Author Topic: Qt in the ARX  (Read 8585 times)
Andrey Bushman
Qt in the ARX
« on: April 24, 2013, 02:22:02 AM »
Can I use the Qt in the my ARX applications? Anybody has this experience?
Thank you.
Re: Qt in the ARX
« Reply #1 on: April 24, 2013, 08:34:31 AM »
Thank you.
I've tried to get Qt (mingw) to work with COM and it's just not possible as far as I can tell. However, I couldn't see why you couldn't get some Qt inside a .dll and use it with ARX. Recompile Qt with VS and start making I suppose.
Andrey Bushman
Re: Qt in the ARX
« Reply #2 on: April 24, 2013, 08:40:13 AM »
The GUI in ARX through the Qt is interesting for me.
Re: Qt in the ARX
« Reply #3 on: April 24, 2013, 08:44:45 AM »
Me as well.
You would have to build a few DLLs. I've seen a few "refactoring" examples where the widgets gets built/changed/added to/etc. at run time instead of static dialogs. I'm sure that method would have to be used if you are going to be building a "generic widgets library" of sorts.
It's Alive!
  • Retired
  • AKA Daniel
Re: Qt in the ARX
« Reply #4 on: April 25, 2013, 06:30:41 PM »
Iíve toyed with widgets see http://www.theswamp.org/index.php?topic=31587.0 , but never QT
Retired
Hessebity
Re: Qt in the ARX
« Reply #5 on: August 01, 2013, 04:56:34 AM »
Hello
I already use Qt in my ARX programs with the qtwinmigrate ( http://qt.gitorious.org/qt-solutions/qt-solutions/trees/master/qtwinmigrate ) library.
To do that, I insert a QWinWidget :
Code - C++: [Select]
  1. HWND hWnd = adsw_acadMainWnd();
  2. QWidget myWidget = new QWidget( new QWinWidget(hWnd) );
So, my dialogs become perfectly modal.
I don't use MFC, but qtwinmigrate seems to work also with it.
It works both with ARX and BRX.
Concerning Linux, I haven't tryed yet. I don't know what adsw_acadMainWnd() returns in this case.
Have fun with that.
Re: Qt in the ARX
« Reply #6 on: August 01, 2013, 09:42:34 AM »
Hessebity, you may have just become my new best friend. That is a great link!!
Would you care to share a project with me/us? If you're not comfortable sharing with the forum would you be willing to share one with me personally (via email, github, code.google, etc)?
Hessebity
Re: Qt in the ARX
« Reply #7 on: August 05, 2013, 04:53:11 PM »
Hi Se7en,
I would be ok to send you a piece of my project that will show you how I use Qt.
Just send me an email and I'll reply ( you are an administrator, so you must have my adresse ).
Andrey Bushman
Re: Qt in the ARX
« Reply #8 on: August 06, 2013, 12:55:02 AM »
Hello
Have fun with that.
Thank you, it is very interesting. Can I use the Qt in the MS Visual Studio 2005? My users use the AutoCAD 2009, and MS VS 2005 are necessary for its ARX applications.
Hessebity
Re: Qt in the ARX
« Reply #9 on: August 06, 2013, 03:54:47 AM »
Yes you can.
Personally, I only use VC2008 and VC2010.
But you must find a VC2005 compiled version of Qt, or compile it yourself ( be careful, it takes hours ).
Re: Qt in the ARX
« Reply #10 on: August 06, 2013, 09:15:27 AM »
Hi Se7en,
Email sent. Thank you very much Hessebity. Very kind of you!
frtfff
Re: Qt in the ARX
« Reply #11 on: February 15, 2014, 05:06:20 AM »
I can reply this in chinese :牛逼~crazy。
