I downloaded both lisp routines from Alanj, (thx!). The "filteredselection" file won't load. The "selectionfilter" one works perfectly, but I'd like to get the other one to work as well.
I'm wondering if my file might have a problem? I keep getting the error "unreconciled layers" when I open up this particular dwg. I have an xref I have in the background that may be causing the problem or it could be a filter. I'll experiment a little bit.
Lee/Alanj - I did modify the lines that had the "getstring" to "getstring t" - 5 lines all together. Looks like that helped a lot!
Many thanks for the help and tips.
