Author Topic: Trying to Understand Mapcar/Lambda for (if (= x "Y"))  (Read 3473 times)
Bill Tillman
« on: June 19, 2013, 09:03:40 AM »
I have an exercise this morning I'm working on and thought why not make use of the time to learn more about mapcar/lambda.
I have four variables:
front   back   rside  lside
If any of these variables contains the value of "Y" I want to take some action. I've been doing this in the past:
(if (or (= front "Y") (= back "Y") (= rside "Y") (= lside "Y")) (setq a "Y"))
All the mapcar examples I've searched through so far show how to add 1, subtract 2, strcase, etc... How would one run this process through mapcar/lambda to achieve the same results?
Re: Trying to Understand Mapcar/Lambda for (if (= x "Y"))
« Reply #1 on: June 19, 2013, 09:09:24 AM »
You could use vl-some like so:
(and (vl-some '(lambda (x) (= x "Y")) (list front back rside lside)) (setq a "Y"))
irneb
« Reply #2 on: June 19, 2013, 09:20:03 AM »
Ronjonp's is definitely the way to go if you have to use lambda.
If you want to use mapcar as well, you could use the following
  1. (if (apply 'or (mapcar '(lambda (x) (= x "Y")) (list front back rside lside)))
  2.  ;;;;
  3. )
Note though, that I'd not advise this, as it checks through each and every variable even if front is already = "Y". Ronjonp's code will work the same way a normal or would - i.e. only evaluate until a T is returned.
Another alternative would be to use vl-position or member:
  1. ;; Using vl-position
  2. (if (vl-position "Y" (list front back rside lside))
  3.   ;;;;
  4. )
  5.
  6. ;; Or using member
  7. (if (member "Y" (list front back rside lside))
  8.   ;;;;
  9. )
BlackBox
« Reply #4 on: June 19, 2013, 11:22:22 AM »
From a duplicate thread here:
Quote from: BlackBox
Consider:
(setq a
       (car
         (vl-remove-if-not
           (function (lambda (x) (= "Y" x)))
« Reply #5 on: June 19, 2013, 11:45:56 AM »
Here's some more benchmarks :).
;; Y at front of list
    _FOO6.....1453 / 1.05 <fastest>
    _FOO3.....1469 / 1.04
    _FOO5.....1469 / 1.04
    _FOO2.....1484 / 1.03
    _FOO4.....1484 / 1.03
    _FOO1.....1531 / 1.00 <slowest>
;; Y at end of list
    _FOO5.....1141 / 1.34 <fastest>
    _FOO4.....1203 / 1.27
    _FOO6.....1219 / 1.26
    _FOO3.....1297 / 1.18
    _FOO1.....1500 / 1.02
    _FOO2.....1531 / 1.00 <slowest>
(defun _foo1 ()
  (vl-some (function (lambda (v)
             (if (eq (eval v) "Y")
          "Y"
(defun _foo2 ()
  (car (vl-remove-if-not (function (lambda (x) (eq x "Y"))) (list front back rside lside)))
(defun _foo3 nil (vl-some (function (lambda (x) (eq x "Y"))) (list front back rside lside)))
(defun _foo4 nil (vl-position "Y" (list front back rside lside)))
(defun _foo5 nil (member "Y" (list front back rside lside)))
(defun _foo6 nil (or (= front "Y") (= back "Y") (= rside "Y") (= lside "Y")))
(defun _foo7 nil (apply 'or (mapcar '(lambda (x) (= x "Y")) (list front back rside lside))))
(benchmark '(_foo1 _foo2 _foo3 _foo4 _foo5 _foo6))
BlackBox
« Reply #6 on: June 19, 2013, 11:56:22 AM »
... Too bad only _foo1, and _foo2 yield the same returned value as the OP's code as requested.  :-P
« Reply #7 on: June 19, 2013, 12:11:11 PM »
I also missed _foo7 LOL ... Here's new numbers with all functions returning "Y" :P
    _FOO2.....1125 / 1.03 <fastest>
    _FOO4.....1125 / 1.03
    _FOO6.....1125 / 1.03
    _FOO7.....1125 / 1.03
    _FOO5.....1140 / 1.01
    _FOO3.....1141 / 1.01
    _FOO1.....1157 / 1.00 <slowest>
;; Y at end of list
    _FOO7.....1110 / 1.04 <fastest>
    _FOO3.....1125 / 1.03
    _FOO5.....1125 / 1.03
    _FOO6.....1141 / 1.01
    _FOO1.....1156 / 1.00 <slowest>
BlackBox
« Reply #8 on: June 19, 2013, 12:13:17 PM »
  1. ;; Y at front of list
  2.
  3.
  4.     _FOO2.....1125 / 1.03 <fastest>
  5.     _FOO4.....1125 / 1.03
  6.     _FOO6.....1125 / 1.03
  7.     _FOO7.....1125 / 1.03
  8.     _FOO5.....1140 / 1.01
  9.     _FOO3.....1141 / 1.01
  10.     _FOO1.....1157 / 1.00 <slowest>
  11.
  12.
  13. ;; Y at end of list
  14.
  15.
  16.     _FOO7.....1110 / 1.04 <fastest>
  17.     _FOO2.....1125 / 1.03
  18.     _FOO3.....1125 / 1.03
  19.     _FOO4.....1125 / 1.03
  20.     _FOO5.....1125 / 1.03
  21.     _FOO6.....1141 / 1.01
  22.     _FOO1.....1156 / 1.00 <slowest>
First place in round 1, Second in round 2, best overall isn't bad at all... Yay me!  :lol:
irneb
« Reply #9 on: June 19, 2013, 03:03:37 PM »
A bit contrived  :-P, but a recursive member function
  1. (defun member-r (pred lst)
  2.   (cond ((eq pred (car lst)) lst)
  3.         (lst (member-r pred (cdr lst)))))
  4.
  5. (if (member-r "Y" (list front back rside lside))
Probably not too great on speed in comparison to the others.
Anyhow, to answer the OP's "actual" question ... making the sample data to test on shows another reason to use mapcar:
_$ (mapcar 'set '(front back rside lside) '("W" "X" "Y" "Z"))
("W" "X" "Y" "Z")
_$ front
"W"
_$ back
"X"
_$ rside
"Y"
_$ lside
"Z"
That shows what's happening with mapcar. The equivalent (if not using mapcar) would have been:
  1. (list (set 'front "W")
  2.       (set 'back "X")
  3.       (set 'rside "Y")
  4.       (set 'lside "Z"))
Lambda is simply a way of defining a function direct in the position where it's called. E.g. the following is equivalent to RonJonP's code in Post #2:
  1. (defun eq-Y (x)
  2.   (= x "Y"))
  3. (and (vl-some 'eq-Y (list front back rside lside)))
