Author Topic: BlockReference  (Read 1890 times)
jcoon
BlockReference
« on: June 04, 2013, 04:14:46 PM »
I'm looking at creatre a block reference to insert different block symbols based on civil 3d surface query. I'm able to create the block name which shows in the block
collection after I run this test. The issue I'm having seems simple but I have not been able to find a sample that shows how to define the block reference for that block name. I found plenty of samples on how to insert a block from outside the editor.  Basically I need to convert my vba sample that checks for a block and if that block is not found in the block collection it creates the block reference.
Thanks for any links or data you can provide.
John
''''' my old vba sample
 If BlockExists("BlockName") Then
Call insertblocks   ' blocks exist. go to insert routine
End If
If BlockExists("BlockName") = False Then
Call makeblocks
End If
 End Sub
Sub makeblocks()
  Dim BlockName1 As String
  BlockName1 = "SURFACECUT"
  Dim LayerName As String
  ' Make point array for block's insertion point
  Dim ptOrigin(2) As Double
  ptOrigin(0) = 0#: ptOrigin(1) = 0#: ptOrigin(2) = 0#
' Create the block object
  Dim Block As AcadBlock
  Set Block = ThisDrawing.Blocks.Add(ptOrigin, BlockName1)
' Make points for lines
  Dim pt1(2) As Double
  pt1(0) = 0#: pt1(1) = -0.04: pt1(2) = 0#
  Dim pt2(2) As Double
  pt2(0) = -0.06: pt2(1) = -0.04: pt2(2) = 0#
  Dim pt3(2) As Double
  pt3(0) = 0.06: pt3(1) = -0.04: pt3(2) = 0#
  Dim pt4(2) As Double
  pt4(0) = -0#: pt4(1) = 0.08: pt4(2) = 0#
' Add the lines to the block's definition
  Block.AddLine pt2, pt3
  Block.AddLine pt3, pt4
  Block.AddLine pt4, pt2
  Call insertblocks
End Sub
'vb sample
<CommandMethod("addblock1")> _
    Public Sub addblock1()
        Dim ed As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor()
        Dim db As Database = HostApplicationServices.WorkingDatabase
        Dim civilDoc As CivilDocument = CivilApplication.ActiveDocument
        Dim acaddoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim BlockTable As BlockTable
        Dim BlockTableRecord As BlockTableRecord
        Dim tr As Transaction = db.TransactionManager.StartTransaction
        Try
            BlockTable = acaddoc.Database.BlockTableId.GetObject(OpenMode.ForWrite)
            BlockTableRecord = New BlockTableRecord
            BlockTableRecord.Name = "CUT"
            ' Make point lines to create block
            Dim pt5(2) As Double
            pt5(0) = 0.0# : pt5(1) = -0.072 : pt5(2) = 0.0#
            Dim pt6(2) As Double
            pt6(0) = -0.083 : pt6(1) = -0.072 : pt6(2) = 0.0#
            Dim pt7(2) As Double
            pt7(0) = -0.083 : pt7(1) = 0.072 : pt7(2) = 0.0#
            Dim pt8(2) As Double
            pt8(0) = 0.083 : pt8(1) = 0.072 : pt8(2) = 0.0#
            Dim pt9(2) As Double
            pt9(0) = 0.083 : pt9(1) = -0.072 : pt9(2) = 0.0#
            Dim acLine As Line
            acLine = New Line(New Point3d(pt6), New Point3d(pt7))
            acLine = New Line(New Point3d(pt7), New Point3d(pt8))
            acLine = New Line(New Point3d(pt8), New Point3d(pt9))
            acLine = New Line(New Point3d(pt9), New Point3d(pt6))
            BlockTable.Add(BlockTableRecord)
            tr.AddNewlyCreatedDBObject(BlockTableRecord, True)
            tr.Commit()
        Catch ex As System.Exception
            ed.WriteMessage(ex.ToString)
        End Try
       End Sub
WILL HATCH
Re: BlockReference
« Reply #1 on: June 04, 2013, 06:01:18 PM »
try the .NET BLOCK Rountines library
are you getting an error or just undesired results?
jcoon
Re: BlockReference
« Reply #2 on: June 05, 2013, 08:24:42 AM »
Will,
got it, thanks
Dim Line as line = new Line(new Point3d(pt5), new Point3d(pt6))
btr.AppendEntity(line)
John
