Author Topic: Engineering Site Grading question  (Read 15259 times)
MSTG007
« on: March 17, 2005, 07:29:05 PM »
Gotta a good question!
When designers on a site design a site and need to calc spot elevations at top of curb bottom of curb, side walks, building Finish floors... They usually need to carry the Fin Floor elev through out of the rest of the site.
would it make it sense to have a lsp or something which can calc the grade for you?
ex.
input fin floor elev. = 800.00
asks what slope. = -2%
then asks the starting point and a ending point for a distance
then places a spot elevation at the second point of where you got the distance to show you what the spot elevation is
does this make sense? or is there another easier idea?
thanks!!!!!!!!!!
Civil3D 2020
CarlB
« Reply #1 on: March 18, 2005, 02:41:18 AM »
Yes a routine like that might be helpful in setting elevations in a uniformly graded area.  But when using automation be careful not to abandon critical thinking.  Such as - what is drop from FF to adjacent grade (different at doorways and landscaped areas), drop at edge sidewalk (6" approx), the slope away from building different than slope along building so a constant grade applies only in one direction, etc......
MSTG007
« Reply #2 on: March 18, 2005, 06:27:40 PM »
is this possible?
Civil3D 2020
« Reply #3 on: March 18, 2005, 08:00:58 PM »
Quote from: MSTG007
is this possible?
Yes it is very easy.
But as Carl pointed out the user has to be careful how it is applied.
CADaver
« Reply #4 on: March 19, 2005, 08:43:09 AM »
I have a little slope calculator I wrote a long time ago that will calc elevations based on a starting elevation and the percent slope and multiple selection points.  I use it for underground pipe calcs, but it'll work on uniformly sloped grades as well.
;; Slope calculator  V2.3, 1987, '88, '90, '92, '94
;; by RBCulp - Falcon Design Services, Inc.
;; NO RIGHTS RESERVED; Any and all content may reproduced by any method on any medium for any reason.
;; Please, feel free to use any part found useful, interesting, enlightening or entertaining.
;; If by some chance, someone wishes to be credited for this, go right ahead.
;; Falcon Design Services (FDS) provides this program "as is" and with all faults.
;; FDS specifically disclaims any implied warranty of merchantability or fitness for a particular use.
;; FDS does not warrant that the operation of the program will be uninterrupted or error free.
(defun c:slcalc ()
;;;;;;;;;;Set defaults on first use
(if (= stelev nil)  (setq stelev 1200.00))
(if (= endelev nil) (setq endelev 1188.00))
(if (= slope nil)   (setq slope -0.002))
;;;;;;;;;;Slope Calculator based on Percent Slope
  (defun slcalcs ( / nstelev nslope distm dist1 nxtelev firstpt PT1 PT2)
     (if (setq nstelev (getdist (strcat "Enter Starting Elevation <" (RTOS stelev) ">: ")))
(setq stelev nstelev)
     (if (setq nslope (getreal (strcat "Enter Slope Factor (Negative For Down) <" (RTOS slope 2 8) ">: ")))
(setq slope nslope)
      (setq FIRSTPT (getpoint "Pick point ")
   PT2 (getpoint FIRSTPT "\nNext point ")
   distm (distance firstpt pt2)
   nxtelev (+ (* distm slope) stelev)
    (princ (strcat "\n                        Distance is  " (rtos (distance firstpt pt2))))
    (princ (strcat "\n                           Slope is  " (rtos (* distm slope))))
    (princ (strcat "\n                       Elevation is  " (rtos nxtelev)))
    (princ (strcat "\n                       Elevation is  " (rtos (/ nxtelev 12.0) 2 2)"'"))
      (while (/= PT2 nil)
(setq PT1 PT2)
(setq PT2 (getpoint PT1 "\n\nNext point "))
(if (/= PT2 nil)
   (setq dist1 (distance pt1 pt2)
 distm (+ distm dist1)
 nxtelev (+ (* dist1 slope) nxtelev)
   (princ (strcat "\n                        Distance is  " (rtos dist1)))
   (princ (strcat "\n                           Slope is  " (rtos (* dist1 slope))))
   (princ (strcat "\n                     Running Total Distance is  " (rtos distm)))
    (princ (strcat "\n                       Final Total Distance is  " (rtos distm)))
    (princ (strcat "\n                   Final Total Slope Change is  " (rtos (* distm slope))))
    (princ (strcat "\n                            Final Elevation is  " (rtos nxtelev)))
    (princ (strcat "\n                            Final Elevation is  " (rtos (/ nxtelev 12.0) 2 2)"'"))
;;;;;;;;;;Slope Calculator based on Start and End Elevations
    (defun slcalce ( / nstelev nendelev distm dist1 nxtelev firstpt PT1 PT2)
      (if (setq nendelev (getdist (strcat "  Enter Ending Elevation <" (RTOS endelev) ">: ")))
 (setq endelev nendelev)
      (setq slope (- 0.0 (- stelev endelev))
      (while (/= PT2 nil)
(setq PT1 PT2)
(if (/= PT2 nil)
    (princ (strcat "\n           Total Elevation Change is  " (rtos slope 2 6)))
    (princ (strcat "\n                    Percent Slope is  " (rtos (/ slope distm) 2 8) "     Neg.=Down  Pos.=Up"))
      (setq slope (/ slope distm))
;;;;;;;;;;Kick-off routine
(initget "Slope Elevation")
(setq ans (getkword "\nKnown (S)lope or (E)levations  < S/E >"))
(If (= ans "Slope")(slcalcs)(slcalce))
I'm sure the guys here can clean it up considerably.  Somewhere I have a modified version that inserts an Elevation block at each point along the way.
MSTG007
« Reply #5 on: March 19, 2005, 11:33:03 AM »
wow... that would be great! if you can find that.
thanks!!!!
Civil3D 2020
CADaver
« Reply #6 on: March 19, 2005, 12:34:26 PM »
Quote from: MSTG007
thanks!!!!
If I were you, I'd probably wait on some of the real gurus around here to post some truly elegant code.  (CAB that'd include you dood).  But here is what I have.
For this to work you need to go HERE , look in directory CADAVER, and download IELEV.DWG into <SOMEDIRECTORY> on your system,
Then, you need to edit the routine to change "E:/CLIENT/MATRIX/TABS/str/" to  <SOMEDIRECTORY>
NOTICE: This thang has NO error trapping.  Should you choose to use it, you are on yer own, Bubba.
;; Slope Tag  V1.2, 1989, '92
(defun c:sltag ( / scft nstelev nslope FIRSTPT PT1 PT2 distm dist1 nxtelev)
(command ".undo" "begin")
(setvar "attdia" 0)
(setvar "texteval" 1)
(setq scft (getvar "dimscale"))
 (if (= 2 (getvar "lunits")) (setq tunit 2 tprec 3) )
 (if (= 4 (getvar "lunits")) (setq tunit 4 tprec 4) )
       (setq slope nslope)
  (setq FIRSTPT (getpoint "Select Starting point ")
(princ (strcat "\n                       Elevation is  " (rtos nxtelev tunit tprec)))
;;;; (txstla)
(command "-insert" "E:/CLIENT/MATRIX/TABS/str/Ielev" "s" scft "r" "45" pt2 (strcat (rtos (/ nxtelev 12.0) 2 2)"'"))
  (while (/= PT2 nil)
    (setq PT1 PT2)
    (if (/= PT2 nil)
(princ (strcat "\n\n          Final Total Distance is  " (rtos distm)))
(setvar "attdia" 1)
(command ".undo" "end")
MSTG007
« Reply #7 on: March 19, 2005, 03:26:20 PM »
Command:  SLTAG .undo Enter the number of operations to undo or
[Auto/Control/BEgin/End/Mark/Back] <1>: begin
Command: Enter Starting Elevation <78.0000>:
Enter Slope Factor (Negative For Down) <-0.00200000>:
Next point 100
                        Distance is  100.0000
                           Slope is  -0.2000
                       Elevation is  77.800-insert Enter block name or [?]
<ielev>: C:ielev Specify insertion point or
[Scale/X/Y/Z/Rotate/PScale/PX/PY/PZ/PRotate]: s Specify scale factor for XYZ
axes: 1.000000000000000 Specify insertion point or
[Scale/X/Y/Z/Rotate/PScale/PX/PY/PZ/PRotate]: r Specify rotation angle: 45
Specify insertion point or [Scale/X/Y/Z/Rotate/PScale/PX/PY/PZ/PRotate]:
Enter attribute values
ELEV....: 6.48'
hey. i set it up like you said... but the 6.48' is suppose to be a 64.89'
I started at a 78 elevation and carried it...
other than that the block comes in ok!
Civil3D 2020
CADaver
« Reply #8 on: March 19, 2005, 04:08:59 PM »
Oops, sorry.  Mine is set up for working in ft-in drawings (LUPREC=4).  You must be working in ft-dec drawings (LUPREC=2).  So you have to remove the division by 12 part of the attribute fill-in
change this line (both of them)
to
(command "-insert" "E:/CLIENT/MATRIX/TABS/str/Ielev" "s" scft "r" "45" pt2 (strcat (rtos nxtelev 2 2)"'"))
and try it again.
BTW, you can also add a
(setvar "cmdecho" 0)at the top after the "UNDO" line to cleanup the echoing.
« Reply #9 on: March 20, 2005, 12:22:03 AM »
CADaver,
Nice routine.
I tweaked it a bit, added the Make Block so you don't have to have the ielev.DWG
Need to revise the way the feet mark is added to the elev tag. May have to prompt the use during start up
to see what unit of measure he/she is using. To little time to much code. :)
Anyway give it a spin.
;;   Revised 03/19/2005 - CAB
(defun c:sltag (/ scft nstelev nslope FIRSTPT PT1 PT2 distm dist1 nxtelev
                *error* save_sys_vars restore_sys_vars make_block $elev)
  ;;         L o c a l   F u n c t i o n s
  ;; error function & Routine Exit
  (defun *error* (msg)
      (not
        (member
          msg
          '("console break" "Function cancelled" "quit / exit abort" "")
       (princ (strcat "\nError: " msg))
    )   ; endif
    (restore_sys_vars); reset vars
  ;; Function to save system variables in global variable
  (defun save_sys_vars (lst)
    (setq *sysvarlist* '())
    (repeat (length lst)
      (setq *sysvarlist* (append *sysvarlist* (list (list (car lst) (getvar (car lst))))))
      (setq lst (cdr lst))
  ;; Function to reset system variables
  (defun restore_sys_vars ()
    (repeat (length *sysvarlist*)
      (setvar (caar *sysvarlist*) (cadar *sysvarlist*))
      (setq *sysvarlist* (cdr *sysvarlist*))
  ;;-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_
  ;;           Make the elevation tag block
  (defun make_block(blockname)
    ;;       Start of Block definition
    (entmake
      (list '(0 . "BLOCK")            ; required
            '(100 . "AcDbEntity")     ; recommended
            '(100 . "AcDbBlockBegin") ; recommended
            (cons 2 blockname)        ; required
            '(8 . "0")                ; recommended
            '(70 . 2)                 ; required [NOTE 0 if no attributes]
            '(10 0.0 0.0 0.0)         ; required
    ;;            Block objects
    ;; NOTE: Wipeouts must be created first for other objects to be visable
    (entmake '((0 . "WIPEOUT") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0")
              (100 . "AcDbWipeout") (90 . 0) (10 0.0078125 -0.0859375 0.0) (11 0.625 0.0 0.0)
              (12 0.0 0.625 0.0) (13 1.0 1.0 0.0) (70 . 7) (280 . 1)
              (281 . 50) (282 . 50) (283 . 0) (71 . 2) (91 . 9) (14 -0.5 0.4625 0.0)
              (14 -0.225 0.4625 0.0) (14 -0.225 0.5 0.0) (14 0.5 0.5 0.0) (14 0.5 0.225 0.0)
              (14 -0.225 0.225 0.0) (14 -0.225 0.2625 0.0) (14 -0.5 0.2625 0.0) (14 -0.5 0.4625 0.0)))
    (entmake '((0 . "ATTDEF") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (100 . "AcDbText")
              (10 0.279583 -0.05 0.0) (40 . 0.1) (1 . "") (50 . 0.0) (41 . 0.7) (51 . 0.0)
              (7 . "Standard") (71 . 0) (72 . 1) (11 0.40625 0.0 0.0) (210 0.0 0.0 1.0)
              (100 . "AcDbAttributeDefinition") (3 . "ELEV....") (2 . "ELEV") (70 . 0)
              (73 . 0) (74 . 2)))
    (entmake '((0 . "LWPOLYLINE") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0")
              (100 . "AcDbPolyline") (90 . 4) (70 . 1) (43 . 0.0) (38 . 0.0) (39 . 0.0)
              (10 0.183594 -0.0789062) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 0.628906 -0.0789062)
              (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 0.628906 0.0789062) (40 . 0.0) (41 . 0.0)
              (42 . 0.0) (10 0.183594 0.0789062) (40 . 0.0) (41 . 0.0) (42 . 0.0) (210 0.0 0.0 1.0)))
    (entmake '((0 . "TEXT") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0")
              (100 . "AcDbText") (10 0.00806548 -0.05 0.0) (40 . 0.1) (1 . "I.E.") (50 . 0.0)
              (41 . 0.8) (51 . 0.0) (7 . "Standard") (71 . 0) (72 . 2) (11 0.171875 0.0 0.0)
              (210 0.0 0.0 1.0) (100 . "AcDbText") (73 . 2)))
    ;;     This is the end of block marker
    (entmake (list '(0 . "ENDBLK")         ; required
                   '(100 . "AcDbBlockEnd") ; recommended
  ) ;                 end defun make_block
  ;;                    S T A R T   O F   R O U T I N E
  ;;    Set defaults on first use
  (or *stelev* (setq *stelev* 1200.00))
  (or *slope*  (setq *slope*  -0.002))
  (if (not (setq *units*
              (car(member *units* '("Inch" "Foot" "Meter" "Centimeter")))))
      (initget "Inch Foot Meter Centimeter")
      (setq *units*
             (getkword
               "\nOne Unit in this drawing = [Inch/Foot/Meter/Centimeter] <Inch>:"))
      (or *units* (setq *units* "Inch"))
  (save_sys_vars '("CMDECHO" "attdia" "attreq" "texteval"))
  (setvar "attdia"   0)
  (setvar "attreq"   1)
        tunit (getvar "lunits")
        distm 0)
    ((= 2 tunit)
      (setq tprec 3)
    ((= 4 tunit)
      (setq tprec 4)
    (T
      (setq tprec 3)
  (if (and (not (tblsearch "Block" "Ielev"))
           (not (make_block "Ielev")))
      (alert "Make Block Failed, can not continue.")
      (exit)
 (if (and
        (or (not (setq nstelev
             (getdist (strcat "Enter Starting Elevation <" (RTOS *stelev*) ">: "))))
           (setq *stelev* nstelev))
        (or (not (setq nslope (getreal (strcat "Enter Slope Factor (Negative For Down) <"
                                    (RTOS *slope* 2 8)  ">: " ))))
            (setq *slope* nslope))
        (setq FIRSTPT (getpoint "Select Starting point "))
        (setq pt1     firstpt
              nxtelev *stelev*)
      ) ; and
    (while (setq PT2 (getpoint PT1 "\n\nNext point "))
            nxtelev (+ (* dist1 *slope*) nxtelev)
            PT1 PT2
                     (rtos (* dist1 *slope*))))
      (if (= *units* "Inch") ; convert to feet
        (setq $elev (rtos (/ nxtelev 12.0) 2 2))
        (setq $elev (rtos nxtelev 2 2))
      (if (or (eq *units* "Inch") (eq *units* "Foot"))
        (setq $elev (strcat $elev "'"))
      (command "-insert" "Ielev" "s" scft "r" "45" pt2 $elev)
    ) ; end while
  ); endif
  (*error* "") ; restore variables
(prompt "\n***   Slope Tag Loaded, Enter sltag to run.  ***")
;;  eof
« Reply #10 on: March 20, 2005, 09:04:58 AM »
Had it working last night but.
Got an error, the make block doesn't work yet.
I'll see if I can fix it this afternoon.
MSTG007
« Reply #11 on: March 20, 2005, 01:25:39 PM »
stupid question.
how hard would it be to add a leader with text above the leader telling the slope with the direction?
And then possibly have the block look like a grading spot elevation?
 _______
|XXX.XX|
                 X    < ---  location of spot
Civil3D 2020
« Reply #12 on: March 20, 2005, 07:36:23 PM »
Updated the code above. Got the block create code working.
Added the prompt for units. :)
MSTG007
« Reply #13 on: March 20, 2005, 08:09:44 PM »
hey cab
I am using CIVIL 3D 2k5
I am getting a
"Make Block Failed, can not continue"
Command: sltag
Command:
Command:
Command:
any ideas?
thanks!
Civil3D 2020
« Reply #14 on: March 20, 2005, 08:22:39 PM »
Did you copy the code again?
I updated it 40 minutes ago.
MSTG007
« Reply #15 on: March 21, 2005, 07:18:01 AM »
cab,
Yup it still does it... I am on another machine at work. Still geting the same error as above
Civil3D 2020
CADaver
« Reply #16 on: March 21, 2005, 07:46:37 AM »
I knew somebody (read that as CAB) would be able to tweak* it some.
Thanks, that's sweet.
(*Tweak = Sow's Ear to Silk Purse)
« Reply #17 on: March 21, 2005, 08:00:43 AM »
Try this, comment out the WIPEOUT entity & see if the block can be created. It is a function of
express tools and may not be supported in your setup. Do you have Express tools?
;    (entmake '((0 . "WIPEOUT") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0")
;              (100 . "AcDbWipeout") (90 . 0) (10 0.0078125 -0.0859375 0.0) (11 0.625 0.0 0.0)
;              (12 0.0 0.625 0.0) (13 1.0 1.0 0.0) (70 . 7) (280 . 1)
;              (281 . 50) (282 . 50) (283 . 0) (71 . 2) (91 . 9) (14 -0.5 0.4625 0.0)
;              (14 -0.225 0.4625 0.0) (14 -0.225 0.5 0.0) (14 0.5 0.5 0.0) (14 0.5 0.225 0.0)
;              (14 -0.225 0.225 0.0) (14 -0.225 0.2625 0.0) (14 -0.5 0.2625 0.0) (14 -0.5 0.4625 0.0)))
Let me know what you find out.
MSTG007
« Reply #18 on: March 21, 2005, 09:34:47 AM »
do you think you can make the block look similar to this
http://www.theswamp.org/lilly_pond/mstg007/SPOTgrade.dwg?nossi=1
I know the lisp actually draws the block opposed to the block already defined.
Thanks cab!
it works great now!
Civil3D 2020
« Reply #19 on: March 21, 2005, 10:15:30 AM »
Glad you like it.
Quote from: MSTG007
it works great now!
Did you have to remove the WIPEOUT to get it to work??
Quote from: MSTG007
Short answer is Yes, but you can use the previous routine that CADaver posted & replace
"ielev" with your block name, put it in the ACAD search path, remove the path string
and update the attributes strings to match your block.
« Reply #20 on: March 21, 2005, 10:23:43 AM »
Here is another update:
Added code to detect Expresstools and ignore the WIPEOUT if ET is not be loaded.
;;   Revised 03/19/2005 - CAB Version 2.1
      (not
        (member
          msg
    )   ; endif
  (defun make_block(blockname / et)
    ;;  Check for ExpressTools
    (if (member "acetutil.arx" (arx))
(if (wcmatch (getvar "ACADVER") "*16*")
           (or (not (arxload "acwipeout")) (setq et T))
           (or (not(member "wipeout.arx" (arx)))(setq et T))
    (if (not et)
       (alert "Express Tools are not Loaded \n Tag will be 'See Through'")
    (entmake
    ;;            Block objects
    (if et
              (73 . 0) (74 . 2)))
      (setq *units*
             (getkword
  (setvar "attdia"   0)
  (setvar "attreq"   1)
        distm 0)
    ((= 2 tunit)
      (setq tprec 3)
    ((= 4 tunit)
      (setq tprec 4)
    (T
      (setq tprec 3)
      (exit)
 (if (and
        (setq pt1     firstpt
              nxtelev *stelev*)
      ) ; and
            PT1 PT2
    ) ; end while
  ); endif
;;  eof
« Reply #21 on: March 21, 2005, 11:23:47 AM »
Here is yet another version based on the scenario CarlB posted.
See the picture below to illustrate.
ST PT 1 is the very first point chosen and elevation set at 100'
points were the chosen along the RED arrow to show slope along the
house foundation.
ST PT 2 is chosen using the NEW option. The new start point elevation is
99.97' based on distance Stpt1 to stpt2. Then points are added along the
green arrow showing slope in that direction.
ST PT 3 is chosen using the NEW option. The new start point elevation is
99.94' based on distance Stpt2 to stpt3. Then points are added along the
cyan arrow showing slope in that direction.
;;   Revised 03/21/2005 - CAB Version 2.1
;;     all elev are calc for start point, you may reset the start point
;;     new start point elev is based on the previous start point elevation
(defun c:sltag2 (/ scft stelev nstelev nslope FIRSTPT PT1 PT2 distm dist1 nxtelev
      (not
        (member
          msg
    )   ; endif
           (or (NOT (arxload "acwipeout")) (setq et T))
    (if (not et)
    (entmake
    ;;            Block objects
    (if et
              (73 . 0) (74 . 2)))
      (setq *units*
             (getkword
  (setvar "attdia"   0)
  (setvar "attreq"   1)
        distm 0)
    ((= 2 tunit)
      (setq tprec 3)
    ((= 4 tunit)
      (setq tprec 4)
    (T
      (setq tprec 3)
      (exit)
 (if (and
        (setq pt1 (getpoint "Select Starting point "))
        (setq stelev *stelev*)
      ) ; and
    (while (or
              (initget "New")
              (setq PT2 (getpoint PT1 "\n\nNext point or New point "))
           ) ;end or
      ((listp PT2); Is PT a point list?
            nxtelev (+ (* dist1 *slope*) stelev)
      (T ; new start point based on base elevation
        (while
          (not (setq pt2 (getpoint pt1 "\n>>--> Select New Starting point: ")))
          (princ "\nPlease try again..."))
              stelev  (+ (* dist1 *slope*) stelev)
              pt1     pt2
     ) ; end cond stmt
    ) ; end while
  ); endif
(prompt "\n***   Slope Tag Loaded, Enter sltag2 to run.  ***")
;;  eof
danny
« Reply #22 on: March 21, 2005, 12:24:45 PM »
CAB,
I get an error message
make block failed, cannot continue
CADaver
« Reply #23 on: March 21, 2005, 12:34:16 PM »
Just so you know, I just noticed the ????? in your tweaked code.
        distm 0)
    ((= 2 tunit)
      (setq tprec 3)
    ((= 4 tunit)
      (setq tprec 4)
    (T
      (setq tprec 3)
I was in the process of tweaking the code a couple years ago, and I was gonna read LUNITS to determine whether we were in a FT-IN file or a FT-DEC.  Then I was gonna do the calcs and set the attribute value precision based on that.
(rtos nxtelev tunit tprec))) Since then, we changed our standard such that ALL site elevations are FT-DEC to 2 places.
CADaver
« Reply #24 on: March 21, 2005, 12:37:39 PM »
BTW, why don't you go ahead and fix the rest of the code and take my header (such as it is) off all together.   :wink:  That's pretty sweet coding, dood.  Do you have a real job???
« Reply #25 on: March 21, 2005, 01:59:58 PM »
Quote from: danny
CAB,
** make block failed, cannot continue
Sorry about that.
What version of Autocad are you running and do you have Expresstools loaded?
danny
« Reply #26 on: March 21, 2005, 02:11:00 PM »
no need to be sorry.....
the version I tested it in was ACAD2004, and express tools was loaded. :?
« Reply #27 on: March 21, 2005, 07:39:07 PM »
danny,
recopy the routines above, I updated both of them.
It is the WIPEOUT that is giving me a problem and detecting express tools.
In ACAD2000 when acetutil.arx is loaded the wipeout.arx is also loaded so
all is well, but in ACAD2004 acetutil.arx may be loaded and acwipeout.arx
is not always loaded and the name of the routine is changed.
Therefore a more elaborate detection algorithm was needed. I don't have
ACAD R14 or 2002 or 2005 so I can't test these.
« Reply #28 on: March 21, 2005, 07:55:29 PM »
Quote from: CADaver
No :) , if i did they would fire me or take away my IE connection.
CADaver
« Reply #29 on: March 21, 2005, 08:06:01 PM »
Quote from: CAB
Quote from: CADaver
Do you want one?
no, wait a minute...
they find out they really don't need me...
nevermind.
MSTG007
« Reply #30 on: April 26, 2005, 05:42:03 PM »
Hey.. question I am getting an error
; error: bad argument type: numberp: #<SUBR @05b7f768 ->
any ideas?
acad 2005
it was working fine
Civil3D 2020
« Reply #31 on: April 26, 2005, 05:47:12 PM »
An expression that is expecting a number is getting something else.
Define this --
(defun *error* (x) (vl-bt))
-- and run your proggy again.
What does it dump now? (It should indicate where the error is happening).
MSTG007
« Reply #32 on: April 27, 2005, 08:34:55 AM »
Command: sltag
Command: Enter Starting Elevation <1200.0000>:
Backtrace:
[0.49] (VL-BT)
[1.45] (*ERROR* "bad argument type: numberp: #<SUBR @05b2f768 ->")
[2.40] (_call-err-hook #<SUBR @0ab4f3e8 *ERROR*> "bad argument type: numberp:
[3.34] (sys-error "bad argument type: numberp: #<SUBR @05b2f768 ->")
:ERROR-BREAK.29 nil
[4.26] (RTOS #<SUBR @05b2f768 -> 2 8)
[5.19] (C:SLTAG)
[6.15] (#<SUBR @0ab4f514 -rts_top->)
[7.12] (#<SUBR @05a72334 veval-str-body> "(C:SLTAG)" T #<FILE internal>)
:CALLBACK-ENTRY.6 (:CALLBACK-ENTRY)
:ARQ-SUBR-CALLBACK.3 (nil 0)
Civil3D 2020
« Reply #33 on: April 27, 2005, 08:37:41 AM »
There ya go --
In function (defun C:SLTAG ...) there is a call to (rtos ...) that is bombing because it is being passed a non numerical value.
« Reply #34 on: April 27, 2005, 09:28:03 AM »
It isn't obvious to me which one if the three variabales is causing the error.
Try this & see if we can determine which one.
;;; DESCRIPTION
;;; This lisp is design to calculate elevation or slope percentage.
;;; **Slvl**
;;; Calculates the elevation after user input of the highest
;;; level and slope percentage.
;;; The distance has to be specified by picking two endpoints
(defun C:Slvl (/ *Error* useros usercmd userlun slp elev dist p1 p2 chg)
      (not
        (member
          msg
    ) ; endif
    ;;reset all variables here
    (if useros (setvar "osmode" useros))
    (if usercmd (setvar "CMDECHO" usercmd))
    (if userlun (setvar "lunits" userlun))
    (setq useros  nil
          usercmd nil
          userlun nil
  ) ;end error function  (defun *Error* (msg) ; embedded defun
  (setq useros  (getvar "osmode")
        usercmd (getvar "CMDECHO")
        userlun (getvar "lunits")
  (setvar "osmode" 1) ; = endpoint
  (setvar "Lunits" 4) ; Feet & Inches
  (setq elev (Getdist "\nReference level (Eg : 100'-0'') : "))
  (setq slp
         (getreal
           "\nDesired Slope in Percentage, - for slope down (Eg : 3 for .03 or 3%) : "
  (initget 128) ; get point OR number OR string
  (setq p1 (getpoint "\nPick 1st point or enter DISTANCE: "))
    ((listp p1) ; got a point
     (if (setq p2 (getpoint p1 "\nPick 2nd point of DISTANCE: "))
       (setq dist (distance p1 p2))
    ((numberp p1) ; got a number
     (setq dist p1)
    ((setq dist (distof p1)) ; got a string, convert to number
    ((not (numberp elev))
     (prompt "\n***  Error in Elevation  ***")
    ((not (numberp slp))
     (prompt "\n***  Error in Slope  ***")
    ((not (numberp dist))
     (prompt "\n***  Error in Distance  ***")
    (t
     (setq slp  (/ slp 100.0)
           elev (/ elev 12.0)
           chg  (rtos (+ elev (* (/ dist 12.0) slp)) 2 2)
     (prompt
       (strcat "\n[Start Elev="
               (rtos elev 2 2)
               "'] [Distance="
               (rtos dist 4 2)
     (if (minusp slp)
       ;;-----slope calculation
       (prompt (strcat "[Level below is : " chg "']"))
       (prompt (strcat "[Level above is : " chg "']"))
  (*error* "")
(prompt "\nSlope Calc Loaded, Enter slvl to run.")
MSTG007
« Reply #35 on: April 27, 2005, 10:13:41 AM »
Command: slvl
Command:
Civil3D 2020
MSTG007
« Reply #36 on: April 27, 2005, 10:59:53 AM »
this is on the old one:
"AutoCAD menu utilities loaded.
Command: sltag .undo Enter the number of operations to undo or
Command: Enter Starting Elevation <1200.0000>:  ; error: bad argument type:
numberp: #<SUBR @058bf768 ->"
the following lisp code
(if (= slope nil)   (setq slope -.002))
(setvar "attdia" 0)
       (setq slope nslope)
;;;; (txstla)
(command "-insert" "E:/CAD/Ielev" "s" scft "r" "0" pt2 (strcat (rtos nxtelev 2 2)" "))
  (while (/= PT2 nil)
    (setq PT1 PT2)
    (if (/= PT2 nil)
(setvar "attdia" 1)
Civil3D 2020
« Reply #37 on: April 27, 2005, 11:09:40 AM »
Well you see you are pressing enter as if the 100' is a default.
If it was a default it should be displayed as <100'-0"> to indicate default.
If you want to force the user to enter something. Use this.
(initget 1)
If you want 100, to be a default use this
(if (null elev) (setq elev (distof "100'")))
Another way to handle it is to have the routine remember the current setting while
the user is in one drawing. You would make a global variable like *elev*
;;  Load a global variable if null
(setq *elev* (cond (*elev*) (distof "100'")))
(if (null elev)
   (setq elev *elev*) ; use global
   (setq *elev* elev) ; reset global
« Reply #38 on: April 27, 2005, 11:28:54 AM »
Like this:
;;; DESCRIPTION
;;; **Slvl**
      (not
        (member
          msg
    ) ; endif
    (setq useros  nil
          usercmd nil
          userlun nil
  (setq *elev* (cond (*elev*) (t (distof "100'"))))
  (setq elev (Getdist (strcat "\nReference level (100'-6\"or 100.5') <" (rtos *elev* 4 2) ">: ")))
  (if (null elev)
  (setq *slp* (cond (*slp*) (0.01)))
  (setq slp
         (getreal
           (strcat "\nEnter Slope Percentage, - for slope down ( 3 = .03 or 3%) <"
                   (rtos (* 100 *slp*) 2 2) ">: ")
  (if (null slp)
     (setq slp *slp*) ; use global
     (setq *slp* (/ slp 100)) ; reset global
     (setq dist p1)
    (t
           elev (/ elev 12.0)
     (prompt (strcat "\n[Start Elev=" (rtos elev 2 2) "'] [Distance="
               (rtos dist 4 2) "] ")
     (if (minusp slp)
  (*error* "")
MSTG007
« Reply #39 on: April 27, 2005, 11:38:07 AM »
Thank you CAB. that works:)
The above last lisp that i posted. The same code you applied to this one, Can i apply to the one which i am getting this wierd error too.
"Command: sltag
Backtrace:
[0.49] (VL-BT)
:ERROR-BREAK.29 nil
[5.19] (C:SLTAG)
:ARQ-SUBR-CALLBACK.3 (nil 0)"
Is MP right about the call of RTOS?
Civil3D 2020
« Reply #40 on: April 27, 2005, 12:05:35 PM »
Quote from: MSTG007
MP is always right.
« Reply #41 on: April 27, 2005, 12:12:48 PM »
Quote from: MSTG007
You are welcome.
And Yes you can.
MSTG007
« Reply #42 on: April 27, 2005, 12:53:03 PM »
grrh still no luck
      (not
        (member
          msg
    ) ; endif
    (setq useros  nil
          usercmd nil
          userlun nil
(setvar "attdia" 0)
       (setq slope nslope)
;;;; (txstla)
  (while (/= PT2 nil)
    (setq PT1 PT2)
    (if (/= PT2 nil)
(setvar "attdia" 1)
(*error* "")
Civil3D 2020
CADaver
« Reply #43 on: April 27, 2005, 12:58:34 PM »
The program uses GETDIST when asking for the input, how are you entering that distance?
3% is text not a distance .03 is a distance.
MSTG007
« Reply #44 on: April 27, 2005, 01:31:47 PM »
as .03 = 3%
Civil3D 2020
CADaver
« Reply #45 on: April 27, 2005, 06:46:37 PM »
Quote from: MSTG007
as .03 = 3%
Exactly, if you answer the prompt with .03 eveything should work, but if you entered 3% it'd blow up.
« Reply #46 on: April 27, 2005, 07:30:38 PM »
Quote from: CAB
MP is always right.
The only time I was ever right was the time I stated that I am frequently wrong.
:lol:
Jeff_M
  • C3D user & customizer
« Reply #47 on: April 27, 2005, 09:09:39 PM »
The problem with the code is that "slope" is a defined function, and it is this line that is cfreating the problem:
-.002 is NOT a real number so lisp is interpreting it as a new subroutine. Change it to be -0.002 and all will be well.
