Author Topic: why this hatch has no area?  (Read 4068 times)
HasanCAD
« on: May 06, 2013, 03:57:16 PM »
I am tring tp get hatch area using
(setq obj  (vlax-ename->vla-object (ssname sset cnt)))
(setq ar (+ ar (vla-get-area obj)))
but gives error
Select objects:  ; error: Automation Error. Invalid input
alanjt
  • Standby for witty remark...
Dropbox
Re: why this hatch has no area?
« Reply #2 on: May 06, 2013, 04:09:02 PM »
Check for self-intersecting hatch boundary.
cadplayer
« Reply #3 on: May 07, 2013, 01:13:43 AM »
Yes the problem I have often with unclosed, arc or Polylines with dubbel lines (Intersection in Polyline). That why I have a routine which check first if Polyline have a area value, if not it draws a line to them.
(if (= T (vl-catch-all-error-p (setq A (vl-catch-all-apply 'vla-get-area (list Vobj)))))
            (princ (strcat "\nwrong area " (cdr (assoc 8 (entget ent))) ))
            (setq l (cdr (vl-remove-if-not (function (lambda (x) (= (car x) 10))) (entget ent))))
            (entmakex
                (list
                   '(0 . "LINE")
                    (cons 10 '(0 0 0))
                    (cons 11  (list (cadr (nth 1 l)) (caddr (nth 1 l))))
                   '(62 . 256)
« Reply #4 on: May 07, 2013, 07:26:30 AM »
Some minor points Dirk, but the following may help with your understanding of AutoLISP:
  1. (if (= T (vl-catch-all-error-p (setq A (vl-catch-all-apply 'vla-get-area (list Vobj)))))
The '=' function is redundant since it will return T if the vl-catch-all-error-p expression being compared returns T; hence the above is equivalent to:
  1. (if (vl-catch-all-error-p (setq A (vl-catch-all-apply 'vla-get-area (list Vobj))))
  1. (cons 10 '(0 0 0))
Note that:
  1. (cons 10 '(0 0 0)) == '(10 0 0 0) == (list 10 0 0 0)
  1. (cons 11 (list (cadr (nth 1 l)) (caddr (nth 1 l))))
The above could be written:
  1. (cons 11 (cdadr l))
Incorporating these and some other changes:
  1. (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-get-area (list Vobj)))
  2.     (progn
  3.         (princ (strcat "\nWrong area " (vla-get-layer Vobj)))
  4.         (setq l (vlax-get Vobj 'coordinates))
  5.         (entmake
  6.             (list
  7.                '(0 . "LINE")
  8.                '(10 0.0 0.0 0.0)
  9.                 (list 11 (car l) (cadr l) (vla-get-elevation Vobj))
  10.                '(62 . 256)
  11.                 (cons 8 (vla-get-layer Vobj))
  12.             )
  13.         )
  14.     )
  15. )
« Last Edit: May 07, 2013, 07:29:54 AM by Lee Mac »
irneb
« Reply #5 on: May 07, 2013, 07:53:58 AM »
http://www.theswamp.org/index.php?topic=32571.0
Alan. Regarding that other thread - do you remember if the hatch was made using a pick-point or through selecting the polyline(s)? If the former it might have picked up some strange stuff from OFF layers (or I've even seen it pick up lines outside the boundary).
But why it would have an area on one PC but not the other on the same DWG on the same hatch is beyond comprehension. Is acad using some form of GPU acceleration to calculate the areas?
Other than that as Lee and Dirk's stated: Either it's self-intersecting (like a bow-tie) or it's not fully enclosed (e.g. using gap tolerances). In my experience these are 99.9999% of the time the culprits for non-areas.
alanjt
« Reply #6 on: May 07, 2013, 07:57:07 AM »
Honestly, I don't remember. I didn't create the hatches, another user had and has posted about them. It started with me posting a hatch area LISP, but I guess that thread was removed.
What you are saying, in agreement with Lee, makes sense.
Dropbox
cadplayer
« Reply #7 on: May 07, 2013, 09:50:59 AM »
Thanks Lee, I´m alway open for correcction. :-o
« Reply #8 on: May 07, 2013, 10:05:17 AM »
Me too  :wink:
HasanCAD
« Reply #9 on: May 16, 2013, 03:22:57 AM »
is this good solution
(defun c:HatchAreas (/ AREA CNT OBJ OBJVL ORC SSET )
  (defun NLayer (Nme)
  (if (not (tblsearch "LAYER" Nme))
      (entmake (list (cons 0 "LAYER") (cons 100 "AcDbSymbolTableRecord")
     (cons 100 "AcDbLayerTableRecord") (cons 2  Nme)
     (cons 70 0) (cons 62 1))))))
  (nlayer "HatchHasNoArea")
  (if (>= (atof (substr (getvar "acadver") 1 4)) 16.2)
      (prompt "\nSelect hatches: ")
      (if (and (setq sset (ssget '((0 . "hatch"))) cnt 0 area 0))
  (repeat (sslength sset)
    (setq obj   (ssname sset cnt))
    (setq objvl (vlax-ename->vla-object obj))
  (vl-catch-all-apply 'vla-get-area (list objvl)))
(vla-put-color objvl 256)
(vla-put-layer objvl "HatchHasNoArea")
) ;prgn
      (setq area (+ area (vla-get-area objvl)))
      ) ;if
    (setq cnt (1+ cnt))
    ) ; repeat
) ;if
      )) ; if
  (alert
    (strcat
      "\nTotal area = "
      (if (or (= (getvar "lunits") 3) (= (getvar "lunits") 4))
(strcat (rtos area 2) " sq. in. (" (rtos (/ area 144) 2) " sq. ft.)"
"\nHatchs with RED color DID NOT calculated")
(strcat (rtos area) "\nHatchs with RED color DID NOT calculated"))
      ) ; strcat
    ) ;alert
  ) ; defun
