Author Topic: Rename Paperspace Layout OBDX  (Read 6594 times)
« on: May 08, 2013, 11:32:07 AM »
Has anyone figured out how to do this or is it just a limitation? I can see the layout object and all the properties ... but when I try and delete or rename, this error is thrown:
Error: Automation Error. Layout does not eixst for renaming; reset after error
  ... and yes "exist" is misspelled  :-)
Re: Rename Paperspace Layout OBDX
« Reply #1 on: May 08, 2013, 01:07:25 PM »
Maybe some code to test...
  1. (defun c:test (/ odbx v)
  2.   (if (setq
  3.         odbx (if (< (atoi (setq v (substr (getvar 'acadver) 1 2))) 16)
  4.                (vla-getinterfaceobject (vlax-get-acad-object) "ObjectDBX.AxDbDocument")
  5.                (vla-getinterfaceobject (vlax-get-acad-object) (strcat "ObjectDBX.AxDbDocument." v))
  6.              )
  7.       )
  8.              odbx
  9.              (strcat (getvar 'dwgprefix) (vl-filename-base (getvar 'dwgname)) "-test.dwg")
  10.            )
  11.            ;; This is where the poo happens :)=
  12.            (vlax-for l (vla-get-layouts odbx)
  13.              ;; Rename first tab in new drawing to tabname from old drawing
  14.              (and (= (vla-get-taborder l) 1) (vla-put-name l "test"))
  15.              ;; Delete the second tab "Layout2"
  16.              ;; (and (= (vla-get-taborder l) 2) (vla-delete l))
  17.            )
  18.            (vlax-release-object odbx)
  19.     )
  20.   )
  21. )
« Reply #2 on: May 08, 2013, 01:46:16 PM »
Using your supplied code, the first layout in the active drawing was renamed, not that of the saved drawing.  :?
kruuger
« Reply #3 on: May 08, 2013, 01:53:24 PM »
  ... and yes "exist" is misspelled  :)
same error on 2010
k.
« Reply #4 on: May 08, 2013, 02:01:47 PM »
No errors?
BlackBox
« Reply #5 on: May 08, 2013, 02:15:25 PM »
Perhaps, for testing purposes, it would be better to instead vl-File-Copy the Active Document first, and then open the resultant Drawing via DBX, being sure to save the changes afterward.  :-)
kruuger
« Reply #6 on: May 08, 2013, 02:22:10 PM »
No errors?
no. code rename layout in active dwg.
i used this for test:
(defun 000:GetDbxDocument ()
  (vla-getInterfaceObject (vlax-get-acad-object)
    (strcat "ObjectDBX.AxDbDocument." (substr (getvar "ACADVER") 1 2) )
(not
  (vl-catch-all-error-p
    (vl-catch-all-apply
      (quote vla-open)
      (list
        (setq dbx (000:GetDbxDocument))
        "d:\\xxx.dwg"
(setq *cd-Layouts* (vla-get-layouts dbx))
(vlax-for % *cd-Layouts*
  (vla-delete (vla-item *cd-Layouts* "1-01"))
(vlax-release-object Dbx)
dwg xxx.dwg on d: with layout 1-01
k.
Cathy
« Reply #7 on: May 08, 2013, 02:25:53 PM »
It ran for me in 2012, renaming Layout1 tab to test in the active drawing.
Just for my education, why do you use "and" here?  I would have used "if".  Does the vla-put-name run even if the first half is nil?
BlackBox
« Reply #8 on: May 08, 2013, 02:36:07 PM »
No... When the first expression returns Nil, the second expression is not evaluated.
BlackBox
« Reply #9 on: May 08, 2013, 02:45:35 PM »
Even after accounting for the renaming of the active document, I too am receiving the same typo... err, I mean error message.
I also tried accessing the Layout Object with vla-Item (in case renaming an iterated object was the cause for the error), but this too was unsuccessful for me... Tested in Civil 3D 2011, and 2012.
« Reply #10 on: May 08, 2013, 03:25:19 PM »
Thanks for checking this. Guess it's just a bug.
Marc'Antonio Alessi
  • Marco
« Reply #11 on: May 08, 2013, 03:47:18 PM »
Same here in 2010:  :o
(defun ALE_Utl_GetItem (VlaCol KeyNam / VlaObj)
  (vl-catch-all-apply
   '(lambda ( )
      (setq VlaObj (vla-item VlaCol KeyNam))
  VlaObj
(setq
  DbxDoc (vla-GetInterfaceObject
  (vlax-get-Acad-Object) (strcat "ObjectDBX.AxDbDocument." (substr (getvar "ACADVER") 1 2)))
(vl-catch-all-error-p (vl-catch-all-apply 'vla-Open (list DbxDoc "test.dwg")))
(vlax-dump-object  (setq lllll (vla-get-Layouts DbxDoc)) T)
; IAcadLayout:
;   Document (RO) = #<VLA-OBJECT IAxDbDocument 000000000cc22fa0>
>>> different >>> Document IAxDb
(vlax-dump-object  (setq aaaaa (vla-get-Layouts (vla-get-activedocument (vlax-get-acad-object)))) T)
; IAcadLayout:
on (RO) = #<VLA-OBJECT IAcadApplication 00000001409f6c70>
;   Document (RO) = #<VLA-OBJECT IAcadDocument 000000000cae3bc0>
>>> different >>> Document IAcad
(setq LayObj    (ALE_Utl_GetItem aaaaa "Layout1"))
(setq LayODBX (ALE_Utl_GetItem lllll "Layout1"))
(vla-put-name LayObj "test") or (vla-put-name LayODBX "test")
>>> rename always Layout1 on active DWG
BlackBox
« Reply #12 on: May 08, 2013, 03:52:00 PM »
You're welcome, ronjonp... Short of a Script, or investigating if a .NET LispFunction Method could perform this task within a LISP's ObjectDBX wrapper, I'm not sure how else to accomplish this.
Good luck :beer:
Cathy
« Reply #13 on: May 08, 2013, 03:52:36 PM »
The first time I ran this, it worked.  The second time it did not.  If I change the rename to -test1, it will work one more time.
BlackBox
« Reply #14 on: May 08, 2013, 04:18:23 PM »
Please clarify the phrase "it worked"... What exactly was done?
