Author Topic: Best way to open pdf in browser in autocad macro  (Read 18636 times)
Keith Brown
« on: June 13, 2013, 09:04:54 AM »
I have a need to have several buttons on my ribbon that will open up different pdfs.  I would like to be able to open up to certain bookmarks in the pdf and the only way I know that autocad can do that is by opening up the pdf in a browser with a url like this - c:/filename.pdf#view=FitV&page=10.  So in my macro I have the following:
Code - Lisp: [Select]
  1. ^C^C^P(command "._browser" "C:/Version_5.2.pdf#view=FitV")
My question to ask is if there is a better LISP function that will do the same thing?  Or for my purposes will this work ok?  I have heard that there is issues with the browser command but I have not experienced it yet.  I work off of IExplorer but the ribbon buttons has the possibility to be used by any browser and I would rather find out sooner than later that the macro I am using will work for everything.
Re: Best way to open pdf in browser in autocad macro
« Reply #1 on: June 13, 2013, 09:10:29 AM »
Try:
^C^C(startapp "explorer" "C:/Version_5.2.pdf")
Keith Brown
« Reply #2 on: June 13, 2013, 09:14:47 AM »
That doesn't work very well.  It opens up the My Documents window and just prints a 33 to the command line.
« Reply #3 on: June 13, 2013, 09:15:36 AM »
If the file can be found, it will open the file using the default program associated with the file extension.
« Reply #4 on: June 13, 2013, 09:17:39 AM »
Google chrome will open a PDF too.
GDF
« Reply #5 on: June 13, 2013, 09:23:11 AM »
(command "start" (strcat yourpathhere "ARCH_FILE.PDF"))
Keith Brown
« Reply #6 on: June 13, 2013, 09:28:19 AM »
It appears to not be working on my machine.  The explorer window opens up to C:\Users\Keith\Documents and the pdf doesn't open.  A 33 is printed to the command window.  A copy/paste of my actual command is:
Code - Text: [Select]
  1. ^C^C(startapp "explorer" "c:/version_5.2.pdf")
and this is what gets printed to the command line.
  1. Command: (startapp "explorer" "c:/version_5.2.pdf") 33
and I have triple checked the file and it is named correctly and located in my root drive.
« Reply #7 on: June 13, 2013, 09:29:41 AM »
although i'm not having any luck making it work with 'startapp'. :(
Keith Brown
« Reply #8 on: June 13, 2013, 09:35:08 AM »
While this will work to open up a pdf.  It will not work for my purpose.  I need to have the pdf open up to a certain page and/or bookmark using the following syntax:
  1. Version_5.2.pdf#View=FitV&nameddest=Chapter3
That is the reason why I was using the browser command.  Forcing it open in a browser session will respect the parameters after the pdf filename and file extension.  I just thought there was a better way to open a browser url.
« Reply #9 on: June 13, 2013, 09:40:07 AM »
Maybe try something like this:
  1. (defun openpdf ( pdf / exe pth )
  2.     (setq pth (LM:expenvstr "%PROGRAMFILES%")
  3.           pdf (strcat "\"" (vl-string-translate "/" "\\" pdf) "\"")
  4.     )
  5.     (cond
  6.         (   (and (setq exe (findfile (strcat pth "\\Mozilla Firefox\\firefox.exe")))
  7.                  (startapp exe pdf)
  8.             )
  9.         )
  10.         (   (and (setq exe (findfile (strcat pth "\\Internet Explorer\\iexplore.exe")))
  11.                  (startapp exe pdf)
  12.             )
  13.         )
  14.     )
  15. )
  16.
  17. ;; Expand Environment String  -  Lee Mac
  18. (defun LM:expenvstr ( str / res wsh )
  19.     (if (setq wsh (vlax-create-object "wscript.shell"))
  20.         (progn
  21.             (setq res (vl-catch-all-apply 'vlax-invoke (list wsh 'expandenvironmentstrings str)))
  22.             (vlax-release-object wsh)
  23.             (if (null (vl-catch-all-error-p res))
  24.                 res
  25.             )
  26.         )
  27.     )
  28. )
You can add extra conditions to account for other browsers (I don't know the path to the Chrome executable), and you can also change the order of conditions to use a preferred browser.
Call with:
  1. (openpdf "C:/Version_5.2.pdf#View=FitV&nameddest=Chapter3")
« Reply #10 on: June 13, 2013, 09:40:38 AM »
I would use the first method (the requirements are to open a PDF to a specific location).
EDIT:
You guys type fast.
« Reply #11 on: June 13, 2013, 09:53:15 AM »
Actually, this might be better:
  1. (defun browser ( url )
  2.     (setq url (strcat "\"" (vl-string-translate "/" "\\" url) "\""))
  3.     (vl-some '(lambda ( exe ) (and (findfile exe) (startapp exe url)))
  4.         (list
  5.             (strcat (getenv "programfiles") "\\Mozilla Firefox\\firefox.exe")
  6.             (strcat (getenv "localappdata") "\\Google\\Chrome\\Application\\chrome.exe")
  7.             (strcat (getenv "programfiles") "\\Internet Explorer\\iexplore.exe")
  8.         )
  9.     )
  10. )
  1. (browser "C:/Version_5.2.pdf#View=FitV&nameddest=Chapter3")
« Last Edit: June 13, 2013, 10:11:20 AM by Lee Mac »
« Reply #12 on: June 13, 2013, 09:53:35 AM »
You could use this to open in chrome ... does not check if chrome is installed.
(defun _openfileinchrome (file / sa)
  (and (findfile file)
       (setq sa (vlax-get-or-create-object "Shell.Application"))
       (null (vlax-invoke sa 'shellexecute "chrome.exe" file))
       (vlax-release-object sa)
(_openfileinchrome "c:\\test.pdf")
« Last Edit: June 13, 2013, 10:15:37 AM by ronjonp »
Keith Brown
« Reply #13 on: June 13, 2013, 10:38:09 AM »
  4.         (list
  8.         )
  9.     )
  10. )
This works great Lee.  Thanks.
Keith Brown
« Reply #14 on: June 13, 2013, 10:40:15 AM »
I only have IE on  my machine.  I am wondering how the order of the list will effect uses that have ie, firefox, and chrome?
