Author Topic: arc dimension lisp question?  (Read 10456 times)
MikePerry
« Reply #15 on: November 06, 2004, 03:52:04 PM »
Hi
For AutoCAD 2005 User's the following might be of some interest....
Below snippet comes via a CAD E-mail Newsletter that arrives in my Inbox -
<snip>
In a similar vein, you can make an arc dimension similar to a standard associative dimension. Type Ddunits and set your units as appropriate. At the Command prompt, type Field. Select Object and set your desired units. At the bottom of the Field dialog box, highlight the code, right-click, and select Copy. Cancel the Field command. Start the Dimangular command and select the arc, then T for text paste, and proceed with the command. You end up with an associative dimension for the arc. When you stretch it and regenerate, the field displays the new dimension.
</snip>
Check out # 58 "Arc Dim. R2005" at http://home.pacifier.com/~nemi/
Have a good one, Mike
42
Re: arc dimension lisp question?
« Reply #16 on: November 15, 2005, 06:04:09 PM »
I know this was pasted some time ago, but have just done a search for Radius dimensions, this is just the tickedt. Thanks :lol:
Alastair Mallett Autodesk Certified Professional
Technical Director
Hunters South Architects
delium55
« Reply #17 on: August 07, 2006, 11:50:22 PM »
Keith, Why your programm Dimarc dont work in paperspace on 2k4.
Thank in advance.
« Reply #18 on: August 08, 2006, 08:05:08 AM »
I don't know, I will have to look at it and see if I can find out why.
John Hancock
« Reply #19 on: August 26, 2006, 11:10:06 AM »
Keith,
I like your arc dimension routine.  The only problem I have is that I can't get the dcl to work.  I've loaded the program in Acad's path but the only thing that works is the lisp program.  What am I doing wrong?
John
« Reply #20 on: August 27, 2006, 06:24:54 PM »
Make sure you have named the DCL file correctly, and it would be better if it were located within the same folder as the lsp file.
John Hancock
« Reply #21 on: September 02, 2006, 10:58:48 AM »
Keith,
I was able to get the dcl to work.  Thanks for a great program
John
