I posted this in another forum with no luck, no response at all, hoping a Swamper has some insight...
This is related to Sheet Set Manager with "Publish using Page Setup Override".
But more basically, I have an issue where I'm not getting the same results when plotting (to PDF) using the "Layout" with defined offsets.
I can duplicate the problem by simply going into the sheets and plotting and reproduce the same problem.
Everything "seems" to be identical, same title block, same plotting configurations, same insertion point and origin (verified TB is at 0,0), same units.
Most of the drawings plot correctly, centered etc, about a third do not, they are the same distance off from being centered, so I suspect it's some silly setting I'm not seeing in those drawings.
I don't think it's a SSM thing, because I can duplicate it by simply plotting on-the-fly with this set up, but I could be wrong.
See screen shots:
"Drawing A": Plots Good!
"Drawing B: same configuration, Plots Bad!, title block low and to the left
Anyone have any thoughts on this?
Gotta be something I'm missing, it should work.
Thanks in advance.
