Author Topic: What the Duck - ForEach, IEnumerable, IEnumerator DuckTyping  (Read 3332 times)
Jeff H
I never knew how much duck typing was going on under hood.
Do not have to implement IEnumerable or IEnumerator.
For a for each loop to work on a object just needs a method called GetEnumerator that returns an Object that has method MoveNext that returns a bool and a property Current that returns any type.
Had it return StreamReader, etc......
Code - C#: [Select]
  1. using System;
  2. using System.Collections.Generic;
  3. using System.Linq;
  4. using System.Text;
  5. using System.Collections;
  6. using System.IO;
  7. namespace WhatTheDuck
  8. {
  9.     class Program
  10.     {
  11.         static void Main(string[] args)
  12.         {
  13.             Duck d = new Duck();
  14.
  15.             foreach(var i in d)
  16.             {
  17.                 Console.WriteLine("{0}{1}{0}", "*Duck*", i);
  18.             }
  19.             Console.ReadLine();
  20.         }
  21.     }
  22.     public class Duck
  23.     {
  24.         public Quack GetEnumerator()
  25.         {
  26.             return new Quack();
  27.         }
  28.
  29.     }
  30.     public class Quack
  31.     {
  32.         static int counter = 0;
  33.         public int Current
  34.         {
  35.             get
  36.             {
  37.                 counter++;
  38.                 Console.WriteLine("*Quack*Current*Quack*");
  39.                 return counter;
  40.                 //return new StreamReader(@"C:\Testing\SSM.txt");
  41.             }
  42.         }
  43.         public bool MoveNext()
  44.         {
  45.             Console.WriteLine("*Quack*MoveNext*Quack*");
  46.             return counter < 10;
  47.         }
  48.         //public void Reset()
  49.         //{
  50.         //    counter = 1;
  51.         //}
  52.     }
  53. }
  54.
  55.
kaefer
Re: What the Duck - ForEach, IEnumerable, IEnumerator DuckTyping
« Reply #1 on: June 18, 2013, 10:58:29 AM »
Me too. But see the C# spec:
The compile-time processing of a foreach statement first determines the collection type, enumerator type and element type of the expression. This determination proceeds as follows:
•    If the type X of expression is an array type then ...
•    If the type X of expression is dynamic then ...
•    Otherwise, determine whether the type X has an appropriate GetEnumerator method:
    o    Perform member lookup on the type X with identifier GetEnumerator and no type arguments. ...
    o    ...
    o    If the return type E of the GetEnumerator method is not a class, struct or interface type, an error is produced and no further steps are taken.
    o    Member lookup is performed on E with the identifier Current and no type arguments. ...
    o    Member lookup is performed on E with the identifier MoveNext and no type arguments. ...
    o     ...
    o    The collection type is X, the enumerator type is E, and the element type is the type of the Current property.
•    Otherwise, check for an enumerable interface:
Jeff H
« Reply #2 on: June 18, 2013, 12:37:41 PM »
Thanks kaefer,
I see all you smart guys refer to the specs and I need to start referring to those more, I just was looking at some MSIL and noticed it was not calling any of the methods through the interface
kaefer
« Reply #3 on: June 18, 2013, 04:53:33 PM »
What would you do if you just know that those methods are there?
Rereading of the material cited does not suggest that the types X (collection type) and E (enumerator type) need to be disjunct. Thus my Minimum Duck (without Quack):
Code - C#: [Select]
  1.     public class Duck
  2.     {
  3.         int counter = 0;
  4.         public Duck GetEnumerator() { return this; }
  5.         public int Current
  6.         {
  7.             get
  8.             {
  9.                 Console.WriteLine("*Quack*Current*Quack*");
  10.                 return counter;
  11.             }
  12.         }
  13.         public bool MoveNext()
  14.         {
  15.             Console.WriteLine("*Quack*MoveNext*Quack*");
  16.             return counter++ < 10;
  17.         }
  18.     }
Edit #2: How is this relevant to AutoCAD?
I've always wondered how the compiler could be so damn sure about the element type of a collection, when encountered in a foreach loop; F# being no different that C#. Many collections in AutoCAD's API are basically broken when accessed in a functional setting; they are missing type information enforced by implementing a generic interface. This compiler quirk explains why they are very efficient when imperative legwork is used, with attendant type safety.
« Last Edit: June 18, 2013, 05:27:20 PM by kaefer »
Jeff H
« Reply #4 on: June 19, 2013, 01:32:20 AM »
I dunno?
I dunno?
