Author Topic: Check Error For Deg/Min/Sec  (Read 1620 times)
AARYAN
« on: May 17, 2013, 01:33:53 AM »
Hi All,
I am trying to creating a routine which gets the user input in DD/DM/DMS. All I want is to check the typo error which can be made by the user.
What am I approaching here is to check if the user has choosen the DD as the input then the edit_box must contain a real value with the degree symbol. Same lies for DM and DMS which must be containing the Minutes and Seconds symbol respectively.
I have already tried angtof function. Here is what i experimented with it..
(angtof "23°30'25\"" 0) --> 0.410274 ; returned value
(angtof "23°30'25\"" 1) --> 0.410274 ; returned value
Dont know why the supplied units doesnt give any error in the first expression, it should give an error when i pass the unit as 0 and string value in DMS.
Please guide me how can i do it.
Thanks and Regards
Russelltimk
Re: Check Error For Deg/Min/Sec
« Reply #1 on: May 17, 2013, 02:41:40 AM »
I'm new myself to lisp (doing it properly at least) but I don't think the function is checking the number how you believe it is.
Check out this link for more info on the function. The number at the end is just denoting the mode.
http://help.caddit.net/progecad.php?kb=IDR_LISP_B124
This link might be useful to you for checking that the input is in the format you want to see...
http://www.cadtutor.net/forum/showthread.php?16638-LISP-requesting-user-input&s=b5544a159b6bbff2b2fa8ccad7b4ef40
Hope this helps!
AARYAN
« Reply #2 on: May 17, 2013, 03:26:11 AM »
Thank You So Much!!! Russelltimk..
