Author Topic: Add Surfacew texture symbol - AutoCAD mechanical  (Read 2979 times)
NirantarVidyarthee
« on: May 02, 2013, 03:40:37 PM »
I have VBA code to insert Surfacew texture symbol where I am facing 2 problems:
1. When I set the min. Ra value as string (eg "Ra 1.6"), the value gets removed as soon as  I try to save the drawing or move / rotate the symbol.
2. The same string does not appear if I use any template other than am_ansi.dwt. This is very strange.
Any help would be welcome.
