Author Topic: COUNT BLOCKS - COUNT V1.3 BY LEE  (Read 2411 times)
GISDUDE
« on: May 29, 2013, 05:15:29 PM »
Hey Lee,
I did a search on the swamp for a lisp file that will count blocks in a drawing. I downloaded the Countv1.3 off your site. It works except, when I select the block, the table will only list 1 occurence in the table, when I know there are several dozen. Any thoughts? I'm on AutoCAD 2012, MAP3D, 32 bit.
Many thanks :-D
Re: COUNT BLOCKS - COUNT V1.3 BY LEE
« Reply #1 on: May 29, 2013, 05:32:21 PM »
Hi GISDUDE,
Are you able to attach a drawing containing only the selection of blocks you are attempting to count?
Meanwhile, does this program yield the same result?
Lee
AVCAD
« Reply #2 on: August 12, 2015, 09:22:25 AM »
Is there a version of this or a different routine that will count the attributes as well??
« Reply #3 on: August 12, 2015, 09:35:59 AM »
You could perhaps try my Count Attribute Values program.
