Author Topic: ssget function with initget function  (Read 2291 times)
Coder
« on: June 23, 2013, 08:44:58 AM »
Hello Guys .  :-)
Is it possible to use the function ssget with the initget to call a dialog if the user typed d or dialog , otherwise keep the ssget function active to select lines ?
(princ "\n Select Lines or [Dialog] :")
(initget "Dialog")
(if (setq sel (ssget '((0 . "LINE"))))
Thanks in advance .
ribarm
  • Marko Ribar, architect
Re: ssget function with initget function
« Reply #1 on: June 23, 2013, 09:45:39 AM »
What comes to mind, something like this :
(defun c:_sel ( / sel )
  (initget "Dialog")
  (if (eq (getkword "\n Select Lines or [Dialog] :") nil)
      (initdia)
M.R. on Youtube
« Reply #2 on: June 23, 2013, 02:58:44 PM »
Use a subroutine to get the entry & then process as you like.
http://www.theswamp.org/index.php?topic=39042.msg442350#msg442350
« Last Edit: June 24, 2013, 08:01:21 AM by CAB »
Coder
« Reply #3 on: June 24, 2013, 12:57:22 AM »
Thank you ribarm and CAB .
Still not what I am after  :embarrassed:
Lee 's function is a single selection set and I need to get the benefit of the ssget to select many lines .
My goal is to have a function that can do the same like below example but with ssget to be able to select many lines in one shut .
(initget "Dialog")
(if (setq sel (entsel "\n Select Lines or [Dialog] :"))
  (if (eq sel "d")
    (showDialog)
roy_043
  • BricsCAD 18
« Reply #4 on: June 24, 2013, 03:01:16 AM »
  1. (princ "\n Select lines or Enter for dialog :")
  2. (if (setq sel (ssget '((0 . "LINE"))))
  3.   (progn
  4.     ............
  5.   )
  6.   (showDialog)
  7. )
