET  & Delphi
Home:
http://www.gurock.com/smartinspect/
exmachina
« Reply #11 on: August 31, 2013, 12:49:10 AM »
Entity Framework Profiler
Real-time visual debugger allowing a development team to gain valuable insight and perspective into their usage of Entity Framework. The product is architected with input coming from many top industry leaders within the OR/M community. Alerts are presented in a concise code-review manner indicating patterns of misuse by your application. To streamline your efforts to correct the misuse, we provide links to the problematic code section that triggered the alert.
Home:
http://www.hibernatingrhinos.com/products/EFProf
exmachina
« Reply #12 on: August 31, 2013, 12:53:12 AM »
NHibernate Profiler
Real-time visual debugger allowing a development team to gain valuable insight and perspective into their usage of NHibernate. The product is architected with input coming from many top industry leaders within the NHibernate community. Alerts are presented in a concise code-review manner indicating patterns of misuse by your application. To streamline your efforts to correct the misuse, we provide links to the problematic code section that triggered the alert.
This and the previous are Silverlight‎ app's, very bad idea, they could be much more efficient...
Home:
http://www.hibernatingrhinos.com/products/NHProf
exmachina
« Reply #13 on: August 31, 2013, 12:54:30 AM »
ORM Profiler
O/R mapper frameworks supported: Any DbProviderFactory using O/R mapper / data-access layer, like: LLBLGen Pro Runtime Framework 3.x, Entity Framework v1, Entity Framework v4.x, Entity Framework v5.x, Dapper.net, Massive, SubSonic, Microsoft.Data (WebMatrix)
Home:
exmachina
« Reply #14 on: August 31, 2013, 12:57:39 AM »
Intersoft WebUI Studio
Introducing WebUI Studio 2012 Premier® edition, expertly designed for the most complex enterprise-level web development requirements. Now featuring over 370 advanced presentation-layer components for ASP.NET, Silverlight, and WPF in one box, WebUI Studio 2012 Premier is the ultimate toolset for building dynamic and powerful next-generation Rich Internet Applications.
From interactive Customer Relationship Management applications to integrated Enterprise Resource Planning systems; from online stock trading to global equipment applications, WebUI Studio Premier defies web development challenges without compromise. Its cutting-edge technologies and remarkable innovations power robust applications like Volvo’s online truck management application and Italy’s hospital supply management system.
Very good.
Home:
http://www.intersoftpt.com/WebUIStudio/
