Author Topic: Move UCS icon  (Read 1956 times)
MeasureUp
Move UCS icon
« on: June 25, 2013, 02:11:36 AM »
I know that the UCS icon can be dragged from one point to another.
But how to get it work in the code?
For example, I want to move it from (5,10,15) to (100,50,25). Is it possible?
Thanks for your help.
Re: Move UCS icon
« Reply #1 on: June 25, 2013, 02:19:50 AM »
Let's see if I understand ...
What does the UCS Icon Represent ??
Tharwat
  • Hypersensitive
Re: Move UCS icon
« Reply #2 on: June 25, 2013, 02:21:27 AM »
Not that sure , but try this .
If the ucs is located as per origin , try the first one , otherwise the second line of code may do the job .
(command "_.ucs" '(95. 40. 10.) "")
(command "_.ucs" '(100. 500. 25.) "")
MeasureUp
Re: Move UCS icon
« Reply #3 on: June 25, 2013, 09:09:06 PM »
Thanks. It didn't work because I used commas, like:
(command "_.ucs" '(100,500,25) "")
Tharwat
  • Hypersensitive
Re: Move UCS icon
« Reply #4 on: June 26, 2013, 12:08:28 AM »
Not a problem
