Author Topic: copy entity from block  (Read 10750 times)
taner
« on: June 02, 2013, 05:06:56 AM »
Dear all,
Can anyone solve this problem? please see the below link.
 http://bbs.xdcad.net/thread-667613-1-1.html
hugha
Re: copy entity from block
« Reply #1 on: June 02, 2013, 05:43:36 AM »
It's all in Chinese.
GP
  • Vercelli, Italy
« Reply #2 on: June 02, 2013, 06:31:02 AM »
ncopy ?!?
« Last Edit: June 02, 2013, 06:34:03 AM by GP »
« Reply #3 on: June 02, 2013, 07:19:15 AM »
  1. (defun c:test ( / a b )
  2.     (if
  3.         (and
  4.             (setq a (nentselp))
  5.             (= 4 (length a))
  6.             (setq b (entmakex (entget (car a))))
  7.         )
  8.         (vla-transformby (vlax-ename->vla-object b) (vlax-tmatrix (caddr a)))
  9.     )
  10.     (princ)
  11. )
taner
« Reply #4 on: June 02, 2013, 11:19:58 AM »
yes,it is similar to ncopy.
Hi, Lee, your routine can only copy one entity at one time. But the request is copy all entity at one time.Explode is not allowed.
thanks.
« Reply #5 on: June 02, 2013, 12:26:52 PM »
  1. ;; Multiple Nested Copy  -  Lee Mac
  2. ;; Copies all components of a selected block reference to the active space.
  3.
  4. (defun c:ncopym ( / ent lst mat obj )
  5.     (while
  6.         (progn (setvar 'errno 0) (setq ent (car (entsel "\nSelect Block Reference: ")))
  7.             (cond
  8.                 (   (= 7 (getvar 'errno))
  9.                     (princ "\nMissed, try again.")
  10.                 )
  11.                 (   (= 'ename (type ent))
  12.                     (setq obj (vlax-ename->vla-object ent))
  13.                     (cond
  14.                         (   (/= "AcDbBlockReference" (vla-get-objectname obj))
  15.                             (princ "\nSelected object is not a block reference.")
  16.                         )
  17.                         (   (= :vlax-true (vla-get-hasattributes obj))
  18.                             (princ "\nSelected block must not be attributed.")
  19.                         )
  20.                         (   (= :vlax-true (vla-get-isdynamicblock obj))
  21.                             (princ "\nSelected block must not be dynamic.")
  22.                         )
  23.                         (   (not
  24.                                 (and
  25.                                     (equal (vla-get-xscalefactor obj) (vla-get-yscalefactor obj) 1e-8)
  26.                                     (equal (vla-get-xscalefactor obj) (vla-get-zscalefactor obj) 1e-8)
  27.                                 )
  28.                             )
  29.                             (princ "\nSelected block must be uniformly scaled.")
  30.                         )
  31.                         (   t
  32.                             (setq mat
  33.                                 (vlax-tmatrix
  34.                                     (apply
  35.                                         (function
  36.                                             (lambda ( mat vec )
  37.                                                 (append (mapcar 'append mat (mapcar 'list vec))
  38.                                                    '((0.0 0.0 0.0 1.0))
  39.                                                 )
  40.                                             )
  41.                                         )
  42.                                         (refgeom ent)
  43.                                     )
  44.                                 )
  45.                             )
  46.                             (vlax-for obj (vla-item (vla-get-blocks (LM:acdoc)) (vla-get-name obj))
  47.                                 (setq lst (cons obj lst))
  48.                             )
  49.                             (foreach obj
  50.                                 (vlax-invoke (LM:acdoc) 'copyobjects (reverse lst)
  51.                                     (vlax-ename->vla-object (cdr (assoc 330 (entget ent))))
  52.                                 )
  53.                                 (vla-transformby obj mat)
  54.                             )
  55.                         )
  56.                     )
  57.                 )
  58.             )
  59.         )
  60.     )
  61.     (princ)
  62. )
  63.
  64. ;; RefGeom (gile)
  65. ;; Returns a list whose first item is a 3x3 transformation matrix and
  66. ;; second item the object insertion point in its parent (xref, block or space)
  67.
  68. (defun refgeom ( ent / ang enx mat ocs )
  69.     (setq enx (entget ent)
  70.           ang (cdr (assoc 050 enx))
  71.           ocs (cdr (assoc 210 enx))
  72.     )
  73.     (list
  74.         (setq mat
  75.             (mxm
  76.                 (mapcar '(lambda ( v ) (trans v 0 ocs t))
  77.                    '(
  78.                         (1.0 0.0 0.0)
  79.                         (0.0 1.0 0.0)
  80.                         (0.0 0.0 1.0)
  81.                     )
  82.                 )
  83.                 (mxm
  84.                     (list
  85.                         (list (cos ang) (- (sin ang)) 0.0)
  86.                         (list (sin ang) (cos ang)     0.0)
  87.                        '(0.0 0.0 1.0)
  88.                     )
  89.                     (list
  90.                         (list (cdr (assoc 41 enx)) 0.0 0.0)
  91.                         (list 0.0 (cdr (assoc 42 enx)) 0.0)
  92.                         (list 0.0 0.0 (cdr (assoc 43 enx)))
  93.                     )
  94.                 )
  95.             )
  96.         )
  97.         (mapcar '- (trans (cdr (assoc 10 enx)) ocs 0)
  98.             (mxv mat (cdr (assoc 10 (tblsearch "block" (cdr (assoc 2 enx))))))
  99.         )
  100.     )
  101. )
  102.
  103. ;; Matrix Transpose  -  Doug Wilson
  104. ;; Args: m - nxn matrix
  105.
  106. (defun trp ( m )
  107.     (apply 'mapcar (cons 'list m))
  108. )
  109.
  110. ;; Matrix x Matrix  -  Vladimir Nesterovsky
  111. ;; Args: m,n - nxn matrices
  112.
  113. (defun mxm ( m n )
  114.     ((lambda ( a ) (mapcar '(lambda ( r ) (mxv a r)) m)) (trp n))
  115. )
  116.
  117. ;; Matrix x Vector  -  Vladimir Nesterovsky
  118. ;; Args: m - nxn matrix, v - vector in R^n
  119.
  120. (defun mxv ( m v )
  121.     (mapcar '(lambda ( r ) (apply '+ (mapcar '* r v))) m)
  122. )
  123.
  124. ;; Active Document  -  Lee Mac
  125. ;; Returns the VLA Active Document Object
  126.
  127. (defun LM:acdoc nil
  128.     (LM:acdoc)
  129. )
  130.
taner
« Reply #6 on: June 02, 2013, 12:50:10 PM »
HI,Lee,Hope you download the attched test file for testing.
the test result:命令:  NCOPYM
Select Block Reference: *取消*
; 错误: 函数被取消
« Reply #7 on: June 02, 2013, 02:11:53 PM »
; 错误: 函数被取消
Yes, the program is restricted to uniformly scaled blocks as stated by the message.
taner
« Reply #8 on: June 03, 2013, 06:24:11 AM »
Hi,LEE,Can you try to write one that can copy not uniformly scaled block(the attachment is uniformly scaled block )? Thanks!
« Reply #9 on: June 03, 2013, 06:29:53 AM »
  1. (defun c:ncopym ( / ent obj )
  2.     (while
  3.         (progn (setvar 'errno 0) (setq ent (car (entsel "\nSelect Block Reference: ")))
  4.             (cond
  5.                 (   (= 7 (getvar 'errno))
  6.                     (princ "\nMissed, try again.")
  7.                 )
  8.                 (   (= 'ename (type ent))
  9.                     (setq obj (vlax-ename->vla-object ent))
  10.                     (cond
  11.                         (   (/= "AcDbBlockReference" (vla-get-objectname obj))
  12.                             (princ "\nSelected object is not a block reference.")
  13.                         )
  14.                         (   (= :vlax-true (vla-get-hasattributes obj))
  15.                             (princ "\nSelected block must not be attributed.")
  16.                         )
  17.                         (   (= :vlax-true (vla-get-isdynamicblock obj))
  18.                             (princ "\nSelected block must not be dynamic.")
  19.                         )
  20.                         (   (not (vlax-write-enabled-p obj))
  21.                             (princ "\nSelected block is on locked layer.")
  22.                         )
  23.                         (   (vla-explode obj)) ;; Thanks roy
  24.                     )
  25.                 )
  26.             )
  27.         )
  28.     )
  29.     (princ)
  30. )
« Last Edit: June 03, 2013, 06:48:59 PM by Lee Mac »
roy_043
  • BricsCAD 18
« Reply #10 on: June 03, 2013, 01:23:51 PM »
(vla-explode) does not erase the original object so there is no need for (vla-copy).
« Reply #11 on: June 03, 2013, 06:48:38 PM »
Good catch roy, the code was written in haste  :oops:
Now updated.
Ketxu
« Reply #12 on: June 04, 2013, 07:08:30 AM »
Lee, please tell me what benefit of use LM:acdoc funtion in #6 post. Can be simple (vla-get-activedocument (vlax-get-acad-object)) ? . I haven't understand clearly :(. Thank you
« Reply #13 on: June 04, 2013, 08:45:17 AM »
The use of defun-q will help to explain the difference:
Consider the following functions:
  1. (defun-q f2 nil
  2.     (f2)
  3. )
Before function evaluation, the respective function definitions are as follows:
When evaluated, both functions will return the Active Document object:
  1. _$ (f1)
  2. #<VLA-OBJECT IAcadDocument 0ceb5b6c>
  3. _$ (f2)
  4. #<VLA-OBJECT IAcadDocument 0ceb5b6c>
However, observe the respective function definitions following function evaluation:
  1. _$ f1
  2. _$ f2
  3. (nil #<VLA-OBJECT IAcadDocument 0ceb5b6c>)
Note that function f2 now no longer retrieves the Application Object (vlax-get-acad-object) before retrieving the Active Document Property (vla-get-activedocument), but simply returns the Active Document object directly. The method is similar to setting a global variable pointing to the Active Document Object.
Of course, for this program, I could have equivalently used a local variable assigned with the Active Document Object, however, such local variable would then be re-assigned this value for every use of the program.
« Last Edit: June 04, 2013, 08:53:20 AM by Lee Mac »
Ketxu
« Reply #14 on: June 04, 2013, 09:47:21 AM »
Oh now i see ^^ Great, It's new for me.
