Author Topic: Block Creation based on TXT File  (Read 1737 times)
ChrisCarlson
« on: July 01, 2013, 11:55:24 AM »
Hitting writers block here, my lisp will only create the 50th line or what ever line is set in the (repeat n ) function. I have approximately 1500~ lines in the text file. Any advice?
;CREATE PART NUMBER BLOCK
(defun C:csvblock (/ pt01)
(if (findfile "e:/lisps/csvblock.txt")
(setq btable (open "e:/lisps/csvblock.txt" "r"))
(repeat 50 (setq partnumber (read-line btable)))
(close btable)
) ; end progn
(alert "FILE NOT FOUND!")
) ; end if
(entmake
(list
(cons 0 "BLOCK") ; entity
(cons 2 partnumber) ; block name
(cons 70 2) ; block type
(list 10 0.0 0.0 0.0) ; base point
) ; end list
) ; end entmake
(entmake
(list
(cons 0 "TEXT") ; entity
(cons 8 "SYS-Bom_Part_Numbers") ; layer
(cons 40 0.035) ; text height
(cons 1 partnumber) ; text string
(cons 50 0)  ; text rotation
; (cons 7 "STANDARD")   ; text style
(cons 72 10) ; text justification
) ; end list
) ; end entmake text
;START ANNOTATIVE / NO EXPLODE SEQUENCE
(entmake
                (list
                    (cons 0 "ENDBLK")
                    (cons 8 "0")
                (entget (cdr (assoc 330 (entget (tblobjname "BLOCK" partnumber)))))
          (setq BLOCKS
          (vla-get-Blocks
           (vla-get-activedocument
            (vlax-get-acad-object)
         BLK (vla-Item BLOCKS partnumber)
      (vla-put-explodable (vla-Item BLOCKS partnumber) :vlax-false)
) ; end function
Re: Block Creation based on TXT File
« Reply #1 on: July 01, 2013, 12:06:48 PM »
Maybe something like this:
(defun c:csvblock (/ _ readfile pt01)
  (defun _readfile (filename / file result line)
    (cond ((and (eq 'str (type filename)) (setq file (open filename "r")))
   (while (setq line (read-line file)) (setq result (cons line result)))
   (close file)
   (reverse result)
  ;; (idt_readfile "c:\\test.csv")
  (if (setq lst (_readfile "e:/lisps/csvblock.txt"))
    (progn (vl-load-com)
   (setq blocks (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))))
   (foreach partnumber lst ; (if (eq (type partnumber) 'STR)
     (entmake (list (cons 0 "BLOCK") ; entity
      ) ; end list
     ) ; end entmake
     (entmake (list (cons 0 "TEXT") ; entity
      ) ; end list
     (entmake (list (cons 0 "ENDBLK") (cons 8 "0")))
     ;; (entget (cdr (assoc 330 (entget (tblobjname "BLOCK" partnumber)))))
     (if (tblobjname "BLOCK" partnumber)
       (vla-put-explodable (vla-item blocks partnumber) :vlax-false)
    ) ; end progn
  ) ; end if
) ; end function
Welcome to theswamp :)
ChrisCarlson
« Reply #2 on: July 01, 2013, 12:10:41 PM »
Had a hunch (while was the way to go.
Thanks a bunch  :kewl:
