Author Topic: ==={Challenge}=== Broken Pieces  (Read 17853 times)
pBe
Re: ==={Challenge}=== Broken Pieces
« Reply #15 on: June 18, 2013, 05:55:27 AM »
Like i said "regular" jigsaw puzzles doesn't have "EDGE-LIKE" piece on the middle part of the board.
You are taking this challenge to another level :lmao: .
There too many common angles and UCS and all.
And that tile thingy? butted against each other? yeahh.. you know what i mean MR.
BTW: Are you going to modify your code to actually solve the jigsaw?
ribarm
  • Marko Ribar, architect
« Reply #16 on: June 18, 2013, 06:53:35 AM »
This puzzle is too complicated for my mind... I was just trying to dissect problem to basics (finding corners), but now as CAD isn't calculating correctly 4th corner with rotated UCS for checking upper-left piece, I am starting to loose patience... Still I am not good prepared for jigsaw challenge... If you can use my research, go ahead, you're welcome - this was my intention in the first place, but now I am seeing to many possibilities for this kind of task... And if I knew how to write jigsaw, still I think it wouldn't be totally applicable for all kind of situations... Still congratulate to all who even tries this challenge...
M.R. on Youtube
pBe
« Reply #17 on: June 18, 2013, 06:59:52 AM »
No worries Marko. just curious is all.
Thank you for your input MR.
Cheers
« Reply #18 on: June 18, 2013, 07:20:36 AM »
Lee. I finally got the chance to try your code, I'm still at awe how were you able to write the code with very few lines. [how did you manage that?]
I notice there are four pieces although connected to each other did not position itself correctly on the board. or is it just me.
Indeed, it is not a complete solution since I am only comparing the interior angles of pairs of pieces, and not groups of 3, 4, 5,...,n pieces. The ambiguity in the position of the last four pieces arises because I am comparing the outer angles of the edge pieces (i.e. testing for summation to pi radians, rather than 2pi), and several positions will pass this test.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #19 on: June 18, 2013, 11:49:00 AM »
my version:
  1. (defun c:test (/ A A1 A2 B D L V V1)
  2.   (setq a1 (ssget)
  3.         l  (mapcar (function (lambda (b)
  4.                                (mapcar (function list)
  5.                                        (mapcar (function (lambda (a) (car b))) (cdr b))
  6.                                        (cdr b)
  7.                                        (cons (last b) (cdr b))
  8.                                )
  9.                              )
  10.                    )
  11.                    (mapcar (function (lambda (b)
  12.                                        (cons b
  13.                                              (vl-remove nil
  14.                                                         (mapcar (function (lambda (a)
  15.        (if (= (car a) 10)
  16.        (cdr a)
  17.        )
  18.        )
  19.        )
  20.        (entget b)
  21.                                                         )
  22.                                              )
  23.                                        )
  24.                                      )
  25.                            )
  26.                            (vl-remove-if (function listp) (mapcar (function cadr) (ssnamex a1)))
  27.                    )
  28.            )
  29.         a1 nil
  30.         a2 nil
  31.         a  (car l)
  32.         l  (cdr l)
  33.   )
  34.   (while (and a l)
  35.     (progn
  36.       (setq b (car a)
  37.             v (mapcar (function -) (caddr b) (cadr b))
  38.       )
  39.       (foreach c l
  40.         (if (setq d (car (vl-member-if
  41.                            (function (lambda (d)
  42.                                        (equal v (mapcar (function -) (cadr d) (caddr d)) 1e-6)
  43.                                      )
  44.                            )
  45.                            c
  46.                          )
  47.                     )
  48.             )
  49.           (progn
  50.             (setq a2 (car (vl-remove-if-not (function (lambda (a) (assoc (car d) a))) l))
  51.                   v1 (mapcar (function -) (caddr d) (cadr b))
  52.                   a1 (vl-remove d
  53.                                 (append a1
  54.                                         (mapcar (function
  55.                                                   (lambda (a)
  56.                                                     (list (car a) (mapcar (function -) (cadr a) v1) (mapcar (function -) (caddr a) v1))
  57.                                                   )
  58.                                                 )
  59.                                                 a2
  60.                                         )
  61.                                 )
  62.                      )
  63.             )
  64.             (vla-move (vlax-ename->vla-object (car d)) (vlax-3d-point (caddr d)) (vlax-3d-point (cadr b)))
  65.             (setq l (vl-remove a2 l))
  66.           )
  67.         )
  68.       )
  69.       (if a1
  70.         (setq a  (append (cdr a) a1)
  71.               a1 nil
  72.         )
  73.         (setq a (cdr a))
  74.       )
  75.     )
  76.   )
  77. )
ribarm
« Reply #20 on: June 18, 2013, 12:06:16 PM »
I've updated my codes - in my last version I used (ssdel) function consequently and didn't realize that I have to do (ssadd) after to preserve selection set as it was... This is why it hadn't highlighted 4th piece (upper-left)...
I apologize for this inconvenience...
Marko R.
M.R. on Youtube
ribarm
« Reply #21 on: June 18, 2013, 12:24:43 PM »
my version:
  2.   (setq a1 (ssget)
  6.                                        (cdr b)
  8.                                )
  9.                              )
  10.                    )
  12.                                        (cons b
  13.                                              (vl-remove nil
  16.        (cdr a)
  17.        )
  18.        )
  19.        )
  20.        (entget b)
  21.                                                         )
  22.                                              )
  23.                                        )
  24.                                      )
  25.                            )
  27.                    )
  28.            )
  29.         a1 nil
  30.         a2 nil
  31.         a  (car l)
  32.         l  (cdr l)
  33.   )
  35.     (progn
  36.       (setq b (car a)
  38.       )
  39.       (foreach c l
  43.                                      )
  44.                            )
  45.                            c
  46.                          )
  47.                     )
  48.             )
  49.           (progn
  52.                   a1 (vl-remove d
  53.                                 (append a1
  55.                                                   (lambda (a)
  57.                                                   )
  58.                                                 )
  59.                                                 a2
  60.                                         )
  61.                                 )
  62.                      )
  63.             )
  66.           )
  67.         )
  68.       )
  69.       (if a1
  71.               a1 nil
  72.         )
  74.       )
  75.     )
  76.   )
  77. )
Wonderful, it works!!! In most cases it's truly correct...
Thanks, EEA...
M.R. on Youtube
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #22 on: June 18, 2013, 01:39:27 PM »
Thanks, EEA...
Thank you!
« Reply #23 on: June 18, 2013, 01:58:11 PM »
Matching edges instead of vertices - good method Evgeniy  :-)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #24 on: June 18, 2013, 02:03:19 PM »
Yes, if all the edges of different lengths
ribarm
« Reply #25 on: June 18, 2013, 03:02:46 PM »
So sel. sets were the problem with my codes...
Except this case pBe, at least and if it find wrong piece it won't break now...
M.R. on Youtube
dgorsman
« Reply #26 on: June 18, 2013, 03:31:03 PM »
That was my initial thought of attack as well.  Could probably extend that to handle adjoining edges, which would reduce the possibilities to a very low numbers.  If its pattern-broken like a jigsaw puzzle cutter I'm thinking it would be very difficult to get everything back together without some other qualifier.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
ribarm
« Reply #27 on: June 18, 2013, 06:05:14 PM »
My codes on page 1 finally updated...
Regards, M.R. :-) :-) :-)
M.R. on Youtube
LE3
« Reply #28 on: June 18, 2013, 10:42:28 PM »
Code - C#: [Select]
  1. [CommandMethod("TOGETHER")]
  2. public void cmd_together()
  3. {
  4.     var e = AcadApp.DocumentManager.MdiActiveDocument.Editor;
  5.     var tv = new TypedValue[] { new TypedValue((int)DxfCode.Start, "LWPOLYLINE") };
  6.     var filter = new SelectionFilter(tv);
  7.     var options = new PromptSelectionOptions();
  8.     options.MessageForAdding = "\nAdd PolyLine(s) to selection";
  9.     options.MessageForRemoval = "\nRemove PolyLine(s) from selection";
  10.     options.AllowDuplicates = false;
  11.     options.RejectObjectsFromNonCurrentSpace = true;
  12.     var psr = e.GetSelection(options, filter);
  13.     if (psr.Status != PromptStatus.OK) return;
  14.     double delta = 0.0000001;
  15.     using (var tr = e.Document.Database.TransactionManager.StartTransaction())
  16.     {
  17.         var ids = psr.Value.GetObjectIds();
  18.         foreach (var id in ids)
  19.         {
  20.             var polyline = (Polyline)tr.GetObject(id, OpenMode.ForWrite, false);
  21.             for (int i = 0; i < polyline.NumberOfVertices; i++)
  22.             {
  23.                 var line = polyline.GetLineSegmentAt(i);
  24.                 var found = false;
  25.                 foreach (var _id in ids)
  26.                 {
  27.                     var _polyline = (Polyline)tr.GetObject(_id, OpenMode.ForWrite, false);
  28.                     if (_polyline == polyline) continue;
  29.                     for (int ii = 0; ii < _polyline.NumberOfVertices; ii++)
  30.                     {
  31.                         var _line = _polyline.GetLineSegmentAt(ii);
  32.                         if (Math.Abs(line.Length - _line.Length) < delta)
  33.                         {
  34.                             var m = Matrix3d.Displacement(line.MidPoint - _line.MidPoint);
  35.                             _polyline.TransformBy(m);
  36.                             found = true;
  37.                             break;
  38.                         }
  39.                     }
  40.                     if (found) break;
  41.                 }
  42.             }
  43.         }
  44.         tr.Commit();
  45.     }
  46. }
The above will put together the shapes.-
« Reply #29 on: June 18, 2013, 11:50:29 PM »
my version:
  2.   <...>
  3.
  4. )
Smart bit of code Evgeniy :)
