I set the Pressure Network Catalog to one of the sqlite files located here: C:\ProgramData\Autodesk\C3D 2013\enu\Pressure Pipes Catalog\Imperial\
I brought the Pressure Network Parts Lists "Standard" and "Water" into my drawing by dragging it from the Toolspace from the out-of-the-box template _AutoCAD Civil 3D (Imperial) NCS.
When I open the parts list, there is nothing in the material category. (See attachment 1)
On the Pressure Network Plan Layout ribbon, I don't have any parts to select for pipes or fittings (See attachment 2).
Why is this happening?
Thanks in advance for your help!
Meredith
