Author Topic: Engineering Site Grading question  (Read 15256 times)
MSTG007
« Reply #30 on: April 26, 2005, 05:42:03 PM »
Hey.. question I am getting an error
; error: bad argument type: numberp: #<SUBR @05b7f768 ->
any ideas?
acad 2005
it was working fine
Civil3D 2020
« Reply #31 on: April 26, 2005, 05:47:12 PM »
An expression that is expecting a number is getting something else.
Define this --
(defun *error* (x) (vl-bt))
-- and run your proggy again.
What does it dump now? (It should indicate where the error is happening).
MSTG007
« Reply #32 on: April 27, 2005, 08:34:55 AM »
Command: sltag
.undo Enter the number of operations to undo or
[Auto/Control/BEgin/End/Mark/Back] <1>: begin
Command: Enter Starting Elevation <1200.0000>:
Backtrace:
[0.49] (VL-BT)
[1.45] (*ERROR* "bad argument type: numberp: #<SUBR @05b2f768 ->")
[2.40] (_call-err-hook #<SUBR @0ab4f3e8 *ERROR*> "bad argument type: numberp:
[3.34] (sys-error "bad argument type: numberp: #<SUBR @05b2f768 ->")
:ERROR-BREAK.29 nil
[4.26] (RTOS #<SUBR @05b2f768 -> 2 8)
[5.19] (C:SLTAG)
[6.15] (#<SUBR @0ab4f514 -rts_top->)
[7.12] (#<SUBR @05a72334 veval-str-body> "(C:SLTAG)" T #<FILE internal>)
:CALLBACK-ENTRY.6 (:CALLBACK-ENTRY)
:ARQ-SUBR-CALLBACK.3 (nil 0)
Civil3D 2020
« Reply #33 on: April 27, 2005, 08:37:41 AM »
There ya go --
In function (defun C:SLTAG ...) there is a call to (rtos ...) that is bombing because it is being passed a non numerical value.
« Reply #34 on: April 27, 2005, 09:28:03 AM »
It isn't obvious to me which one if the three variabales is causing the error.
Try this & see if we can determine which one.
;;; DESCRIPTION
;;; This lisp is design to calculate elevation or slope percentage.
;;; **Slvl**
;;; Calculates the elevation after user input of the highest
;;; level and slope percentage.
;;; The distance has to be specified by picking two endpoints
(defun C:Slvl (/ *Error* useros usercmd userlun slp elev dist p1 p2 chg)
  ;; error function & Routine Exit
  (defun *error* (msg)
      (not
        (member
          msg
          '("console break" "Function cancelled" "quit / exit abort" "")
    ) ; endif
    ;;reset all variables here
    (if useros (setvar "osmode" useros))
    (if usercmd (setvar "CMDECHO" usercmd))
    (if userlun (setvar "lunits" userlun))
    (setq useros  nil
          usercmd nil
          userlun nil
  ) ;end error function  (defun *Error* (msg) ; embedded defun
  (setq useros  (getvar "osmode")
        usercmd (getvar "CMDECHO")
        userlun (getvar "lunits")
  (setvar "osmode" 1) ; = endpoint
  (setvar "Lunits" 4) ; Feet & Inches
  (setq elev (Getdist "\nReference level (Eg : 100'-0'') : "))
  (setq slp
         (getreal
           "\nDesired Slope in Percentage, - for slope down (Eg : 3 for .03 or 3%) : "
  (initget 128) ; get point OR number OR string
  (setq p1 (getpoint "\nPick 1st point or enter DISTANCE: "))
    ((listp p1) ; got a point
     (if (setq p2 (getpoint p1 "\nPick 2nd point of DISTANCE: "))
       (setq dist (distance p1 p2))
    ((numberp p1) ; got a number
     (setq dist p1)
    ((setq dist (distof p1)) ; got a string, convert to number
    ((not (numberp elev))
     (prompt "\n***  Error in Elevation  ***")
    ((not (numberp slp))
     (prompt "\n***  Error in Slope  ***")
    ((not (numberp dist))
     (prompt "\n***  Error in Distance  ***")
    (t
     (setq slp  (/ slp 100.0)
           elev (/ elev 12.0)
           chg  (rtos (+ elev (* (/ dist 12.0) slp)) 2 2)
     (prompt
       (strcat "\n[Start Elev="
               (rtos elev 2 2)
               "'] [Distance="
               (rtos dist 4 2)
     (if (minusp slp)
       ;;-----slope calculation
       (prompt (strcat "[Level below is : " chg "']"))
       (prompt (strcat "[Level above is : " chg "']"))
  (*error* "")
(prompt "\nSlope Calc Loaded, Enter slvl to run.")
MSTG007
« Reply #35 on: April 27, 2005, 10:13:41 AM »
Command: slvl
Command:
Civil3D 2020
MSTG007
« Reply #36 on: April 27, 2005, 10:59:53 AM »
this is on the old one:
"AutoCAD menu utilities loaded.
Command: sltag .undo Enter the number of operations to undo or
Command: Enter Starting Elevation <1200.0000>:  ; error: bad argument type:
numberp: #<SUBR @058bf768 ->"
the following lisp code
;; Slope Tag  V1.2, 1989, '92
;; by RBCulp - Falcon Design Services, Inc.
;; NO RIGHTS RESERVED; Any and all content may reproduced by any method on any medium for any reason.
;; Please, feel free to use any part found useful, interesting, enlightening or entertaining.
;; If by some chance, someone wishes to be credited for this, go right ahead.
;; Falcon Design Services (FDS) provides this program "as is" and with all faults.
;; FDS specifically disclaims any implied warranty of merchantability or fitness for a particular use.
;; FDS does not warrant that the operation of the program will be uninterrupted or error free.
(defun c:sltag ( / scft nstelev nslope FIRSTPT PT1 PT2 distm dist1 nxtelev)
;;;;;;;;;;Set defaults on first use
(if (= stelev nil)  (setq stelev 1200.00))
(if (= slope nil)   (setq slope -.002))
(command ".undo" "begin")
(setvar "attdia" 0)
(setvar "texteval" 1)
(setq scft (getvar "dimscale"))
 (if (= 2 (getvar "lunits")) (setq tunit 2 tprec 3) )
 (if (= 4 (getvar "lunits")) (setq tunit 4 tprec 4) )
   (if (setq nstelev (getdist (strcat "Enter Starting Elevation <" (RTOS stelev) ">: ")))
       (setq stelev nstelev)
   (if (setq nslope (getreal (strcat "Enter Slope Factor (Negative For Down) <" (RTOS slope 2 8) ">: ")))
       (setq slope nslope)
  (setq FIRSTPT (getpoint "Select Starting point ")
   PT2 (getpoint FIRSTPT "\nNext point ")
   distm (distance firstpt pt2)
   nxtelev (+ (* distm slope) stelev)
(princ (strcat "\n                        Distance is  " (rtos (distance firstpt pt2))))
(princ (strcat "\n                           Slope is  " (rtos (* distm slope))))
(princ (strcat "\n                       Elevation is  " (rtos nxtelev tunit tprec)))
;;;; (txstla)
(command "-insert" "E:/CAD/Ielev" "s" scft "r" "0" pt2 (strcat (rtos nxtelev 2 2)" "))
  (while (/= PT2 nil)
    (setq PT1 PT2)
    (setq PT2 (getpoint PT1 "\n\nNext point "))
    (if (/= PT2 nil)
   (setq dist1 (distance pt1 pt2)
         distm (+ distm dist1)
         nxtelev (+ (* dist1 slope) nxtelev)
   (princ (strcat "\n                        Distance is  " (rtos dist1)))
   (princ (strcat "\n                           Slope is  " (rtos (* dist1 slope))))
   (princ (strcat "\n          Running Total Distance is  " (rtos distm)))
   (princ (strcat "\n\n          Final Total Distance is  " (rtos distm)))
(setvar "attdia" 1)
(command ".undo" "end")
Civil3D 2020
« Reply #37 on: April 27, 2005, 11:09:40 AM »
Well you see you are pressing enter as if the 100' is a default.
If it was a default it should be displayed as <100'-0"> to indicate default.
If you want to force the user to enter something. Use this.
(initget 1)
If you want 100, to be a default use this
(if (null elev) (setq elev (distof "100'")))
Another way to handle it is to have the routine remember the current setting while
the user is in one drawing. You would make a global variable like *elev*
;;  Load a global variable if null
(setq *elev* (cond (*elev*) (distof "100'")))
(if (null elev)
   (setq elev *elev*) ; use global
   (setq *elev* elev) ; reset global
« Reply #38 on: April 27, 2005, 11:28:54 AM »
Like this:
;;; DESCRIPTION
;;; **Slvl**
      (not
        (member
          msg
    ) ; endif
    (setq useros  nil
          usercmd nil
          userlun nil
  (setq *elev* (cond (*elev*) (t (distof "100'"))))
  (setq elev (Getdist (strcat "\nReference level (100'-6\"or 100.5') <" (rtos *elev* 4 2) ">: ")))
  (if (null elev)
  (setq *slp* (cond (*slp*) (0.01)))
  (setq slp
         (getreal
           (strcat "\nEnter Slope Percentage, - for slope down ( 3 = .03 or 3%) <"
                   (rtos (* 100 *slp*) 2 2) ">: ")
  (if (null slp)
     (setq slp *slp*) ; use global
     (setq *slp* (/ slp 100)) ; reset global
     (setq dist p1)
    (t
           elev (/ elev 12.0)
     (prompt (strcat "\n[Start Elev=" (rtos elev 2 2) "'] [Distance="
               (rtos dist 4 2) "] ")
     (if (minusp slp)
  (*error* "")
MSTG007
« Reply #39 on: April 27, 2005, 11:38:07 AM »
Thank you CAB. that works:)
The above last lisp that i posted. The same code you applied to this one, Can i apply to the one which i am getting this wierd error too.
"Command: sltag
Backtrace:
[0.49] (VL-BT)
:ERROR-BREAK.29 nil
[5.19] (C:SLTAG)
:ARQ-SUBR-CALLBACK.3 (nil 0)"
Is MP right about the call of RTOS?
Civil3D 2020
« Reply #40 on: April 27, 2005, 12:05:35 PM »
Quote from: MSTG007
MP is always right.
« Reply #41 on: April 27, 2005, 12:12:48 PM »
Quote from: MSTG007
You are welcome.
And Yes you can.
MSTG007
« Reply #42 on: April 27, 2005, 12:53:03 PM »
grrh still no luck
      (not
        (member
          msg
    ) ; endif
    (setq useros  nil
          usercmd nil
          userlun nil
(if (= slope nil)   (setq slope -0.002))
(setvar "attdia" 0)
       (setq slope nslope)
;;;; (txstla)
  (while (/= PT2 nil)
    (setq PT1 PT2)
    (if (/= PT2 nil)
(setvar "attdia" 1)
(*error* "")
Civil3D 2020
CADaver
« Reply #43 on: April 27, 2005, 12:58:34 PM »
The program uses GETDIST when asking for the input, how are you entering that distance?
3% is text not a distance .03 is a distance.
MSTG007
« Reply #44 on: April 27, 2005, 01:31:47 PM »
as .03 = 3%
Civil3D 2020
